[Ovmsdev] Twizy / 500 kbps CAN lockups
mikeljo at me.com
mikeljo at me.com
Sat Nov 3 07:30:22 HKT 2012
Hi Michael,
nice to see you here.
The Volt/Ampera has 500 kbps too.
i only change this:
// BRGCON1 = 0; // SET BAUDRATE to 1 Mbps
BRGCON1 = 0x01; // SET BAUDRATE to 500 Kbps
BRGCON2 = 0xD2;
BRGCON3 = 0x02;
And it works. I think i must recalculate, but it works. ;-)
Mark check the Logs from my car and it looks good.
Bye
PS: Bin aus Kaiserslautern. Warst du am Samstag in Wuppertal?
Am 02.11.2012 um 20:54 schrieb Michael Balzer <dexter at expeedo.de>:
> During my tests I had two times some sort of a CAN lockup, i.e. everything worked except the CAN reception -- was fixed by switching the car off + on.
> I'm not sure yet what caused that, it (of course) did not happen again since I included a first debug output of the RXERRCNT...
> I saw the 1 mbps setup does not follow the intrepid timing calculator standard parameters but increases prop delay from 1 to 3 and decreases phase 1 from 5 to 3.
> A similar change to the 500 kbps parameters though did not work with the Twizy.
> Do you have any hints on debugging this?
> My current setup for 500 kbps is:
> // 500 kbps -- tool recommendation + multisampling:
> BRGCON1 = 0x00;
> BRGCON2 = 0xFA;
> BRGCON3 = 0x07;
> Thanks,
