[Ovmsdev] Merging in Twizy and Volt/Ampera work
Wed Nov 21 09:38:29 HKT 2012
Michael,
Server logs for PUSH notifications:
2012-11-20 14:52:21.050617 -0500 info  main: #37 C DEXZE85 rx msg P ACharging, Topping off
2012-11-20 14:56:13.216180 -0500 info  main: #37 C DEXZE85 rx msg P ACharging, Topping off
2012-11-20 15:28:37.549081 -0500 info  main: #37 C DEXZE85 rx msg P ACharging, Topping off
2012-11-20 15:40:48.776406 -0500 info  main: #80 C DEXZE85 rx msg P ACharging, Topping off Range: 46 - 66 km SOC: 83% (8194 - 8302) ODO: 3730 Km
2012-11-20 16:00:15.659214 -0500 info  main: #53 C DEXZE85 rx msg P ACharging, Topping off Range: 51 - 74 km SOC: 93% (8696 - 9304) ODO: 3730 Km
Times are EST.
On 21 Nov, 2012, at 5:25 AM, Michael Balzer wrote:
> Am 20.11.2012 20:47, schrieb Michael Balzer:
>> I'm currently charging my Twizy to see if the alert is functional now.
> Ok, this is getting strange now... everything else works, calling cmd 6 in diag mode, SMS alerts etc., just the App wouldn't alert me. I found a "PA" entry in the Apps "TCP log" output that was cut down to the charge state line, so I thought maybe it's the "\r\n" I had put into the alert text to structure it.
> I removed all of the line breaks and the first two alerts again did not come through to the App -- but the third one just did, in perfect shape!?
> But for that one I now do not find any TCP log entry... is the Android App reliable concerning the TCP log function?
> Mark, I'm stuck. Could you please check the server log for this? Vehicle name now is "DEXZE85".
> Thanks,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121121/69265971/attachment.htm>
