This is a beta rest / release candidate, documentation has not yet been updated. Firmware: http://dexters-web.de/f/tw/OVMS-Twizy-3.6.0-beta1.zip Source: https://github.com/dexterbg/Open-Vehicle-Monitoring-System/ Framework V2.7.4: - New compiler switches to disable framework functions: OVMS_NO_CHARGECONTROL OVMS_NO_CTP OVMS_NO_SMSTIME OVMS_NO_VEHICLE_ALERTS (all need to be set for Twizy build) - Potential buffer overflow fix in net_msg_forward_sms() - Fix stp_l2f() for negative values - Fix SMS MSG wrapper for long commands Twizy V3.6.0: - New: All power values now based on real battery power (current * voltage) - Battery current sums + min/max moved to separate fields - STAT command extended by grid energy drain estimation - RT-GPS-Log extended by BMS limits, auto power levels and battery current min/max - RT-PWR-Log extended by battery coulomb counts (Ah) - "RT-PWR-UsageStats" is now "RT-PWR-Stats", fields reordered and units converted (to save space), coulomb count discharge/charge sums added (Ah) - Rework & bug fixes in auto power adjustment - Auto RECUP power adjustment extended by 100% reference power (ATT: CFG RECUP parameters changed!) - New: auto DRIVE power adjustment (ATT: CFG DRIVE parameters changed!) - New: CFG CLEAR = clear SEVCON diagnostic logs - Now using GSM time (NET_FN_CARTIME) for more accurate parking times - New: feature #14 & 64 = send notification on charge starts - Fixed charge time estimation for SOC > 94% - ISR performance optimization Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
