CAN bus logging not working
Hi, Has anyone had any problems with CAN bus logging? I have a 32GB SD card installed and "SD status" gives: *SD CARD is inserted* *Status: available* *Name: SD32G* *Size: 30419 MB* *Free: 29767 MB* *Card type: SDHC/SDXC* *Max speed: 25000 kHz* *Capacity: 30436 MB* *CSD: ver=1; sector_size=512; capacity=62333952 read_bl_len=9* *SCR: sd_spec=2; bus_width=5* I have setup CAN1 and 2 to "listen" and started the logging like it's mentioned in the user guide, checked the status, I stopped it some time later, and when I go to open it from the Web UI it is empty, also tried from the Editor and it is also empty, removing the card is a bit tricky since the hardware is pretty tucked away in the console. I searched the manual for a format command but can't find anything. I do get messages and readings on the OVMS Android app, so at least the OBD CAN is fine. Oscar
First guess is that you have to ‘can log stop’ to close the logging file before you will be able to see the content. If that is not it, please provide details of the logging commands you are typing, and what ‘vfs ls /sd’, ‘can can1 status’, ‘can can2 status’, show. Regards, Mark. P.S. If you have a modern OVMS module, I also suggest you double-check the sdcard maxfreq.khz setting to optimise performance: https://docs.openvehicles.com/en/latest/userguide/logging.html?highlight=sdc...
On 7 Feb 2023, at 4:08 AM, Christos Oscar Kambiselis <ckambiselis@gmail.com> wrote:
SD CARD is inserted Status: available Name: SD32G Size: 30419 MB Free: 29767 MB
Card type: SDHC/SDXC Max speed: 25000 kHz Capacity: 30436 MB CSD: ver=1; sector_size=512; capacity=62333952 read_bl_len=9 SCR: sd_spec=2; bus_width=5
Oscar _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Hi, The first time I tested it I started logging from the Web UI and stopped it from there too and the next time I tested it I did it from the shell, running status commands to make sure it had started and stopped. vfs ls /sd gives, 0 30-Nov-1979 00:00 log 0 30-Nov-1979 00:00 0 30-Nov-1979 00:00 0 30-Nov-1979 00:00 0 30-Nov-1979 00:00 ! 0 30-Nov-1979 00:00 ) 0 30-Nov-1979 00:00 1 0 30-Nov-1979 00:00 9 0 30-Nov-1979 00:00 A 0 30-Nov-1979 00:00 i 0 30-Nov-1979 00:00 Q 0 30-Nov-1979 00:00 y 0 30-Nov-1979 00:00 a 0 30-Nov-1979 00:00 i 0 30-Nov-1979 00:00 ���r 0 30-Nov-1979 00:00 y which I noticed on the "Editor", and the reason I wanted to format the card in the OVMS. can can1 status CAN: can1 Mode: Active Speed: 500000 DBC: none Interrupts: 214034 Rx pkt: 120472 Rx ovrflw: 0 Tx pkt: 90774 Tx delays: 0 Tx ovrflw: 0 Tx fails: 254 Err flags: 0x008040d9 Rx err: 0 Tx err: 128 Rx invalid: 0 Wdg Resets: 0 Wdg Timer: 2 sec(s) Err Resets: 0 can can2 status CAN: can2 Mode: Listen Speed: 500000 DBC: none Interrupts: 0 Rx pkt: 0 Rx ovrflw: 0 Tx pkt: 0 Tx delays: 0 Tx ovrflw: 0 Tx fails: 0 Err flags: 0x00000000 Rx err: 0 Tx err: 0 Rx invalid: 0 Wdg Resets: 91 Wdg Timer: 3 sec(s) Err Resets: 0 The command to start logging is the all CAN messages command from the guide *can log start vfs crtd /sd/can.crtd * and it returns CAN logging to VFS active: Type:vfs Format:crtd(discard) Vehicle:KN Path:/sd/can.cr also can log status #2: open Type:vfs Format:crtd(discard) Vehicle:KN Path:/sd/can.crtd Messages:214 Dropped:0 Filtered:0 Rate:0.0% /sd/can.crtd: running Messages:214 Discarded:0 Dropped:0 Filtered:0 Rate:0.0% On Tue, Feb 7, 2023, 02:08 Mark Webb-Johnson <mark@webb-johnson.net> wrote:
On 7 Feb 2023, at 4:08 AM, Christos Oscar Kambiselis < ckambiselis@gmail.com> wrote:
That SD looks messed up. There is no ‘format’ command that I know of in the ESP IDF. I did try a while (years) ago, but it wasn’t trivial at the time. If it detects an empty SDCARD it will format automatically, or you will need to format on a workstation. Your ‘can can1 status’ is showing packets, so I suggest you try: can log start vfs crtd /sd/can.crtd (Wait a minute) can log stop vfs ls /sd (and see if /sd/can.crtd has data) Regards, Mark
On 7 Feb 2023, at 2:16 PM, Christos Oscar Kambiselis <ckambiselis@gmail.com> wrote:
Hi,
The command to start logging is the all CAN messages command from the guide can log start vfs crtd /sd/can.crtd
and it returns CAN logging to VFS active: Type:vfs Format:crtd(discard) Vehicle:KN Path:/sd/can.cr <http://can.cr/>
On Tue, Feb 7, 2023, 02:08 Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote:
On 7 Feb 2023, at 4:08 AM, Christos Oscar Kambiselis <ckambiselis@gmail.com <mailto:ckambiselis@gmail.com>> wrote:
Oscar _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
This is the latest return vfs ls /sd 191.4M 09-Jan-2004 14:20 191.4M 09-Jan-2004 14:20 191.4M 09-Jan-2004 14:20 191.4M 09-Jan-2004 14:20 ! 191.4M 09-Jan-2004 14:20 ) 191.4M 09-Jan-2004 14:20 1 191.4M 09-Jan-2004 14:20 9 191.4M 09-Jan-2004 14:20 A 191.4M 09-Jan-2004 14:20 i 191.4M 09-Jan-2004 14:20 Q 191.4M 09-Jan-2004 14:20 y 191.4M 09-Jan-2004 14:20 a 191.4M 09-Jan-2004 14:20 i 191.4M 09-Jan-2004 14:20 ��� r 191.4M 09-Jan-2004 14:20 y I guess I have to open the covers again. Thanks for the help Oscar On Tue, Feb 7, 2023 at 8:22 AM Mark Webb-Johnson <mark@webb-johnson.net> wrote:
(Wait a minute)
can log stop
vfs ls /sd
On 7 Feb 2023, at 2:16 PM, Christos Oscar Kambiselis < ckambiselis@gmail.com> wrote:
Hi,
You can get the sdcard out and in with the help of something to push it with, without opening it up. Michael On Tue, 7 Feb 2023, 2:42 pm Christos Oscar Kambiselis, < ckambiselis@gmail.com> wrote:
(Wait a minute)
can log stop
vfs ls /sd
Hi,
I meant the cars own covers, the module is tacked away behind the upper panels. Oscar On Tue, Feb 7, 2023, 09:14 Michael Geddes <frog@bunyip.wheelycreek.net> wrote:
(Wait a minute)
can log stop
vfs ls /sd
Hi,
Ahh. Makes sense. I guess one of these days I'll get around to actually installing my OVMS properly. I still get the occasional need to get at the device (like for fixing a reboot loop due to a botched updated which requires physical USB access). For the moment it sits in the little space under the USB ports. //.ichael On Tue, 7 Feb 2023 at 17:39, Christos Oscar Kambiselis < ckambiselis@gmail.com> wrote:
Oscar
(Wait a minute)
can log stop
vfs ls /sd
Hi,
Christos Oscar Kambiselis -
Mark Webb-Johnson -
Michael Geddes
