PICkit changes parameters (EEPROM)
Hi all, my PICkit2 frequently alters single EEPROM cells on flashing. It's set to "preserve EEPROM" and mostly does so, the effect only for example changes the server parameter from "64..." to "S4...". Other parameter slots also have been affected, my last flash changed my registered phone id, and a forum member reports a change of the first vehicle id byte from "D" to "R". Is there a way to make the flashing process reliably preserve the EEPROM? Thanks, Michael -- Michael Balzer * Paradestr. 8 * D-42107 Wuppertal Fon 0202 / 272 2201 * Handy 0176 / 206 989 26
I've never had anything like that happen and I've flashed my device plenty of times when doing occasional coding. I have blasted it to all zeros a few times, which I attribute to forgetting to flip that setting either in the MPLab project or in the PICkit2 downloader. Perhaps you have a bad chip or a bad programmer? Very curious. Tom -----Original Message----- From: Michael Balzer <dexter@expeedo.de> Reply-To: OVMS Developers <ovmsdev@lists.teslaclub.hk> Date: Saturday, May 31, 2014 at 6:19 AM To: OVMS Developers <ovmsdev@lists.teslaclub.hk> Subject: [Ovmsdev] PICkit changes parameters (EEPROM)
Hi all,
Thanks, Michael
Tom, that could be the case if it's only me, but this has been reported by other users as well. This is my PICkit config: <PICkit2PlatformTool> <property key="pk2settings.3state" value="false"/> <property key="pk2settings.preserveee" value="true"/> <property key="pk2settings.setvddvoltage" value="5,00"/> <property key="pk2settings.userpgmexec" value="true"/> <property key="pk2settings.usetargetpower" value="false"/> </PICkit2PlatformTool> The "5.00 V" setting is marked red with "!!" and "Unknown cause" by the MPLAB config UI -- I don't know what that means. Regards, Michael Am 31.05.2014 17:40, schrieb Tom Saxton:
Very curious.
Tom
Hi all,
Thanks, Michael
Michael Balzer -
Tom Saxton
