Fwd: Open Vehicle 3.2.1 (20131211) is now available
A good day. OVMS Android App v3.2.1 is now released to beta test. You can get it from testflightapp: http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNz... We’re using TestFlightApp for both iOS and Android Apps, so it would be helpful if you could register there. If you do, you’ll get notified of new builds as and when they are released. As with the iOS App, we’ve had sponsorship and support from Zero Carbon World for this: Charging station integration and information provided by Zero Carbon World (http://www.zerocarbonworld.org/open-charge-map) and the Open Charge Map project (www.openchargemap.org). Let me have feedback / problems via testflightapp or here. It is a beta #1 build, but is functionally complete. The only known issue is a 20 second delay when a new car is setup (or the first time the app is run), for charge station data to be downloaded. Regards, Mark.
Open Vehicle Version 3.2.1 (20131211)
(open this email on your Android 2.3+ Device and click the install button)
What's New
v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1
* 67dd173 Disable two-finger rotation gesture for map * 79b70dd Dont show undefined number of charging points as "null" * f813df7 Revise clustering factors, to improve usability choices * d1786ca Tidy up layout of setting dialog * d37d9c7 OCM integration, rough draft
Details
Platform: Android Version: 3.2.1 (20131211) Team: Open Vehicles Release Date: December 11, 2013 Size: 13.4 MB
Hi Mark, Can you confirm if this build supports the Leaf? Just to confirm that both Nikki (I assume) and I are standing ready to help Leaf testing once firmware is available. Look forward to helping out. Also, I now have an OBD2 and Leafspy so maybe able to take traces if required. Rob ---- On Wed, 11 Dec 2013 10:25:02 +0100 Mark Webb-Johnson<mark@webb-johnson.net> wrote ---- A good day. OVMS Android App v3.2.1 is now released to beta test. You can get it from testflightapp: http://www.testflightapp.com/install/c514a82bf4936634cbd1f76536c74c67-ODMxNz... We’re using TestFlightApp for both iOS and Android Apps, so it would be helpful if you could register there. If you do, you’ll get notified of new builds as and when they are released. As with the iOS App, we’ve had sponsorship and support from Zero Carbon World for this: Charging station integration and information provided by Zero Carbon World (http://www.zerocarbonworld.org/open-charge-map) and the Open Charge Map project (www.openchargemap.org). Let me have feedback / problems via testflightapp or here. It is a beta #1 build, but is functionally complete. The only known issue is a 20 second delay when a new car is setup (or the first time the app is run), for charge station data to be downloaded. Regards, Mark. Open Vehicle Version 3.2.1 (20131211) (open this email on your Android 2.3+ Device and click the install button) What's New v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1 * 67dd173 Disable two-finger rotation gesture for map * 79b70dd Dont show undefined number of charging points as "null" * f813df7 Revise clustering factors, to improve usability choices * d1786ca Tidy up layout of setting dialog * d37d9c7 OCM integration, rough draft Details Platform: Android Version: 3.2.1 (20131211) Team: Open Vehicles Release Date: December 11, 2013 Size: 13.4 MB _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Robert, This is an update to the Android App (not in-car firmware). I’m still working on the Leaf support (but have been ill with flu for the past week). Should have a build for you guys any day now. Regards, Mark. On 11 Dec, 2013, at 5:55 pm, Robert Sharpe <robert.sharpe@evergreen-consulting.co.uk> wrote:
Hi Mark,
Rob
A good day.
What's New
Details
Dear Mark, I have just started following your blog and entire project. Is entire project focussed on electric cars(Roadster $ Leaf) or there are chances that your solution can be used for other cars too . I wish to contribute and test with others cars using standard OBD11 and probably getting more data that simple OBD. But the query is will your app or server require changes . Since you have codes available online can we make changes to adjust server/app for various other cars. Awaiting your reply and guidance. Regards, Avesh On Wed, Dec 11, 2013 at 5:21 PM, Mark Webb-Johnson <mark@webb-johnson.net>wrote:
Robert,
On 11 Dec, 2013, at 5:55 pm, Robert Sharpe < robert.sharpe@evergreen-consulting.co.uk> wrote:
Hi Mark,
Rob
---- On Wed, 11 Dec 2013 10:25:02 +0100 *Mark Webb-Johnson<mark@webb-johnson.net <mark@webb-johnson.net>>* wrote ----
A good day.
*Open Vehicle* Version 3.2.1 (20131211) [image: INSTALL]<http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ> (open this email on your Android 2.3+ Device and click the install button)
*What's New*
*Details*
*Platform:* Android *Version:* 3.2.1 (20131211) *Team:* Open Vehicles *Release Date:* December 11, 2013 *Size:* 13.4 MB
Avesh, Welcome.
We do focus on electric cars, but there is nothing in the project really specific to them. I have recently made quite a few changes to the generic OBDII driver to introduce a generic polling mechanism, and that vehicle support should be quite reasonable when that code is released (still a work-in-progress today). My concern with generic OBDII though is the 12V battery. OVMS does not currently implement a sleep mode, and it is not so easy in the current architecture and hardware, so power drain may be a concern for cars with small batteries.
Everything we have is in the project HEAD now. I suggest you look at my new vehicle.{h,c} and vehicle_obdii.c code to see how it works. You can see that it should be fairly easy to extend. Have a look at it, and then come back to us with any questions / suggestions you have. Regards, Mark. On 11 Dec, 2013, at 8:09 pm, Avesh Chauhan <aveshcool@gmail.com> wrote:
Dear Mark,
Regards, Avesh
On Wed, Dec 11, 2013 at 5:21 PM, Mark Webb-Johnson <mark@webb-johnson.net> wrote: Robert,
Hi Mark,
Rob
A good day.
What's New
Details
Hi Mark, I was not able to get this app into my dashboard, I guess I have to be explicitly invited or part of the team.?. Regards Rolf On 11.12.2013 10:25, Mark Webb-Johnson wrote:
A good day.
Charging station integration and information provided by Zero Carbon World (http://www.zerocarbonworld.org/open-charge-map) and the Open Charge Map project (www.openchargemap.org <http://www.openchargemap.org>).
TestFlight » Beta Testing On The Fly
*Open Vehicle* Version 3.2.1 (20131211) INSTALL <http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ>
*What's New*
*Details*
-- Rolf Welde Skeie Solåsen 27, 5223 Nesttun, Norway +47 92403016 / rwskeie@gmail.com
Rolf, Can you try this link: http://tflig.ht/v8INxA I think I still need to approve, but that should work. Regards, Mark. On 11 Dec, 2013, at 6:28 pm, Rolf Welde Skeie <rwskeie@gmail.com> wrote:
Hi Mark,
Regards Rolf
A good day.
*What's New*
*Details*
-- Rolf Welde Skeie Solåsen 27, 5223 Nesttun, Norway +47 92403016 / rwskeie@gmail.com _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
For those not already in testflightapp, the following recruitment URL should let you sign-up: http://tflig.ht/18Bho0d Regards, Mark. On 11 Dec, 2013, at 5:25 pm, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
A good day.
What's New
Details
Sorry, still getting used to the new Android testflightapp. This link may be better: http://tflig.ht/v8INxA Regards, Mark. On 11 Dec, 2013, at 7:32 pm, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
A good day.
What's New
Details
Hmm, after using the last two links you sent I'm now a member of the "Open Vehicles" and "Android Testers" teams, but there are no apps available.?.. (tried both compatible and noncompatible). More tricks up your sleeve? :) Regards Rolf On 12/11/2013 12:40 PM, Mark Webb-Johnson wrote:
On 11 Dec, 2013, at 7:32 pm, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote:
On 11 Dec, 2013, at 5:25 pm, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>> wrote:
A good day.
Charging station integration and information provided by Zero Carbon World (http://www.zerocarbonworld.org/open-charge-map) and the Open Charge Map project (www.openchargemap.org <http://www.openchargemap.org/>).
*What's New*
*Details*
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
I’ve just confirmed your join (it seems to require that). Can you try again - you should have got an eMail with the link. Regards, Mark. On 11 Dec, 2013, at 7:47 pm, Rolf Welde Skeie <rwskeie@gmail.com> wrote:
Regards Rolf
A good day.
*What's New*
*Details*
I can confirm that: - I got an email - I was able to download the app and install it - I was able to change my default car picture to a Think City (horaay) I have noticed a couple of changes which might not be intended: - map default zoom level too zoomed in - when in map view horizontal wipe does not go to the next menu item (Messages), it only moves the map about. - the Think images need a bit of photoshopping to remove the white border. I guess I should start putting stuff in bugzilla or something.. Or even better, fix them :) Thanks Mark for getting me "into the loop". Best regards Rolf On 12/11/2013 12:49 PM, Mark Webb-Johnson wrote:
Regards Rolf
A good day.
*What's New*
*Details*
Fix would be good! Github pulls accepted :-)
We tried to put it close to the iOS version, but maybe both are too aggressive. It is a fairly simple change I think.
On my nexus 4, I need to swipe from just off the side of the screen, and not too fast. I think this is part of the ActionBarSherlock framework.
I wouldn’t worry about this too much, but you are welcome to make the fix. I am re-working that entire framework to use base layer + colour layer + mask to generate all the different car images from one. Any help you, or anyone, can give to this would be most appreciated. This is beta #1, and the changes made to get OCM integration done have been quite drastic (most notable upgrading to maps api v2). I am aware that the translations will need to be added to, but that can be left until we are a bit later in this beta process. Regards, Mark. On 11 Dec, 2013, at 8:07 pm, Rolf Welde Skeie <rwskeie@gmail.com> wrote:
Best regards Rolf
Regards Rolf
A good day.
> TestFlight » Beta Testing On The Fly > > *Open Vehicle* > Version 3.2.1 (20131211) INSTALL > <http://email.n.testflightapp.com/c/YnVpbGRfaWQ9ODMxNzcwMiZkPTViYSZpPTIwMTMxMjExMDkwMDExLjk2My42OTQxMiU0MHdvcmtlcjYuYXMudGVzdGZsaWdodGFwcC5jb20maD1kNDViMGRlN2U0ZjA5Zjk3ODhiN2FjOTQ5NWQ1ZDMxMyZsPWh0dHAlM0ElMkYlMkZ0ZXN0ZmxpZ2h0YXBwLmNvbSUyRmluc3RhbGwlMkZjNTE0YTgyYmY0OTM2NjM0Y2JkMWY3NjUzNmM3NGM2Ny1PRE14Tnpjd01nJTJGJnI9bWFyayU0MHdlYmItam9obnNvbi5uZXQ> > > > > > (open this email on your Android 2.3+ Device and click the install > button) > > *What's New* > > v3.2.1 OVMS for Android, with Open Charge Map integration - beta #1 > > * 67dd173 Disable two-finger rotation gesture for map > * 79b70dd Dont show undefined number of charging points as "null" > * f813df7 Revise clustering factors, to improve usability choices > * d1786ca Tidy up layout of setting dialog > * d37d9c7 OCM integration, rough draft > > > > *Details* > > *Platform:* Android > *Version:* 3.2.1 (20131211) > *Team:* Open Vehicles > *Release Date:* December 11, 2013 > *Size:* 13.4 MB >
I've got some new IOS devices. Can you add these to the beta list: f6845be196e3103a7e6ea3e1b24d26516f43aa26 6904b3d696ceaa09ac9759eabbb037d222059286 Didn't realize you were a diver (looked on FB for your email first and found the rebreather pics). I'm also a tech diver (open circuit only)... Ken
Adelman@Adelman.COM -
Avesh Chauhan -
Mark Webb-Johnson -
Robert Sharpe -
Rolf Welde Skeie
