[Ovmsdev] Merging in Twizy and Volt/Ampera work
Tue Nov 20 05:08:29 HKT 2012
My test just showed I've implemented a bug as well ;-): I now
occasionally get SMS replies containing "AT+CIPSHUT" instead of the last
character of the message, so somehow the buffers seem to get confused.
It's late, I'll debug tomorrow.
Am 19.11.2012 20:52, schrieb Michael Balzer:
> Mark,
> I've implemented it, please review:
> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/70b770fff2268c84100a0bef30965f1c0cd58106
> I have included the necessary changes to the framework, as there are few.
> As both charge alerts are the same now I could also factor out the
> text preparation, saving some ROM space. I intend to reuse the other
> command functions as well, if the parameters can use the same syntax I
> can just switch the argument separator char.
> Am 19.11.2012 19:40, schrieb Michael Balzer:
>> Mark,
>> Am 19.11.2012 14:34, schrieb Mark Webb-Johnson:
>>>> ...plus a new common code for "ALERT", if you agree on routing the
>>>> net_msg_alert() function through the dispatcher as well to allow
>>>> vehicle control over this.
>>> Can you explain more what you require here?
>> I would like to change the text for charge alerts to the App the same
>> way I did with the SMS alerts, especially to get the SOC min/max and
>> odometer.
>> So I would basically overload net_msg_alert() with my vehicle
>> specific version. That will require either a specific hook for just
>> this function, or -- my suggestion -- the introduction of a msg
>> command "ALERT", so the existing cmd overloading framework can simply
>> be used. I tend to the cmd solution because that's nice in line with
>> the SMS way. I know the command now would not be needed by the Apps,
>> but it wouldn't hurt either.
>> So instead of calling net_msg_alert() directly (which happens only at
>> one place now), we would call net_msg_cmd_do() with i.e.
>> net_msg_cmd_code=NET_CMD_ALERT and let the net and vehicle
>> dispatchers decide which alert function to execute. May sound a bit
>> complicated first, but would IMO also provide clean and clear
>> extendability for maybe other future notifications sent from the
>> module to the App.
>> I can prepare a Twizy implementation of this if you like to have a
>> look at the application side first.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121119/0e469c96/attachment-0001.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121119/0e469c96/attachment-0001.vcf>
