[Ovmsdev] Release Firmware
Sat Apr 13 02:51:41 HKT 2013
Mark,
I just checked in my latest changes.
In net.c I added the pending send check also to the new
net_notify_errorcode send, I think that should be correct, but please
have a look.
I saw the new stp_f() function, but I don't understand it's purpose yet.
What's the difference to my stp_l2f() function?
Btw: l2f = "long to float" -- I think "_f" should be reserved for an stp
call with a real float type parameter, if we once really need one.
Am 12.04.2013 20:16, schrieb Michael Balzer:
> Nikki,
> yes, see attachment.
> I could not make out any possible source of that strange error I had
> yesterday (completely garbled data).
> I made a clean build with a freshly started MPLAB and got no errors up
> to now.
> May have been something completely different, not related to my last
> changes.
> Am 12.04.2013 17:01, schrieb Nikki Gordon-Bloomfield:
>> Michael,
>> Any new firmware for me to test this weekend?
>> Nikki.
>> On 11 Apr 2013, at 18:33, Michael Balzer <dexter at expeedo.de
>>> I think I was a bit too fast on this, Nikki, don't use that version,
>>> it seems to have some new bug causing frequent crashes... :-(
>>> Am 11.04.2013 19:22, schrieb Michael Balzer:
>>>> Mark, Nikki,
>>>> I'm currently trying to fix a last bug with the power statistics
>>>> (the distance counter still went wrong), and I'm trying to get the
>>>> 12V A/D conversion to work without these strange "peaks" by raising
>>>> the automatic acquisition time. I will finish testing this ASAP or
>>>> tell you in time before sunday.
>>>> Nikki, I attached the latest version in case you'd like to test as
>>>> well.
>>>> Regards,
>>>> Michael
>>>> Am 11.04.2013 16:41, schrieb Mark Webb-Johnson:
>>>>> China is bugging me for final firmware for the next batch of
>>>>> hardware. I need to get them this early next week.
>>>>> I've committed what I need for the Tesla Roadster (and framework).
>>>>> Last outstanding small change to make is to send CAC as 999.99,
>>>>> rather than the current 99999, using Tom's new library function.
>>>>> Michael B & J: can you check Twizzy and Volt/Ampera, to see if
>>>>> everything is ok with current firmware or there is anything you
>>>>> need changed?
>>>>> I plan to cut release candidate for 2.3.1 on Sunday.
>>>>> Regards, Mark.
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130412/f81adc6d/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130412/f81adc6d/attachment-0002.vcf>
