[Ovmsdev] Cool down
    Tue Sep 11 09:58:22 HKT 2012
Following discussions on the tmc thread, I tried cooldown again last night, but this time using a range mode charge. I got:
RANGE MODE 220V 13A charge (try to cooldown):
Date/Time (HKT)            SOC% Units iRange eRange cLimit Current Voltage      State         Mode Duration      kWh  PH% State SubSt Mode  Tpem  Tmtr  Tess  Tamb Note
2012-09-10 05:55:30.741879   66     K    206    162     56       0      -1    stopped     standard       43        6  100    21     7    0    50    62    39    32
2012-09-10 06:02:58.344806   65     K    203    168     70       0     222   charging     standard        0        0  100     1     5    0    50    73    40    32 Start
2012-09-10 06:03:04.943447   65     K    203    168     70       0     223   charging     standard        0        0  100     1     5    0    43    79    40    30
2012-09-10 06:03:28.325184   62     K    245    202     13      13     221   charging        range        0        0  100     1     5    3    43    79    40    30
2012-09-10 06:03:43.102515   62     K    245    202     13      13     222   charging        range        0        0  100     1     5    3    44    78    40    30
2012-09-10 06:04:45.503092   62     K    245    202     13      13     220   charging        range        1        0  100     1     5    3    45    77    40    30
2012-09-10 06:05:44.383001   62     K    245    202     13      13     221   charging        range        2        0  100     1     5    3    47    75    40    30
2012-09-10 06:06:45.725419   62     K    245    202     13      13     222   charging        range        3        0  100     1     5    3    48    73    39    33
2012-09-10 06:07:45.300497   61     K    245    202     13      13     221   charging        range        4        0  100     1     5    3    48    71    38    36
2012-09-10 06:08:46.360142   62     K    245    202     13      13     222   charging        range        6        0  100     1     5    3    48    69    37    38
2012-09-10 06:09:46.635334   62     K    245    202     13      13     221   charging        range        7        0  100     1     5    3    48    67    37    38
2012-09-10 06:10:46.815447   62     K    245    202     13      13     222   charging        range        8        0  100     1     5    3    48    66    37    37
2012-09-10 06:11:47.534305   62     K    246    202     13      13     223   charging        range        9        0  100     1     5    3    48    64    38    37
2012-09-10 06:12:47.833010   62     K    246    202     13      13     221   charging        range       10        0  100     1     5    3    48    63    38    36
2012-09-10 06:13:48.414804   62     K    246    202     13      13     221   charging        range       11        1  100     1     5    3    48    62    38    35
2012-09-10 06:14:58.894398   62     K    246    202     13      13     222   charging        range       12        1  100     1     5    3    48    61    38    35
2012-09-10 06:15:51.651958   62     K    246    203     13      13     221   charging        range       13        1  100     1     5    3    48    60    37    37
2012-09-10 06:16:50.430951   62     K    246    203     13      13     222   charging        range       14        1  100     1     5    3    48    59    36    38
2012-09-10 06:17:51.930644   62     K    246    203     13      13     221   charging        range       15        1  100     1     5    3    48    58    36    37
2012-09-10 06:18:51.727193   62     K    246    203     13      13     221   charging        range       16        1  100     1     5    3    48    57    37    37
2012-09-10 06:19:52.649190   62     K    246    203     13      13     222   charging        range       17        1  100     1     5    3    48    57    37    36
2012-09-10 06:22:20.067095   62     K    248    203     13      13     221   charging        range       19        1  100     1     5    3    48    56    37    36
2012-09-10 06:22:57.925791   62     K    248    203     13      13     219   charging        range       20        1  100     1     5    3    48    54    36    37
2012-09-10 06:23:59.762348   62     K    248    203     13      13     221   charging        range       21        1  100     1     5    3    48    54    35    38
2012-09-10 06:24:59.243697   62     K    248    205     13      13     221   charging        range       22        1  100     1     5    3    48    53    36    37
2012-09-10 06:25:59.519488   62     K    248    205     13      13     220   charging        range       23        1  100     1     5    3    48    53    36    36
2012-09-10 06:27:00.160039   62     K    248    205     13      13     220   charging        range       24        1  100     1     5    3    48    53    36    36
2012-09-10 06:28:00.659713   62     K    248    205     13      13     219   charging        range       25        1  100     1     5    3    48    52    36    35
2012-09-10 06:29:01.017175   62     K    250    205     13      13     218   charging        range       26        1  100     1     5    3    48    52    36    35
2012-09-10 06:30:03.138729   62     K    250    205     13      13     220   charging        range       27        1  100     1     5    3    48    51    36    35
2012-09-10 06:31:02.695538   62     K    250    205     13      13     220   charging        range       28        1  100     1     5    3    48    51    35    37
2012-09-10 06:32:03.620632   62     K    250    205     13      13     218   charging        range       29        1  100     1     5    3    48    50    35    37
2012-09-10 06:33:03.051800   62     K    250    205     13      13     219   charging        range       30        1  100     1     5    3    48    50    35    36
2012-09-10 06:36:03.192658   63     K    250    205     13      13     220   charging        range       33        2  100     1     5    3    48    50    35    36
2012-09-10 06:46:02.283843   63     K    251    206     13      13     218   charging        range       43        2  100     1     5    3    48    49    35    35
2012-09-10 06:56:00.749721   63     K    253    208     13      13     219   charging        range       53        3  100     1     5    3    47    46    33    37
2012-09-10 07:05:23.720964   64     K    254    210     13      13     220   charging        range       62        3  100     1     5    3    47    44    33    35
2012-09-10 07:05:46.742630   64     K    254    210     13       0       4    stopped        range       62        3  100    21     3    3    47    43    33    34 Stopped
STANDARD MODE 220V 70A normal charge (for comparison):
2012-09-10 07:06:04.200639   64     K    254    210     13       0       2    stopped        range       62        3  100    21     3    3    47    43    33    34
2012-09-10 07:06:27.660741   68     K    213    176     56       0     220   charging     standard       62        3  100     1     5    0    43    43    33    34 Start
2012-09-10 07:16:08.911715   72     K    224    184     56      56     215   charging     standard       72        5  100     1     5    0    43    43    33    34
2012-09-10 07:19:12.947921   73     K    227    187     56      56     215   charging     standard       75        5  100     1     5    0    55    42    32    34
2012-09-10 07:26:09.323317   75     K    237    195     70      70     214   charging     standard       82        7  100     1     5    0    56    41    32    34
2012-09-10 07:36:07.932734   80     K    251    206     70      70     215   charging     standard       92       10  100     1     5    0    59    41    31    35
2012-09-10 07:46:06.080087   84     K    266    218     70      70     213   charging     standard      102       12  100     1     5    0    60    41    31    34
2012-09-10 07:56:05.788377   88     K    278    229     70      59     216   charging     standard      112       14  100     1     5    0    60    41    32    32
2012-09-10 08:06:03.019474   91     K    288    237     70      45     216   charging     standard      122       16  100     1     5    0    59    41    32    32
2012-09-10 08:16:01.730535   94     K    296    243     70      34     220   charging     standard      132       18  100     1     5    0    56    40    32    31
2012-09-10 08:25:59.598007   95     K    301    248     70      26     221   charging     standard      142       19  100     1     5    0    53    40    32    31
2012-09-10 08:35:58.987523   96     K    304    250     70       0       1       done     standard      146       19  100     4     9    0    50    40    31    31 Done
Ambient temperature was 32celcius, at the start, but rose during the charge (car was at the front of the garage, in the open air, and it was evening) - and this makes little sense unless the aircon is blowing hot air over the ambient temperature sensor (go figure...).
ESS was at 40 celcius, and had dropped to 35 celcius after around 20 minutes. It then took another 33 minutes to get it to drop 2 more degrees.
ESS temperature didn't change much during the 70amp charge.
So, on this sample of 1 it does appear that a RANGE mode charge at low amperages can cool the battery down. I'll try again tonight...
If anyone else is in a very hot climate (or can drive the ESS temperature up into the 40Celcius or above), please try the same (range mode charge, low amperage) and let me know the time you did it and your vehicle ID. It is helpful if you can leave a smartphone app on and connected during the cooldown period (so we get reports every 1 minute, rather than the usual 10 minutes).
On 28 Jun, 2012, at 11:14 AM, Bennett Leeds wrote:
> I've been doing 220volt 15 amp charging to cool the battery. Like Tom, I manually stop it when the battery temp reaches 80F. Like Mark, I found that low amp charges didn't cool the battery as much - I'll speculate that Tesla probably sees the low amperage and figures that it can't waste as much juice cooling the battery, and that a slow charge won't really heat it up much.
> Have you thought about parameters for the CoolDown function?
> - Desired End Temperature
> - Amperage to Use
> - Maximum length of time to run
> Also, have you considered an "Auto" feature, where when OVMS sees the car is plugged-in but not charging and that the battery temp is high, automatically kicks on to cool it? The max run time parameter is kind of a safety feature to avoid running too long at high prices.
> - Bennett
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120911/745b0006/attachment.htm>
