[Ovmsdev] Merging in Twizy and Volt/Ampera work
Tue Nov 20 03:52:43 HKT 2012
Mark,
I've implemented it, please review:
https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/70b770fff2268c84100a0bef30965f1c0cd58106
I have included the necessary changes to the framework, as there are few.
As both charge alerts are the same now I could also factor out the text
preparation, saving some ROM space. I intend to reuse the other command
functions as well, if the parameters can use the same syntax I can just
switch the argument separator char.
Am 19.11.2012 19:40, schrieb Michael Balzer:
> Mark,
> Am 19.11.2012 14:34, schrieb Mark Webb-Johnson:
>>> ...plus a new common code for "ALERT", if you agree on routing the
>>> net_msg_alert() function through the dispatcher as well to allow
>>> vehicle control over this.
>> Can you explain more what you require here?
> I would like to change the text for charge alerts to the App the same
> way I did with the SMS alerts, especially to get the SOC min/max and
> odometer.
> So I would basically overload net_msg_alert() with my vehicle specific
> version. That will require either a specific hook for just this
> function, or -- my suggestion -- the introduction of a msg command
> "ALERT", so the existing cmd overloading framework can simply be used.
> I tend to the cmd solution because that's nice in line with the SMS
> way. I know the command now would not be needed by the Apps, but it
> wouldn't hurt either.
> So instead of calling net_msg_alert() directly (which happens only at
> one place now), we would call net_msg_cmd_do() with i.e.
> net_msg_cmd_code=NET_CMD_ALERT and let the net and vehicle dispatchers
> decide which alert function to execute. May sound a bit complicated
> first, but would IMO also provide clean and clear extendability for
> maybe other future notifications sent from the module to the App.
> I can prepare a Twizy implementation of this if you like to have a
> look at the application side first.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121119/72d49fc1/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121119/72d49fc1/attachment.vcf>
