[Ovmsdev] Merging in Twizy and Volt/Ampera work
Thu Nov 22 03:10:48 HKT 2012
Mark,
that shed some light, thanks.
It now seems it was not a bug but a combination of a) my poor garage
GPRS connectivity, b) the MSG protocol and/or App not allowing for "\n"
within alert text and c) me not remembering to put the App to background
in time so the notification would really be displayed by Android.
So, everything's working now, I get the same alerts from the App now as
via SMS :-)
https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commits/v2
Regarding cr2lf(): I think it would be nice if we could just use one
kind of line break throughout all texts without having to recode them
according to the transport. I thought about modifying the transport
layer functions to recode text accordingly, but that's quite lowlevel,
so I now introduced this utility as a workaround. Maybe we can eliminate
that later.
Am 21.11.2012 02:38, schrieb Mark Webb-Johnson:
> Michael,
> Server logs for PUSH notifications:
>     2012-11-20 14:52:21.050617 -0500 info  main: #37 C DEXZE85 rx msg
>     P ACharging, Topping off
>     2012-11-20 14:56:13.216180 -0500 info  main: #37 C DEXZE85 rx msg
>     2012-11-20 15:28:37.549081 -0500 info  main: #37 C DEXZE85 rx msg
>     2012-11-20 15:40:48.776406 -0500 info  main: #80 C DEXZE85 rx msg
>     P ACharging, Topping off Range: 46 - 66 km SOC: 83% (8194 - 8302)
>     ODO: 3730 Km
>     2012-11-20 16:00:15.659214 -0500 info  main: #53 C DEXZE85 rx msg
>     P ACharging, Topping off Range: 51 - 74 km SOC: 93% (8696 - 9304)
>     ODO: 3730 Km
> Times are EST.
> On 21 Nov, 2012, at 5:25 AM, Michael Balzer wrote:
>> Am 20.11.2012 20:47, schrieb Michael Balzer:
>>> I'm currently charging my Twizy to see if the alert is functional now.
>> Ok, this is getting strange now... everything else works, calling cmd
>> 6 in diag mode, SMS alerts etc., just the App wouldn't alert me. I
>> found a "PA" entry in the Apps "TCP log" output that was cut down to
>> the charge state line, so I thought maybe it's the "\r\n" I had put
>> into the alert text to structure it.
>> I removed all of the line breaks and the first two alerts again did
>> not come through to the App -- but the third one just did, in perfect
>> shape!?
>> But for that one I now do not find any TCP log entry... is the
>> Android App reliable concerning the TCP log function?
>> Mark, I'm stuck. Could you please check the server log for this?
>> Vehicle name now is "DEXZE85".
>> Thanks,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121121/55171e8b/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121121/55171e8b/attachment-0002.vcf>
