[Ovmsdev] Release Firmware
Nikki Gordon-Bloomfield
nikki at littlecollie.com
Fri Apr 12 23:01:04 HKT 2013
Michael,
Any new firmware for me to test this weekend?
Nikki.
On 11 Apr 2013, at 18:33, Michael Balzer <dexter at expeedo.de> wrote:
> I think I was a bit too fast on this, Nikki, don't use that version, it seems to have some new bug causing frequent crashes... :-(
> Am 11.04.2013 19:22, schrieb Michael Balzer:
>> Mark, Nikki,
>> I'm currently trying to fix a last bug with the power statistics (the distance counter still went wrong), and I'm trying to get the 12V A/D conversion to work without these strange "peaks" by raising the automatic acquisition time. I will finish testing this ASAP or tell you in time before sunday.
>> Nikki, I attached the latest version in case you'd like to test as well.
>> Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
>>> China is bugging me for final firmware for the next batch of hardware. I need to get them this early next week.
>>> I've committed what I need for the Tesla Roadster (and framework). Last outstanding small change to make is to send CAC as 999.99, rather than the current 99999, using Tom's new library function.
>>> Michael B & J: can you check Twizzy and Volt/Ampera, to see if everything is ok with current firmware or there is anything you need changed?
>>> I plan to cut release candidate for 2.3.1 on Sunday.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130412/d54878bd/attachment.htm>
