[Ovmsdev] Merging in Twizy and Volt/Ampera work
Wed Nov 21 03:47:35 HKT 2012
Mark,
I did some debugging but I did not find the bug yet -- if it is one. I
now assume it's because the module had to reset the gprs connection due
to my weak connectivity situation, just when I had requested the SMS. So
the "AT+CIPSHUT" from the net state change just happened to get into the
SMS. Does that make sense?
My debug session resulted in some more changes, pls have a look:
https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/9eaa71c1e6ccae21cf9dcfe8fd8a4e22666830ba
The extension of the diag mode to call MSG commands as well was an
attempt to produce the bug, but I find it also quite useful for other
debugs and for pre-provisioning the module. That also led to the
can_capabilities type change.
I'm currently charging my Twizy to see if the alert is functional now.
Am 19.11.2012 22:08, schrieb Michael Balzer:
> My test just showed I've implemented a bug as well ;-): I now
> occasionally get SMS replies containing "AT+CIPSHUT" instead of the
> last character of the message, so somehow the buffers seem to get
> confused.
> It's late, I'll debug tomorrow.
> Am 19.11.2012 20:52, schrieb Michael Balzer:
>> Mark,
>> I've implemented it, please review:
>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/70b770fff2268c84100a0bef30965f1c0cd58106
>> I have included the necessary changes to the framework, as there are few.
>> As both charge alerts are the same now I could also factor out the
>> text preparation, saving some ROM space. I intend to reuse the other
>> command functions as well, if the parameters can use the same syntax
>> I can just switch the argument separator char.
>> Am 19.11.2012 19:40, schrieb Michael Balzer:
>>> Mark,
>>> Am 19.11.2012 14:34, schrieb Mark Webb-Johnson:
>>>>> ...plus a new common code for "ALERT", if you agree on routing the
>>>>> net_msg_alert() function through the dispatcher as well to allow
>>>>> vehicle control over this.
>>>> Can you explain more what you require here?
>>> I would like to change the text for charge alerts to the App the
>>> same way I did with the SMS alerts, especially to get the SOC
>>> min/max and odometer.
>>> So I would basically overload net_msg_alert() with my vehicle
>>> specific version. That will require either a specific hook for just
>>> this function, or -- my suggestion -- the introduction of a msg
>>> command "ALERT", so the existing cmd overloading framework can
>>> simply be used. I tend to the cmd solution because that's nice in
>>> line with the SMS way. I know the command now would not be needed by
>>> the Apps, but it wouldn't hurt either.
>>> So instead of calling net_msg_alert() directly (which happens only
>>> at one place now), we would call net_msg_cmd_do() with i.e.
>>> net_msg_cmd_code=NET_CMD_ALERT and let the net and vehicle
>>> dispatchers decide which alert function to execute. May sound a bit
>>> complicated first, but would IMO also provide clean and clear
>>> extendability for maybe other future notifications sent from the
>>> module to the App.
>>> I can prepare a Twizy implementation of this if you like to have a
>>> look at the application side first.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121120/1df8d072/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121120/1df8d072/attachment.vcf>
