Re: [Ovmsdev] debugging CAN bus error flags
Thanks Michael, That explains why I was struggling to decode the error flag. Having been through the MCP2515 docs and decoded the logged error flags can2 is receiving they all relate to overflow of RXB0 but not RXB1. Hence this does not really pose or indicate a problem for the can bus / MCP2515 chip, correct? So if I have understood the chip operation is there any reason for line 489 in mcp2515.cpp which causes these to be logged? 489: LogStatus(CAN_LogStatus_Error); As if RXB1 does overflow and cause a packet loss then line 467: ESP_LOGW(TAG, "CAN Bus 2/3 receive overflow; Frame lost."); deals with that? Cheers Derek
Derek, all error conditions can be relevant for debugging. For example if you need to react to some frames as fast as possible, you may want to know if/when overflows occur, as they indicate processing delays. Also be aware LogStatus() injects the error status into the CAN logging framework, while ESP_LOGW() only creates a system log entry. Again for your error codes:
1970-01-01 13:01:41 NZDT E (89501) can: can2: intr=93510 rxpkt=127559 txpkt=14 errflags=0x23000001 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0 1970-01-01 13:01:41 NZDT E (89511) can: can2: intr=93511 rxpkt=127564 txpkt=14 errflags=0x23400401 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0 1970-01-01 13:01:41 NZDT E (89531) can: can2: intr=93525 rxpkt=127592 txpkt=14 errflags=0x22400402 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0
The strange combination 0x2300.... (error interrupt w/o error flags) may here also indicate a bug / race condition in the driver. Looking at the current code now: the LogStatus() call should also be done after having collected all error info, but the handler adds m_status.error_flags after the call. So the picture you got might be wrong, I suggest verifying / debugging the handler first. Regards, Michael Am 17.07.20 um 09:31 schrieb Derek Caudwell:
Thanks Michael,
Cheers Derek
Derek Caudwell -
Greg D. -
