[Ovmsdev] Open Vehicle 1.3.0 (20120919)
Sat Sep 29 20:22:54 HKT 2012
I'll get it added for the next build.
On 29 Sep, 2012, at 4:05 PM, Karin Aeschlimann <aeschlimann.karin at bluewin.ch> wrote:
> hi mark
> would you mind adding piotr's iphone 5 to the test flight? thanks!
> Von meinem iPhone gesendet
> Am 29.09.2012 um 09:32 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>> This seems to be intermittently working. My best guess is still the weather API we use is experiencing sunspots.
>> I've just released 1.3.1 containing this sunspot fix, to TestFlightApp. It would be helpful if the testers on that system could deploy this to see if it resolves your problems.
>> On 29 Sep, 2012, at 2:27 PM, 911carrera4 <911carrera4 at bluewin.ch> wrote:
>>> Mark
>>> I have the iphone5 now (;-)) working with ios6. Ovms got an update via apple store prior to this and now ovms app crashes while starting. Rebooting didn’t work.
>>> Do I have to register the new iphone to the testflight app?
>>> Piotr
>>> Von: ovmsdev-bounces at lists.teslaclub.hk [mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Webb-Johnson
>>> Gesendet: Samstag, 29. September 2012 02:06
>>> An: OVMS Developers
>>> Betreff: Re: [Ovmsdev] Open Vehicle 1.3.0 (20120919)
>>> Jack,
>>> Based on the testflightapp logs, I think your sunspot comment was not far off. The app was not correctly validating the response from the weather api we use, and strange responses were causing the crash.
>>> I have created github issue #5 (Sunspot activity) to track this, and fixed it in the code. I think this was a problem with the weather service itself, that has now been fixed, so no urgency for a release. I'll keep monitoring, and let me know if you see this again.
>>> On 29 Sep, 2012, at 3:37 AM, Jack West <jackduncanwest at gmail.com> wrote:
>>> All seems OK today on both iPad and iPhone. I tried before rebooting and it worked right off. Maybe there were sun spots?
>>> Jack
>>> On Sep 27, 2012, at 11:39 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> Jack,
>>> I just had that on my phone as well. Something strange on the networking I guess.
>>> I rebooted my phone, and it seems fine since. Can you try to reboot your phone again, and let me know if it is still happening?
>>> Testflightapp is showing some crashes captured, and I can see roughly where the problem is. It looks like something in the initial handshaking is coming over the wire badly formatted. I'll have a look at it tonight.
>>> P.S. Testflightapp is the most amazing system. Real-time analysis of stuff like this...
>>> On 28 Sep, 2012, at 3:29 PM, Jack West <jackduncanwest at gmail.com> wrote:
>>> Mark,
>>> I'm having trouble with the app in my iPad 2. When I open OVMS the app opens momentarily and then quits and drops back to my home screen. My iPad was updated to IOS6 a couple days ago and I just updated the app to the latest from the App Store. I rebooted but no luck.
>>> Just tried on my iPhone 4 with iOS5 and same result. The data that I do see before it quits looks current.
>>> Ideas?
>>> Jack
>>> On Sep 19, 2012, at 4:39 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> This fixes everything we know about in the iOS App and is now going to Apple for approval.
>>> <Icon.png>
>>> Team: Open Vehicles
>>> What's New:
>>> 1.3.0 (20120919)
>>> - Minor bug fixes
>>> - Temperature Options in Settings App
>>> - #1 Support for iOS 6, iPhone 5 and Xcode 4.5
>>> - #2 Temperature issue - Fahrenheit showed before data is loaded
>>> - #3 Support for Adaptive Reporting
>>> - #4 iPad startup landscape orientation map is wrong
>>> Released: September 19, 2012
>>> Expires In: 2 months, 1 week
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120929/08f63743/attachment-0001.html>
