[Ovmsdev] OVMS OBDII Cables now available
Wed Dec 19 16:20:39 HKT 2012
We received the cables yesterday, and they look good. The factory seems to have done a good job. I tested 5 - all ok - and even put one in my wife's Nissan to power up an OVMS module. Now, if only her car had a can bus :-(
OVMS vehicle cables for connection to can-bus equipped OBDII vehicles are now available from our FastTech logistics partner. You can find them here:
OVMS OBDII Cable @FastTech
This cable connects the OVMS module to the vehicle CAN bus, via the industry standard OBDII socket. It is 1 metre in length, and uses a right-angle OBDII plug (J1962-M) to help with cable management and routing.
The cable is intended to be used in Renault Twizy, Chevy Volt, Opel/Vauxhall Ampera, and other cars using OBDII connectors.
OVMS OBDII Cable Pinout
J1962-M DB9-F Signal
4 3 Chassis/Power GND
6 7 CAN-H
14 2 CAN-L
16 9 +12V Vehicle Power
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121219/415874f4/attachment.htm>
