[Ovmsdev] OVMS OBDII Cables now available
mikeljo at me.com mikeljo at me.com
Fri Dec 28 20:14:32 HKT 2012
Hi all,
Cable received.
Tested and it Works.
Bye
Am 19.12.2012 um 09:20 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> We received the cables yesterday, and they look good. The factory seems to have done a good job. I tested 5 - all ok - and even put one in my wife's Nissan to power up an OVMS module. Now, if only her car had a can bus :-(
> OVMS vehicle cables for connection to can-bus equipped OBDII vehicles are now available from our FastTech logistics partner. You can find them here:
>     OVMS OBDII Cable @FastTech
> This cable connects the OVMS module to the vehicle CAN bus, via the industry standard OBDII socket. It is 1 metre in length, and uses a right-angle OBDII plug (J1962-M) to help with cable management and routing.
> The cable is intended to be used in Renault Twizy, Chevy Volt, Opel/Vauxhall Ampera, and other cars using OBDII connectors.
> OVMS OBDII Cable Pinout
> J1962-M   DB9-F   Signal
> 4         3       Chassis/Power GND
> 6         7       CAN-H
> 14        2       CAN-L
> 16        9       +12V Vehicle Power
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121228/7003fe70/attachment.htm>
