[Ovmsdev] 1.2.0 Release Candidate
Michael Stegen
michael at stegen.com
Tue Feb 14 07:57:00 HKT 2012
Hi Mark,
Havent found any bugs yet.. Looking good so far.
It was a bit weird not to get a SMS after the charge finished, but then
i realized this is how it's suppposed to be.
One small thing, i received push messages , and the time displayed is 24:53
shoudn't this be 00:53?
Tomorrow i will drive around a bit, and do some more testing
-Michael
Op 13-2-2012 2:57, OVMS Developers schreef:
> Dear Developers,
> We finally have a feature complete release candidate for the OVMS
> software. At this stage, we would like to get this deployed to as many
> cars as possible to work out any final bugs.
> This release candidate is version 1.2.0-rc3, and you can find it on
> github in the master branch.
> To upgrade your car to this version, just flash the firmware as normal
> (remember to set the flags to preserve EEPROM or you'll have to reset
> the parameters - the experimental config has these flags set correctly
> for upgrades).
> There are two changes that might impact you:
> 1. This version has support for the GSM-only/GPRS-enable switch on
> the PIC board, so please take care with this. You will need the
> switch OFF in order to get GPRS connectivity. If you see the usual
> red-green alternating LED sequence then a solid green without any
> red light blinking, the switch is probably in the wrong position
> (you should try it in the other position, then reset the module).
> 2. This version re-works the old compile-time #define statements to
> be run-time FEATURE settings. The only one important is the WRITE
> enabled can bus, which is feature #15. To enable this feature,
> send a SMS to the car (from your registered phone) "FEATURE 15 1",
> and then reboot the module.
> Compared to the v1.0 firmware, there are a huge number of enhancements
> in v1.2. The biggest of these are:
> * FEATURES (write-enabled CAN bus, location streaming, minimum SOC
> alerts, etc).
> * Optional digital speedometer experimental code
> * Improvements in miles->km conversions
> * Improvements in modem initialisation and control
> * Fixes for support of sub-zero temperatures and battery pre-heating
> before charging
> * Watchdog timer support
> * App->Server->Car command support, including:
> o Start/Stop Charge
> o Set charge mode
> o Set charge current
> o Activate/Deactivate Valet Mode
> o Lock/Unlock Car (doors only - alarm and immobiliser cannot be
> deactivated where fitted [non-US cars])
> o Feature list and set
> o Parameter list and set
> o Wake up car
> o GPRS utilisation
> * Social group subscription
> * Ambient temperature monitoring
> * Many more vehicle parameters sent to server (including speed,
> direction, altitude, charge states, doors, etc)
> The Android App (in the market) already has experimental support for
> most of these new features, and the iPhone App is currently being
> extended (and we should have an experimental testflight release this
> week).
> We will most likely have a few more release candidate releases before
> final end-user firmware is cut, but we would like to get the current
> 1.2.0-rc3 installed in as many cars as possible, in the next few days
> - and would be grateful if you could assist.
> Any questions / problems should be addressed to this developers
> mailing list.
> Mark.
Stegen Electronics
Kwartslaan 95
3162 RD Rhoon
The Netherlands
Tel: +31 10-5016960
Skype: stegen.com
www.stegen.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120214/6b9fddee/attachment.htm>
