Working on ESP-IDF5 + Have a question about ovms_module 'Name'
Hey, In working trying to get ESP-IDF 5+ Working, I came across the following fun thing that I'm trying to work out what is going on!! This is from main/ovms_module.cpp I'm not sure why we don't just go through all the words and compare - why the masked compare for the last entry! And why that value?? It might make sense if you masked out the final byte ... I'm just struggling to understand. Why am I looking at it?? Well there's a new warning about copy constructors.. and then I ran into a problem where 'Name' is sometimes in memory that can only be accessed 32bit int aligned (which is why the strange implementation in the first place - I get that). Can anybody shed any light on this? class Name {....... inline bool operator==(const Name& a) const { for (int i = 0; i < NAMELEN/4 - 1; ++i) if (a.words[i] != words[i]) return false; i*f (a.words[NAMELEN/4-1] != (words[NAMELEN/4-1] & 0x7FFFFFFF)) return false;* return true; }
Michael, Am 21.01.24 um 02:54 schrieb Michael Geddes:
From the further accesses to the last word/byte in TaskMap, I'd guess Steve intended using the sign bit on the last byte as some special indicator, but it's not clear to me for what purpose. It also doesn't seem to be relevant anymore. Steve's commit message is verbose (30d0a403a380e797f9b222b01dab8da791ab388c), and maybe you can find some more explanation in the list archives. Regards, Michael
Thanks Michael, I hadn't considered there would be an essay in the commit, thanks for that - though it doesn't shed a lot of light on the situation There seems to be 2 places that mark a Name using the high bit, and only one place that kinda-sorta reads it. The Name is 'marked' during populate() which seems to be to mark each name with a '*' and the high-bit, before going through and getting the current names for the processes - adding new ones and replacing the old ones without '*' and high-bit mark. So items which are double marked are effectively stale/historic. It is also 'marked' during the find call .. which basically marks the 'found' name if it was not found and then constructed. The does not appear to be any purpose to this that I can ascertain. The one place (afaict) it reads the value is in zero() below - the problem is that it looks at the entire top uint32 rather than just that high byte!! It's hard to work out whether this is just a long-standing bug or whether it is weeding out names > 12 characters as well from being removed. So this seems to remove an item from the map, but only if it isn't marked (or long) ie if it isn't stale - or been 'seen' I guess? bool zero(TaskHandle_t taskid) { for (int i = 0; i < count; ++i) { if (map[i].id == taskid) { * if (map[i].name.words[NAMELEN/4-1] > 0)* return false; for (++i ; i < count; ++i) { map[i-1] = map[i]; } --count; return true; } } return false; } Does this help? Any thoughts on what this was meant to do ? I've CCd Stephen with a hope he might chip in? //. On Wed, 24 Jan 2024 at 15:09, Michael Balzer <dexter@expeedo.de> wrote:
Michael,
Regards, Michael
_______________________________________________ OvmsDev mailing listOvmsDev@lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Michael, Unfortunately, Steve passed away in 2022 so is unlikely to reply :-( He did work on some of the lower level and more complex parts of OVMS, as well as the command processing framework, and is sorely missed. I can’t help much with the code you are working on, other than to ask if this functionality is still required in the v5 IDF framework? A lot of stuff we did back then was to address inadequacies in the very new early buggy frameworks coming out of Espressif for the just released ESP-32. Regards, Mark.
On 26 Jan 2024, at 9:23 AM, Michael Geddes <frog@bunyip.wheelycreek.net> wrote:
Oh damn, that is both unfortunate and sad that he is no longer with us. The high-bit does seem to almost have a usage, but I'm just not seeing it quite and there's possibly a bug if it does? It seems that once you call the command 'modules task stack' * this calls get_tasks() which calls populate() * which then marks all the tasks in the list with * and high-bit and then the reloads the existing tasks and names which overrides both * and high_bit() * The high bit (and a long task name) will cause the zero() function to not remove the entry from the list. * module memory and module leaks commands both call changes->transfer() which calls zero(Task) for every item in HeapTotals that has zero 'after' value for DRAM, D_IRAM and SPIRAM. So this is really affecting only module commands output. I certainly think that the 'and a long task name' part is a weird mistake. I guess we can see what we see. This was all just trying to make it readable and fix the memory access crashes I was getting when I added in some extra methods required by the compiler. //.ichael On Fri, 26 Jan 2024 at 09:34, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
Michael,
Mark Webb-Johnson -
Michael Balzer -
Michael Geddes
