[Ovmsdev] Digital Speedometer
    Mark Ramakers
    MRamakers at talpa.tv
    Thu Mar 15 16:42:09 HKT 2012
Brilliant!! Works perfect! Would be even 100% is we could change AMPS into KMH!
Verstuurd vanaf mijn Iphone
Op 14 mrt. 2012 om 13:33 heeft "Mark Webb-Johnson" <mark at webb-johnson.net<mailto:mark at webb-johnson.net>> het volgende geschreven:
Mark,
How do you turn it on ?
First, you need to ensure you are running an EXPERIMENTAL build (one built with the experimental config, not production). That will make sure the appropriate code is included.
Then, after plugging the module into the car, use the Apps to set feature #0 to value 5, or SMS "FEATURE 0 5" to enable it. That will set aggressiveness factor #5.
This video shows what to expect:
http://www.youtube.com/watch?v=C0gKzCigXhs
Our description of this (in the code) covers most of the bases:
// The OVMS_SPEEDO_EXPERIMENT switch is a highly experimental feature to
// change the dashboard Amps display in the Tesla Roadster to show speed.
// Please take extreme care with this and consider it extremely experimental -
// use at your own risk. The feature can transmit a lot of messages on the bus
// and is spoofing the car message. We can't see any affect (and we've even put
// an analyser on at the same time to see if any errors come up - they don't),
// but it is very intrusive to the car. One concern we have is if the car is
// using that message for anything else (but we can't see how it would as it
// also contains data for the battery level display, estimated miles, etc -
// it seems very very specific to that dashboard display).
// We really don't want anyone breaking their cars with this.
//#define OVMS_SPEEDO_EXPERIMENT
On 14 Mar, 2012, at 5:50 PM, Mark Ramakers wrote:
How do you turn it on ? Under the features list in the App this option is
listed in 1st position ? If I turn this option on does it show the digital
speedo then in the App ?
On 14-03-12 10:10, "Mark Webb-Johnson" <mark at webb-johnson.net<mailto:mark at webb-johnson.net>> wrote:
A while ago, I had to turn off the digital speedometer in my car as I had
some issues that I wanted to be sure it wasn't causing. It turned out to
be completely unrelated and caused by a faulty PEM. Since replacement of
the PEM, things have been perfect.
I've now been running the digital speedo on (setting 5) for the past 3
weeks and it had been flawless.
Is anyone else running this feature? If so, have you seen any issues and
what is your opinion? Anyone else brave enough |-)
Mark Ramakers
CFO
Talpa Holding N.V.
Zevenend 45 - 1251 RL Laren
P.O. Box 154 - 1250 AD Laren
The Netherlands
T +31 35 53 33 553
E MRamakers at talpa.tv<mailto:MRamakers at talpa.tv>
W http://www.talpa.tv
Chamber of commerce registration number 32083875
Talpa Holding is part of the Talpa Group
The information contained in this communication is confidential and may be legally privileged. It is intended solely for the use of the individual or entity to whom it is addressed and others authorised to receive it. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or taking any action in relation to the contents of this information is strictly prohibited and may be unlawful. Neither the sender nor the represented institution are liable for the correct and complete transmission of the contents of an e-mail, or for its timely receipt.
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk<mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120315/faf59dee/attachment.htm>
