[Ovmsdev] Car firmware v1.2.7
William Petefish william.petefish at gmail.com
Mon May 28 07:25:07 HKT 2012
The homelink works. I've done the testing of the other commands too. They
work.
William
On Sun, May 27, 2012 at 7:58 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
> Inching towards the v1.3.0 release, I've just committed to github v1.2.7
> of the car firmware for OVMS.
> Changelog since v1.2.2 is:
> 2012-05-27 1.2.7       Preliminary firmware 1.2.7
>                        Bug fix for off-by-one-can-byte bug in roadster id
> from VIN
>                        Add homelink and charge timer support, plus misc
> fixes
>                        Only send non-empty params to PARAMS? sms command
>                        Remove need to RESET after can write change
>                        Only NETINIT (not SOFTRESET) after a parameter
> change
>                        Re-label parameters internally to match new
> user-friendly names
>                        Re-work of sms command handlers to be table driven
> - saving 6% of flash
>                        Use the 6% of flash we saved to implement a bunch
> of SMS commands
>                          REGISTER?                                  Report
> on registered phone
>                          REGISTER <modulepass>
>  Register caller phone
>                          PASS?                                      Report
> on module password
>                          PASS     <modulepass>                      Set
> new module password
>                          GPS?/GPS [<modulepass>]                    Report
> GPS location
>                          STAT?/STAT [<modulepass>]                  Report
> status
>                          PARAMS? [<modulepass>]                     Report
> on parameters
>                          PARAMS <param2> <param3> .. <paramN>       Set
> parameters
>                          MODULE? [<modulepass>]                     Report
> on module parameters
>                          MODULE <vehicleid> <units> <notifies>      Set
> module parameters
>                          GPRS? [<modulepass>]                       Report
> on GPRS parameters and status
>                          GPRS <gprsapn> <gprsuser> <gprspass>       Set
> GPRS parameters
>                          SERVER? [<modulepass>]                     Report
> on server parameters
>                          SERVER <serverip> <serverpass> <paranoid>  Set
> server parameters
>                          DIAG?/DIAG [<modulepass>]
>  Technical diagnostics
>                          FEATURES? [<modulepass>]                   Report
> on features configured
>                          FEATURE <feature> <value>                  Set
> specified feature value
>                          HOMELINK <button>
>  Activate homelink 0, 1 or 2
>                          LOCK <pin>                                 Lock
> car (with specified pin)
>                          UNLOCK <pin>                               Unlock
>                          VALET <pin>
>  Activate valet mode (with specified pin)
>                          UNVALET <pin>
>  Deactivate valet mode (with specified pin)
>                          CHARGEMODE <mode> <current>                Set
> charge mode (sta, sto, ran, per) and current
>                          CHARGESTART [<modulepass>]                 Start
> charge immediately
>                          CHARGESTOP [<modulepass>]                  Stop
> charge immediately
>                          VERSION [<modulepass>]                     Report
> module firmware version
>                          RESET [<modulepass>]                       Reset
> module
> 2012-05-11 1.2.5       Preliminary firmware 1.2.5
>                        LED re-work
>                        Support multiple vehicle configurations -
> TeslaRoadster and VoltAmpera
>                        NET driver tidy-ups
>                        Auto-support Tesla Roadster v1.5 cars
>                        Issue #38 - Prevent user from locking car if car is
> ON
>                        Issue #39 - Alert (SMS/PUSH) if trunk is opened
> while in valet mode
> I've managed to do this with very little impact to firmware size.
> Major user-visible extensions in this firmware include:
>    - A huge number of new SMS commands.
>    - Support for simplified setup steps (working on with Bennett).
>    - New status and error LED arrangement.
>    - New diagnostic SMS commands.
>    - Various minor bug-fixes and improvements.
>    - Homelink support (firmware both SMS and app protocol support - app
>    support will follow).
>    - Charge timer support (firmware and app protocol support - app and
>    sms support will follow).
> This is a major re-work of the SMS sub-system. We now have 27 commands and
> similar functionality to the GPRS smartphone apps. In particular, charge
> start/stop and mode setting is now available.
> I've also added in the homelink commands (courtesy of Fuzzylogic's CAN
> decoding skills).
> I've tested this on the bench, and it seems to work. I've also put it in
> my car 10 minutes ago, and got a network connection. That is pretty much
> the extent of my testing, so consider this pre-beta and definitely NOT for
> end-users.
> I haven't completely tested the setup of a module from scratch with these
> new REGISTER, PASS, MODULE, SERVER, GPRS commands - I hope Bennett, or
> someone else, will help with that.
> I haven't tested homelink support. I hope someone will try that (using SMS
> "HOMELINK 0" command) and let me know if it works.
> This is now pretty feature complete for the v1.3.0 firmware. I need to do
> the CHARGETIMER SMS commands, and want to re-work the social group messages
> to allow streaming of group location messages (if enabled). So, please test
> this as you can, and let me know any problems you find.
> Again, please don't put this on end-user cars yet. There has been a lot go
> into this and I need a week or so of inevitable bug fixing before it is
> ready for wider testing. There hasn't been much changes to the net
> subsystem since 1.2.5, and that seem stable, so I think it is fine to put
> in developer's cars.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120527/800a15df/attachment.htm>
