Re: [Ovmsdev] Update WolfSSH/SSL
Any objections to merging my update-wolfssh branch into master? -- Steve ---------- Forwarded message ---------- Date: Wed, 27 Jan 2021 18:03:42 -0800 (PST) From: Stephen Casner <casner@acm.org> Reply-To: OVMS Developers <ovmsdev@lists.openvehicles.com> To: OVMS Developers <ovmsdev@lists.openvehicles.com> Subject: Re: [Ovmsdev] Update WolfSSH/SSL On Sun, 24 Jan 2021, Michael Balzer wrote:
The higher base memory footprint due to the higher NetMan stack size + some additional buffer it seems (some 512 bytes?) means this needs to be checked with complex vehicle modules in live operation before merging, but I think that won't be an issue.
As suggested to me by WolfSSL support, there is a configuration parameter for wolfssl to use heap allocation rather than stack for some buffers and structures. With that change, I can restore the NetMan stack to 8K. Now the comparison of memory usage is as follows: - With the current master code the max NetMan stack depth on my OVMS was 5616 whereas after the update it is 5760. - With the current master code, the amount of memory added by NetMan when an ssh connection was established was 2557 D/IRAM and 6108 SPIRAM for 8665 total. With the update it was 1056 D/IRAM and 7532 SPIRAM for 8588 total. I think this change should clear the way for merging into master. -- Steve _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Stephen Casner
