[Ovmsdev] Twizy / 500 kbps CAN lockups
Sat Nov 3 03:54:03 HKT 2012
During my tests I had two times some sort of a CAN lockup, i.e.
everything worked except the CAN reception -- was fixed by switching the
car off + on.
I'm not sure yet what caused that, it (of course) did not happen again
since I included a first debug output of the RXERRCNT...
I saw the 1 mbps setup does not follow the intrepid timing calculator
standard parameters but increases prop delay from 1 to 3 and decreases
phase 1 from 5 to 3.
A similar change to the 500 kbps parameters though did not work with the
Twizy.
Do you have any hints on debugging this?
My current setup for 500 kbps is:
// 500 kbps -- tool recommendation + multisampling:
BRGCON1 = 0x00;
BRGCON2 = 0xFA;
BRGCON3 = 0x07;
Thanks,
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121102/8b9ed48d/attachment-0002.vcf>
