[Ovmsdev] Release Firmware
Sat Apr 13 02:16:58 HKT 2013
Nikki,
yes, see attachment.
I could not make out any possible source of that strange error I had
yesterday (completely garbled data).
I made a clean build with a freshly started MPLAB and got no errors up
to now.
May have been something completely different, not related to my last
changes.
Am 12.04.2013 17:01, schrieb Nikki Gordon-Bloomfield:
> Michael,
> Any new firmware for me to test this weekend?
> Nikki.
> On 11 Apr 2013, at 18:33, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
>> I think I was a bit too fast on this, Nikki, don't use that version,
>> it seems to have some new bug causing frequent crashes... :-(
>> Am 11.04.2013 19:22, schrieb Michael Balzer:
>>> Mark, Nikki,
>>> I'm currently trying to fix a last bug with the power statistics
>>> (the distance counter still went wrong), and I'm trying to get the
>>> 12V A/D conversion to work without these strange "peaks" by raising
>>> the automatic acquisition time. I will finish testing this ASAP or
>>> tell you in time before sunday.
>>> Nikki, I attached the latest version in case you'd like to test as
>>> well.
>>> Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
>>>> China is bugging me for final firmware for the next batch of
>>>> hardware. I need to get them this early next week.
>>>> I've committed what I need for the Tesla Roadster (and framework).
>>>> Last outstanding small change to make is to send CAC as 999.99,
>>>> rather than the current 99999, using Tom's new library function.
>>>> Michael B & J: can you check Twizzy and Volt/Ampera, to see if
>>>> everything is ok with current firmware or there is anything you
>>>> need changed?
>>>> I plan to cut release candidate for 2.3.1 on Sunday.
>>>> Regards, Mark.
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130412/1683a8ab/attachment.htm>
Type: text/x-hex
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130412/1683a8ab/attachment-0002.bin>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130412/1683a8ab/attachment-0002.vcf>
