[Ovmsdev] Open Vehicle 1.3.0 (20120919)
Karin Aeschlimann
aeschlimann.karin at bluewin.ch
Sat Sep 29 16:05:12 HKT 2012
hi mark
would you mind adding piotr's iphone 5 to the test flight? thanks!
Von meinem iPhone gesendet
Am 29.09.2012 um 09:32 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> This seems to be intermittently working. My best guess is still the weather API we use is experiencing sunspots.
> I've just released 1.3.1 containing this sunspot fix, to TestFlightApp. It would be helpful if the testers on that system could deploy this to see if it resolves your problems.
> On 29 Sep, 2012, at 2:27 PM, 911carrera4 <911carrera4 at bluewin.ch> wrote:
>> Mark
>> I have the iphone5 now (;-)) working with ios6. Ovms got an update via apple store prior to this and now ovms app crashes while starting. Rebooting didn’t work.
>> Do I have to register the new iphone to the testflight app?
>> Piotr
>> Von: ovmsdev-bounces at lists.teslaclub.hk [mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Webb-Johnson
>> Gesendet: Samstag, 29. September 2012 02:06
>> An: OVMS Developers
>> Betreff: Re: [Ovmsdev] Open Vehicle 1.3.0 (20120919)
>> Jack,
>> Based on the testflightapp logs, I think your sunspot comment was not far off. The app was not correctly validating the response from the weather api we use, and strange responses were causing the crash.
>> I have created github issue #5 (Sunspot activity) to track this, and fixed it in the code. I think this was a problem with the weather service itself, that has now been fixed, so no urgency for a release. I'll keep monitoring, and let me know if you see this again.
>> On 29 Sep, 2012, at 3:37 AM, Jack West <jackduncanwest at gmail.com> wrote:
>> All seems OK today on both iPad and iPhone. I tried before rebooting and it worked right off. Maybe there were sun spots?
>> Jack
>> On Sep 27, 2012, at 11:39 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> Jack,
>> I just had that on my phone as well. Something strange on the networking I guess.
>> I rebooted my phone, and it seems fine since. Can you try to reboot your phone again, and let me know if it is still happening?
>> Testflightapp is showing some crashes captured, and I can see roughly where the problem is. It looks like something in the initial handshaking is coming over the wire badly formatted. I'll have a look at it tonight.
>> P.S. Testflightapp is the most amazing system. Real-time analysis of stuff like this...
>> On 28 Sep, 2012, at 3:29 PM, Jack West <jackduncanwest at gmail.com> wrote:
>> Mark,
>> I'm having trouble with the app in my iPad 2. When I open OVMS the app opens momentarily and then quits and drops back to my home screen. My iPad was updated to IOS6 a couple days ago and I just updated the app to the latest from the App Store. I rebooted but no luck.
>> Just tried on my iPhone 4 with iOS5 and same result. The data that I do see before it quits looks current.
>> Ideas?
>> Jack
>> On Sep 19, 2012, at 4:39 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> This fixes everything we know about in the iOS App and is now going to Apple for approval.
>> <Icon.png>
>> Team: Open Vehicles
>> What's New:
>> 1.3.0 (20120919)
>> - Minor bug fixes
>> - Temperature Options in Settings App
>> - #1 Support for iOS 6, iPhone 5 and Xcode 4.5
>> - #2 Temperature issue - Fahrenheit showed before data is loaded
>> - #3 Support for Adaptive Reporting
>> - #4 iPad startup landscape orientation map is wrong
>> Released: September 19, 2012
>> Expires In: 2 months, 1 week
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120929/a6ec8c57/attachment.html>
