Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works well the basic functions for my car with Mitsubishi profile. I want to create a own profile for my car for testing, my own code, but i duplicate mitsubishi files in components folder, and all mitsubishi change to peugeot (case sensitive), and vehicle code modified to PI, and duplicate mitsibishi code in main/Kconfig and modify to peugeot, but i can not see in the web interface after make flash. After add it make show a question: add Peugeot to... i write Y, but nothing happen. I use MacOS High Sierra, and atom for modify files.
Can you show the source code for your module (github repository?), or just: Your component.mk The changes you have made to sdkconfig Your OvmsVehicle***Init::OvmsVehicle**Init() function Your OvmsVehicle***::OvmsVehicle***() function Output of ‘vehicle list’ command Regards, Mark.
On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt@gmail.com> wrote:
Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works well the basic functions for my car with Mitsubishi profile. I want to create a own profile for my car for testing, my own code, but i duplicate mitsubishi files in components folder, and all mitsubishi change to peugeot (case sensitive), and vehicle code modified to PI, and duplicate mitsibishi code in main/Kconfig and modify to peugeot, but i can not see in the web interface after make flash. After add it make show a question: add Peugeot to... i write Y, but nothing happen. I use MacOS High Sierra, and atom for modify files. <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at 8.17.35.png>_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
- In attachment - compare on attachment picture - OvmsVehiclePeugeotInit::OvmsVehiclePeugeotInit() { ESP_LOGI(TAG, "Registering Vehicle: PEUGEOT ION (9000)"); MyVehicleFactory.RegisterVehicle<OvmsVehiclePeugeot>("PI","Peugeot iOn"); } - OvmsVehiclePeugeot::OvmsVehiclePeugeot() { ESP_LOGI(TAG, "Start Peugeot vehicle module"); mi_candata_timer = 0; mi_est_range = 0; mi_stale_charge = 0; mi_QC = 0; mi_QC_counter = 5; mi_last_good_SOC = 0; mi_last_good_range = 0; memset(m_vin,0,sizeof(m_vin)); memset(mi_batttemps,0,sizeof(mi_batttemps)); RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS); // require GPS: MyEvents.SignalEvent("vehicle.require.gps", NULL); MyEvents.SignalEvent("vehicle.require.gpstime", NULL); } - Type Name - DEMO Demonstration vehicle - FT5E Fiat 500e - KS Kia Soul EV - MI Mitsubishi iMiev - NL Nissan Leaf - NONE Empty vehicle - O2 OBDII - RT Renault Twizy - TGTC Think City - TR Tesla Roadster - TS Tesla Model S - VA Volt/Ampera - XX TRACK - ZEVA ZEVA BMS Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 11., K, 3:07):
- Your component.mk - The changes you have made to sdkconfig - Your OvmsVehicle***Init::OvmsVehicle**Init() function - Your OvmsVehicle***::OvmsVehicle***() function - Output of ‘vehicle list’ command
-- Üdvözlettel: Kovács Tamás
It seems your module is not compiled in / registered (if it doesn’t appear in vehicle list). Can you check your component.mk (the one in your vehicle directory, not the mail project one you attached). Make sure it matches the main/Kconfig name (with CONFIG at the start). Regards, Mark.
On 12 Sep 2018, at 12:11 AM, Tamás Kovács <kommykt@gmail.com> wrote:
In attachment compare on attachment picture OvmsVehiclePeugeotInit::OvmsVehiclePeugeotInit() { ESP_LOGI(TAG, "Registering Vehicle: PEUGEOT ION (9000)");
// require GPS: MyEvents.SignalEvent("vehicle.require.gps", NULL); MyEvents.SignalEvent("vehicle.require.gpstime", NULL); } Type Name DEMO Demonstration vehicle FT5E Fiat 500e KS Kia Soul EV MI Mitsubishi iMiev NL Nissan Leaf NONE Empty vehicle O2 OBDII RT Renault Twizy TGTC Think City TR Tesla Roadster TS Tesla Model S VA Volt/Ampera XX TRACK ZEVA ZEVA BMS
Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> ezt írta (időpont: 2018. szept. 11., K, 3:07): Can you show the source code for your module (github repository?), or just:
Your component.mk <http://component.mk/> The changes you have made to sdkconfig Your OvmsVehicle***Init::OvmsVehicle**Init() function Your OvmsVehicle***::OvmsVehicle***() function Output of ‘vehicle list’ command
On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt@gmail.com <mailto:kommykt@gmail.com>> wrote:
Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works well the basic functions for my car with Mitsubishi profile. I want to create a own profile for my car for testing, my own code, but i duplicate mitsubishi files in components folder, and all mitsubishi change to peugeot (case sensitive), and vehicle code modified to PI, and duplicate mitsibishi code in main/Kconfig and modify to peugeot, but i can not see in the web interface after make flash. After add it make show a question: add Peugeot to... i write Y, but nothing happen. I use MacOS High Sierra, and atom for modify files. <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at 8.17.35.png>_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Üdvözlettel: Kovács Tamás <component.mk><Screen Shot 2018-09-11 at 6.04.29.png>_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
In component.mk and main/Kconfig has the same name. Kconfig: config OVMS_VEHICLE_PEUGEOT component.mk (in vehicle folder): CONFIG_OVMS_VEHICLE_PEUGEOT Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 12., Sze, 5:40):
-- Üdvözlettel: Kovács Tamás <component.mk><Screen Shot 2018-09-11 at 6.04.29.png> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Easiest way would be for you to commit changes, push to a github repository, then let us know where that is so that we can check. Very hard to help find where the issue is, without actually being able to see the code. When the module starts, it will show initialisation of modules - please check to ensure your module shows up there. If initialisation works, then check the vehicle list to be sure it is registered. Regards, Mark.
On 12 Sep 2018, at 12:22 PM, Tamás Kovács <kommykt@gmail.com> wrote:
In component.mk <http://component.mk/> and main/Kconfig has the same name. Kconfig: config OVMS_VEHICLE_PEUGEOT component.mk <http://component.mk/> (in vehicle folder): CONFIG_OVMS_VEHICLE_PEUGEOT
Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> ezt írta (időpont: 2018. szept. 12., Sze, 5:40): It seems your module is not compiled in / registered (if it doesn’t appear in vehicle list).
Can you check your component.mk <http://component.mk/> (the one in your vehicle directory, not the mail project one you attached). Make sure it matches the main/Kconfig name (with CONFIG at the start).
On 12 Sep 2018, at 12:11 AM, Tamás Kovács <kommykt@gmail.com <mailto:kommykt@gmail.com>> wrote:
-- Üdvözlettel: Kovács Tamás <component.mk <http://component.mk/>><Screen Shot 2018-09-11 at 6.04.29.png>_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Üdvözlettel: Kovács Tamás _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I use first time github, commit change, and push to my github reposytory: gitHub <https://github.com/KommyKT/Open-Vehicle-Monitoring-System-3/tree/upsteam/peugeot>, and after pull request (I should not have done it) Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 12., Sze, 6:46):
I compiled your code, and get: ... I (287) v-twizy: Registering Vehicle: Renault Twizy (9000) I (293) v-peugeot: Registering Vehicle: PEUGEOT ION (9000) I (300) v-obdii: Registering Vehicle: OBDII (9000) … OVMS# vehicle list Type Name DEMO Demonstration vehicle FT5E Fiat 500e KS Kia Soul EV MI Mitsubishi iMiev NL Nissan Leaf NONE Empty vehicle O2 OBDII PI Peugeot iOn RT Renault Twizy TGTC Think City TR Tesla Roadster TS Tesla Model S VA Volt/Ampera XX TRACK ZEVA ZEVA BMS The Peugeot iOn also appears in the web interface config vehicle list. My sdkconfig has: # # Vehicle Support # CONFIG_OVMS_VEHICLE_NONE=y CONFIG_OVMS_VEHICLE_OBDII=y CONFIG_OVMS_VEHICLE_TRACK=y CONFIG_OVMS_VEHICLE_DEMO=y CONFIG_OVMS_VEHICLE_TESLAROADSTER=y CONFIG_OVMS_VEHICLE_TESLAMODELS=y CONFIG_OVMS_VEHICLE_NISSANLEAF=y CONFIG_OVMS_VEHICLE_RENAULTTWIZY=y CONFIG_OVMS_VEHICLE_KIASOULEV=y CONFIG_OVMS_VEHICLE_VOLTAMPERA=y CONFIG_OVMS_VEHICLE_THINKCITY=y CONFIG_OVMS_VEHICLE_MITSUBISHI=y CONFIG_OVMS_VEHICLE_PEUGEOT=y CONFIG_OVMS_VEHICLE_ZEVA=y CONFIG_OVMS_VEHICLE_FIAT500=y CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144 CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=40 Also: $ make size-components|grep -e 'Archive' -e peugeot Archive File DRAM .data & .bss IRAM Flash code & rodata Total libvehicle_peugeot.a 0 54 0 3655 531 4240 Can you try to recreate that? Do you get the same? If not, what differences? Regards, Mark.
Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> ezt írta (időpont: 2018. szept. 12., Sze, 6:46): Easiest way would be for you to commit changes, push to a github repository, then let us know where that is so that we can check. Very hard to help find where the issue is, without actually being able to see the code.
On 12 Sep 2018, at 12:22 PM, Tamás Kovács <kommykt@gmail.com <mailto:kommykt@gmail.com>> wrote:
-- Üdvözlettel: Kovács Tamás _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
First i run - "make flash" at first time, the ovms "booted" up - and *not *shown in web interface, - "vehicle list" command - not shown peugeot - "make size-components|grep -e 'Archive' -e peugeot" - output same as yours - sdkconfig - same as yours - make monitor - not shown "v-peugeot: Registering Vehicle: PEUGEOT ION (9000)" row I don't understand what is a problem. Now i install debian 9 -on my laptop to test in the car, and write code, but same as if i compile on my Mac. I attach some picture, to show some state. Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 14., P, 3:19):
My sdkconfig has:
Also:
Yep. You are running from ota_1: Please try changing to factory partition, which is what ‘make app-flash’ writes to. Regards, Mark
On 15 Sep 2018, at 12:31 AM, Tamás Kovács <kommykt@gmail.com> wrote:
First i run "make flash" at first time, the ovms "booted" up and not shown in web interface, "vehicle list" command not shown peugeot "make size-components|grep -e 'Archive' -e peugeot" output same as yours sdkconfig same as yours make monitor not shown "v-peugeot: Registering Vehicle: PEUGEOT ION (9000)" row I don't understand what is a problem. Now i install debian 9 -on my laptop to test in the car, and write code, but same as if i compile on my Mac. I attach some picture, to show some state.
My sdkconfig has:
Also:
I use first time github, commit change, and push to my github reposytory: gitHub, and after pull request (I should not have done it)
> On 12 Sep 2018, at 12:11 AM, Tamás Kovács <kommykt@gmail.com> wrote: > > In attachment > compare on attachment picture > OvmsVehiclePeugeotInit::OvmsVehiclePeugeotInit() > { > ESP_LOGI(TAG, "Registering Vehicle: PEUGEOT ION (9000)"); > > MyVehicleFactory.RegisterVehicle<OvmsVehiclePeugeot>("PI","Peugeot iOn"); > } > > OvmsVehiclePeugeot::OvmsVehiclePeugeot() > { > ESP_LOGI(TAG, "Start Peugeot vehicle module"); > > mi_candata_timer = 0; > mi_est_range = 0; > mi_stale_charge = 0; > mi_QC = 0; > mi_QC_counter = 5; > mi_last_good_SOC = 0; > mi_last_good_range = 0; > memset(m_vin,0,sizeof(m_vin)); > memset(mi_batttemps,0,sizeof(mi_batttemps)); > > RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS); > > // require GPS: > MyEvents.SignalEvent("vehicle.require.gps", NULL); > MyEvents.SignalEvent("vehicle.require.gpstime", NULL); > } > Type Name > DEMO Demonstration vehicle > FT5E Fiat 500e > KS Kia Soul EV > MI Mitsubishi iMiev > NL Nissan Leaf > NONE Empty vehicle > O2 OBDII > RT Renault Twizy > TGTC Think City > TR Tesla Roadster > TS Tesla Model S > VA Volt/Ampera > XX TRACK > ZEVA ZEVA BMS > > > > Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 11., K, 3:07): >> Can you show the source code for your module (github repository?), or just: >> >> Your component.mk >> The changes you have made to sdkconfig >> Your OvmsVehicle***Init::OvmsVehicle**Init() function >> Your OvmsVehicle***::OvmsVehicle***() function >> Output of ‘vehicle list’ command >> >> Regards, Mark. >> >>> On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt@gmail.com> wrote: >>> >>> Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works >>> well the basic functions for my car with Mitsubishi profile. I want to >>> create a own profile for my car for testing, my own code, but i >>> duplicate mitsubishi files in components folder, and all mitsubishi >>> change to peugeot (case sensitive), and vehicle code modified to PI, >>> and duplicate mitsibishi code in main/Kconfig and modify to peugeot, >>> but i can not see in the web interface after make flash. After add it >>> make show a question: add Peugeot to... i write Y, but nothing happen. >>> I use MacOS High Sierra, and atom for modify files. >>> <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at 8.17.35.png>_______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > -- > Üdvözlettel: > Kovács Tamás > <component.mk><Screen Shot 2018-09-11 at 6.04.29.png>_______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Üdvözlettel: Kovács Tamás <IMG_2030.jpg> <IMG_2026.jpg> <IMG_2029.jpg> <IMG_2031.jpg> <make_monitor.pdf> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
First i change to factory partition , nothing happen, and after run "make app-flash", now show my "new car" Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 15., Szo, 3:36):
[image: image1.jpeg]
First i run
My sdkconfig has:
Also:
<IMG_2030.jpg>
<IMG_2026.jpg>
<IMG_2029.jpg>
<IMG_2031.jpg>
<make_monitor.pdf>
Changing the partition just sets it to run at the next boot. It will stay on factory so long as you don’t do an ota update. Regards, Mark
My sdkconfig has:
Also:
> On 12 Sep 2018, at 12:22 PM, Tamás Kovács <kommykt@gmail.com> wrote: > > In component.mk and main/Kconfig has the same name. > Kconfig: config OVMS_VEHICLE_PEUGEOT > component.mk (in vehicle folder): CONFIG_OVMS_VEHICLE_PEUGEOT > > Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 12., Sze, 5:40): >> It seems your module is not compiled in / registered (if it doesn’t appear in vehicle list). >> >> Can you check your component.mk (the one in your vehicle directory, not the mail project one you attached). Make sure it matches the main/Kconfig name (with CONFIG at the start). >> >> Regards, Mark. >> >>> On 12 Sep 2018, at 12:11 AM, Tamás Kovács <kommykt@gmail.com> wrote: >>> >>> In attachment >>> compare on attachment picture >>> OvmsVehiclePeugeotInit::OvmsVehiclePeugeotInit() >>> { >>> ESP_LOGI(TAG, "Registering Vehicle: PEUGEOT ION (9000)"); >>> >>> MyVehicleFactory.RegisterVehicle<OvmsVehiclePeugeot>("PI","Peugeot iOn"); >>> } >>> >>> OvmsVehiclePeugeot::OvmsVehiclePeugeot() >>> { >>> ESP_LOGI(TAG, "Start Peugeot vehicle module"); >>> >>> mi_candata_timer = 0; >>> mi_est_range = 0; >>> mi_stale_charge = 0; >>> mi_QC = 0; >>> mi_QC_counter = 5; >>> mi_last_good_SOC = 0; >>> mi_last_good_range = 0; >>> memset(m_vin,0,sizeof(m_vin)); >>> memset(mi_batttemps,0,sizeof(mi_batttemps)); >>> >>> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS); >>> >>> // require GPS: >>> MyEvents.SignalEvent("vehicle.require.gps", NULL); >>> MyEvents.SignalEvent("vehicle.require.gpstime", NULL); >>> } >>> Type Name >>> DEMO Demonstration vehicle >>> FT5E Fiat 500e >>> KS Kia Soul EV >>> MI Mitsubishi iMiev >>> NL Nissan Leaf >>> NONE Empty vehicle >>> O2 OBDII >>> RT Renault Twizy >>> TGTC Think City >>> TR Tesla Roadster >>> TS Tesla Model S >>> VA Volt/Ampera >>> XX TRACK >>> ZEVA ZEVA BMS >>> >>> >>> >>> Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 11., K, 3:07): >>>> Can you show the source code for your module (github repository?), or just: >>>> >>>> Your component.mk >>>> The changes you have made to sdkconfig >>>> Your OvmsVehicle***Init::OvmsVehicle**Init() function >>>> Your OvmsVehicle***::OvmsVehicle***() function >>>> Output of ‘vehicle list’ command >>>> >>>> Regards, Mark. >>>> >>>>> On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt@gmail.com> wrote: >>>>> >>>>> Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works >>>>> well the basic functions for my car with Mitsubishi profile. I want to >>>>> create a own profile for my car for testing, my own code, but i >>>>> duplicate mitsubishi files in components folder, and all mitsubishi >>>>> change to peugeot (case sensitive), and vehicle code modified to PI, >>>>> and duplicate mitsibishi code in main/Kconfig and modify to peugeot, >>>>> but i can not see in the web interface after make flash. After add it >>>>> make show a question: add Peugeot to... i write Y, but nothing happen. >>>>> I use MacOS High Sierra, and atom for modify files. >>>>> <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at 8.17.35.png>_______________________________________________ >>>>> OvmsDev mailing list >>>>> OvmsDev@lists.openvehicles.com >>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>>> >>>> _______________________________________________ >>>> OvmsDev mailing list >>>> OvmsDev@lists.openvehicles.com >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >>> >>> >>> -- >>> Üdvözlettel: >>> Kovács Tamás >>> <component.mk><Screen Shot 2018-09-11 at 6.04.29.png>_______________________________________________ >>> OvmsDev mailing list >>> OvmsDev@lists.openvehicles.com >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > > -- > Üdvözlettel: > Kovács Tamás > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
-- Üdvözlettel: Kovács Tamás <image1.jpeg> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Also, please check: ota status And make sure you are booting from "factory" partition (not ota 0 or 1), to ensure you are actually running your newly flashed code. Regards, Mark
My sdkconfig has:
Also:
Mark Webb-Johnson <mark@webb-johnson.net> ezt írta (időpont: 2018. szept. 11., K, 3:07): > Can you show the source code for your module (github repository?), or just: > > Your component.mk > The changes you have made to sdkconfig > Your OvmsVehicle***Init::OvmsVehicle**Init() function > Your OvmsVehicle***::OvmsVehicle***() function > Output of ‘vehicle list’ command > > Regards, Mark. > >> On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt@gmail.com> wrote: >> >> Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works >> well the basic functions for my car with Mitsubishi profile. I want to >> create a own profile for my car for testing, my own code, but i >> duplicate mitsubishi files in components folder, and all mitsubishi >> change to peugeot (case sensitive), and vehicle code modified to PI, >> and duplicate mitsibishi code in main/Kconfig and modify to peugeot, >> but i can not see in the web interface after make flash. After add it >> make show a question: add Peugeot to... i write Y, but nothing happen. >> I use MacOS High Sierra, and atom for modify files. >> <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at 8.17.35.png>_______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.openvehicles.com >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.openvehicles.com > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Mark Webb-Johnson -
Tamás Kovács
