[Ovmsdev] OVMS OBDII Cables now available
    Sat Dec 29 00:40:10 HKT 2012
Michael,
Thanks for testing this. I hope you didn't get too much hassle at customs.
What do you think of the cable? Good enough for the job?
On 28 Dec, 2012, at 8:14 PM, mikeljo at me.com wrote:
> Hi all,
> Cable received.
> Tested and it Works.
> Bye
> Am 19.12.2012 um 09:20 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>> We received the cables yesterday, and they look good. The factory seems to have done a good job. I tested 5 - all ok - and even put one in my wife's Nissan to power up an OVMS module. Now, if only her car had a can bus :-(
>> OVMS vehicle cables for connection to can-bus equipped OBDII vehicles are now available from our FastTech logistics partner. You can find them here:
>>     OVMS OBDII Cable @FastTech
>> This cable connects the OVMS module to the vehicle CAN bus, via the industry standard OBDII socket. It is 1 metre in length, and uses a right-angle OBDII plug (J1962-M) to help with cable management and routing.
>> The cable is intended to be used in Renault Twizy, Chevy Volt, Opel/Vauxhall Ampera, and other cars using OBDII connectors.
>> OVMS OBDII Cable Pinout
>> J1962-M   DB9-F   Signal
>> 4         3       Chassis/Power GND
>> 6         7       CAN-H
>> 14        2       CAN-L
>> 16        9       +12V Vehicle Power
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121229/2fee7b97/attachment.htm>
