[Ovmsdev] Open Vehicle 1.3.0 (20120919)
Sat Sep 29 15:32:12 HKT 2012
This seems to be intermittently working. My best guess is still the weather API we use is experiencing sunspots.
I've just released 1.3.1 containing this sunspot fix, to TestFlightApp. It would be helpful if the testers on that system could deploy this to see if it resolves your problems.
On 29 Sep, 2012, at 2:27 PM, 911carrera4 <911carrera4 at bluewin.ch> wrote:
> Mark
> I have the iphone5 now (;-)) working with ios6. Ovms got an update via apple store prior to this and now ovms app crashes while starting. Rebooting didn’t work.
> Do I have to register the new iphone to the testflight app?
> Piotr
> Von: ovmsdev-bounces at lists.teslaclub.hk [mailto:ovmsdev-bounces at lists.teslaclub.hk] Im Auftrag von Mark Webb-Johnson
> Gesendet: Samstag, 29. September 2012 02:06
> An: OVMS Developers
> Betreff: Re: [Ovmsdev] Open Vehicle 1.3.0 (20120919)
> Jack,
> Based on the testflightapp logs, I think your sunspot comment was not far off. The app was not correctly validating the response from the weather api we use, and strange responses were causing the crash.
> I have created github issue #5 (Sunspot activity) to track this, and fixed it in the code. I think this was a problem with the weather service itself, that has now been fixed, so no urgency for a release. I'll keep monitoring, and let me know if you see this again.
> On 29 Sep, 2012, at 3:37 AM, Jack West <jackduncanwest at gmail.com> wrote:
> All seems OK today on both iPad and iPhone. I tried before rebooting and it worked right off. Maybe there were sun spots?
> Jack
> On Sep 27, 2012, at 11:39 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Jack,
> I just had that on my phone as well. Something strange on the networking I guess.
> I rebooted my phone, and it seems fine since. Can you try to reboot your phone again, and let me know if it is still happening?
> Testflightapp is showing some crashes captured, and I can see roughly where the problem is. It looks like something in the initial handshaking is coming over the wire badly formatted. I'll have a look at it tonight.
> P.S. Testflightapp is the most amazing system. Real-time analysis of stuff like this...
> On 28 Sep, 2012, at 3:29 PM, Jack West <jackduncanwest at gmail.com> wrote:
> Mark,
> I'm having trouble with the app in my iPad 2. When I open OVMS the app opens momentarily and then quits and drops back to my home screen. My iPad was updated to IOS6 a couple days ago and I just updated the app to the latest from the App Store. I rebooted but no luck.
> Just tried on my iPhone 4 with iOS5 and same result. The data that I do see before it quits looks current.
> Ideas?
> Jack
> On Sep 19, 2012, at 4:39 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> This fixes everything we know about in the iOS App and is now going to Apple for approval.
> <Icon.png>
> Team: Open Vehicles
> What's New:
> 1.3.0 (20120919)
> - Minor bug fixes
> - Temperature Options in Settings App
> - #1 Support for iOS 6, iPhone 5 and Xcode 4.5
> - #2 Temperature issue - Fahrenheit showed before data is loaded
> - #3 Support for Adaptive Reporting
> - #4 iPad startup landscape orientation map is wrong
> Released: September 19, 2012
> Expires In: 2 months, 1 week
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120929/4a76c81a/attachment-0001.html>
