[Ovmsdev] Twizy module 2.1
    Tue Dec 11 02:23:53 HKT 2012
Mark,
stable & usable, with battery monitor enabled as well.
For the vehicle support table: speed display is also working -- if you
mean feeding "car_speed". The old App shows this on the second tab.
Also "charge mode control" and "lock/unlock control" would be "n/a" for
the Twizy. LOL on "seriously?" btw :-)
How about adding a row "special features"? For the Twizy that would now
contain:
- Individual max range config
- Charge alerts on SOC/range
- Battery health monitoring
I also vote for merging v2 into the master, I have been using only v2
lately.
Am 10.12.2012 01:50, schrieb Mark Webb-Johnson:
> Looks good. I'll try to merge it in.
> What is the status of Twizy support now, in your opinion? Is it stable
> and usable?
> I put up a page at:
>     http://www.openvehicles.com/vehiclesupport
>     Here's a summary of the vehicle support we have in OVMS at the
>     moment. Functionality for the Tesla Roadster v1.x and v2.x is
>     pretty much complete (although we have lots of ideas for add-on
>     functionality) and support for other vehicles is in progress.
>     Note that functions marked "experimental" and "development" may
>     not be in the main code repository yet - we recommend you check
>     with the developers mailing list for up-to-date status and code
>     location for these.
>     Function 	Tesla Roadster v1.x 	Tesla Roadster v2.x 	Volt/Ampera
>     Renault Twizy
>     Status 	Released 	Released 	Development 	Development
>     Firmware 	1.2.2 or later 	1.0.0 or later 	VA experimental 	RT
>     experimental
>     Hardware 	v1 or v2 	v2 or v2 	v2 	v2
>     Module 	OVMS Module v2
>     <http://www.fasttech.com/products/1099/10000001/1000300-ovms-car-module-v2>
>     	OVMS Module v2
>     	OVMS Module v2
>     	OVMS Module v2
>     Vehicle Cable 	OVMS Data Cable
>     <http://www.fasttech.com/products/1099/10000001/1000400> 	OVMS
>     Data Cable
>     <http://www.fasttech.com/products/1099/10000001/1000400> 	Not
>     available (yet) 	Not available (yet)
>     GSM Antenna 	OVMS GSM Antenna
>     <http://www.fasttech.com/products/1099/10000001/1000500> 	OVMS GSM
>     Antenna <http://www.fasttech.com/products/1099/10000001/1000500>
>     OVMS GSM Antenna
>     GPS Antenna 	Not Required 	Not Required 	OVMS GPS Antenna
>     <http://www.fasttech.com/products/1099/10000001/1020200> 	OVMS GPS
>     Antenna <http://www.fasttech.com/products/1099/10000001/1020200>
>     Firmware Tool 	PICKIT 2
>     <http://www.fasttech.com/products/1099/10000001/1002200> 	PICKIT 2
>     SOC Display 	Yes 	Yes 	Yes 	Yes
>     Range Display 	Yes 	Yes 	Not yet 	Yes
>     GPS Location Display 	Yes (car gps) 	Yes (car gps) 	Yes (OVMS
>     gps) 	Yes (OVMS gps)
>     Speed Display 	Yes 	Yes 	Not yet 	Not yet
>     Charge Status Display 	Yes 	Yes 	Not yet 	Yes
>     Charge Interruption Alerts 	Yes 	Yes 	Not yet 	Yes
>     Charge Control 	Yes 	Yes 	Not yet 	Not yet
>     Lock/Unlock Control 	Yes 	Yes 	Not yet 	Not yet
>     Charge Mode Control 	Yes 	Yes 	Not yet 	Not yet
>     Cabin Pre-heat/cool 	Not possible 	Not possible 	Not yet
>     Seriously? No
>     Digital Speedo 	Yes 	Not yet 	n/a 	n/a
> Does that seem accurate? Anything to add/remove.
> I think the v2 branch is stable now, and what we are working from, so
> perhaps it is time to merge it back into mainline head...
> On 9 Dec, 2012, at 8:39 PM, Michael Balzer wrote:
>> https://github.com/dexterbg/Open-Vehicle-Monitoring-System/commit/e527b90883353f32da0f60d09c871333dc2c4646
>> - temperature function updated to new formula (A - 40)
>> - cell alert thresholds changed to fixed absolute deviations
>>  3 °C temperature / 100 mV  (watch thresholds = stddev as before)
>> - battery monitor reset now bound to "key on" event
>>  instead of full charge cycle
>> - cell mean value / deviation calculations now done with rounding
>> - battery text alert now also sent by MSG protocol ("PA")
>>  and triggered immediately after every alert status change
>> - Twizy battery monitor compiler switch: OVMS_TWIZY_BATTMON
>>  current ressource usage: 6% RAM (193 byte) + 10% ROM
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121210/0cefbc6e/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121210/0cefbc6e/attachment-0002.vcf>
