Today my coolant pump was running continuously even though the charge level was only 55% and the ambient temperature was only 77F, although the battery was at 89F (32C) left over from a drive last evening. So, I decided to try cooldown again. The log is below. This time the charge current was properly managed at 12A and Range mode. The A/C fans came on soon after starting and the battery temp was reduced from 32C to 30C in 3 minutes. However, after that the temperature did not drop further, even though the templimit is currently set to 25C, except for a brief period at 29C for 3 minutes about halfway through the hour time limit before returning to 30C. I didn't monitor the whole time, but I didn't notice the A/C fans on any more. Does the Roadster not try to cool below 30C? Yet when we were testing last winter while the ambient temperature was cooler, I was able to set the templimit to 19C and the car did cool the battery from 20C to 19C in the test. Perhaps the car's goal temperature is based on some delta from the ambient temperature. This time the session correctly did not turn into a regular charging session after the cooldown time limit was reached, and the coolant pump did stop running. -- Steve Welcome to the Open Vehicle Monitoring System (OVMS) - SSH Console Firmware: 3.2.001-18-gac0ae29b-dirty/ota_1/main Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1 OVMS# config list xtr xtr (readable writeable) cooldown.templimit: 25 OVMS# log file /sd/cooldown Logging to file: /sd/cooldown OVMS# log mon Monitoring log messages enabled I (466541) ovms-server-v2: Incoming Msg: MP-0 Z0 I (493591) ovms-server-v2: Send MP-0 PAStandard - Charge Stopped|SOC: 54.0%|Ideal range: 124M|Est. range: 115M|ODO: 55912.4M OVMS# charge cooldown Cooldown has been started I (540471) v-teslaroadster: Cooldown: 0 cycles 32C/25C 12A (with 60 minute(s) remaining) I (580461) ovms-server-v2: Incoming Msg: MP-0 Z1 I (580521) ovms-server-v2: One or more peers have connected I (581471) ovms-server-v2: Send MP-0 S54.0,M,245,12,charging,range,153,142,12,0,0,0,5,1,3,0,0,0,178.49,858,0,0,0,0,0,0,0,0,0,0,0,-1.16,0.00,79 I (581541) ovms-server-v2: Send MP-0 D92,0,5,31,28,31,466,559124,0,581,23,2,1,1,12.75,0,12.6,128,31,0,0 I (581601) ovms-server-v2: Send MP-0 L37.346279,-122.037292,336,30,1,1,0,0,1.2,0,0 I (581661) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (581711) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (599471) ovms-server-v2: Send MP-0 PIRange - Charging|242.0V/12.0A|Full: 858 mins|SOC: 54.0%|Ideal range: 153M|Est. range: 142M|ODO: 55912.4M|CAC: 178.5Ah|SOH: 80% I (600471) v-teslaroadster: Cooldown: 0 cycles 31C/25C 12A (with 59 minute(s) remaining) I (600551) housekeeping: 2019-07-30 19:07:05 GMT (RAM: 8b=113788-127376 32b=10312) I (638391) ovms-server-v2: Incoming Msg: MP-0 Z0 I (660471) v-teslaroadster: Cooldown: 0 cycles 31C/25C 12A (with 58 minute(s) remaining) I (720471) v-teslaroadster: Cooldown: 0 cycles 30C/25C 12A (with 57 minute(s) remaining) I (780471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 56 minute(s) remaining) I (793471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (803471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (840471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 55 minute(s) remaining) I (853471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (863471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (900471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 54 minute(s) remaining) I (900541) housekeeping: 2019-07-30 19:12:05 GMT (RAM: 8b=113788-127084 32b=10312) I (913471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (923471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (960471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 53 minute(s) remaining) I (973471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (983471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1020471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 52 minute(s) remaining) I (1033471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1043471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1080471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 51 minute(s) remaining) I (1093471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1103471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1140471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 50 minute(s) remaining) I (1153471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1163471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1182471) ovms-server-v2: Send MP-0 S54.0,M,243,12,charging,range,155,143,12,10,0,100,5,1,3,0,0,0,178.49,875,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (1182551) ovms-server-v2: Send MP-0 D92,0,5,35,33,30,466,559124,0,1182,25,2,1,1,12.79,0,12.6,0,35,0,0 I (1182611) ovms-server-v2: Send MP-0 L37.346329,-122.037262,336,57,1,1,0,0,2.3,0,0 I (1182661) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (1200471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 49 minute(s) remaining) I (1200601) housekeeping: 2019-07-30 19:17:05 GMT (RAM: 8b=113788-127376 32b=10312) I (1213471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1223471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1260471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 48 minute(s) remaining) I (1273471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1283471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1320471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 47 minute(s) remaining) I (1333471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1343471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1380471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 46 minute(s) remaining) I (1393471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1403471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1440471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 45 minute(s) remaining) I (1453471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1463471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1500471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 44 minute(s) remaining) I (1500541) housekeeping: 2019-07-30 19:22:05 GMT (RAM: 8b=113788-127084 32b=10312) I (1513471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1523471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1560471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 43 minute(s) remaining) I (1573471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1583471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1603141) ovms-server-v2: Incoming Msg: MP-0 Z1 I (1603191) ovms-server-v2: One or more peers have connected I (1603471) ovms-server-v2: Send MP-0 S54.0,M,245,12,charging,range,156,144,12,17,0,100,5,1,3,0,0,0,178.49,864,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (1603551) ovms-server-v2: Send MP-0 D92,0,5,35,36,30,466,559124,0,1603,25,2,1,1,12.79,0,12.6,0,35,0,0 I (1603621) ovms-server-v2: Send MP-0 L37.346302,-122.037346,336,65,1,1,0,0,2.3,0,0 I (1603681) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (1603741) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (1620471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 42 minute(s) remaining) I (1631391) ovms-server-v2: Incoming Msg: MP-0 Z0 I (1633471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1643471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1680471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 41 minute(s) remaining) I (1693471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1703471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1740471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 40 minute(s) remaining) I (1753471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1763471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1800471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 39 minute(s) remaining) I (1800541) housekeeping: 2019-07-30 19:27:05 GMT (RAM: 8b=113788-127084 32b=10312) I (1813471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1823471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1860471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 38 minute(s) remaining) I (1873471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1883471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1920471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 37 minute(s) remaining) I (1933471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1943471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1980471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 36 minute(s) remaining) I (1993471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2003471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2040471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 35 minute(s) remaining) I (2053471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2063471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2100471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 34 minute(s) remaining) I (2100541) housekeeping: 2019-07-30 19:32:05 GMT (RAM: 8b=113788-127084 32b=10312) I (2113471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2123471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2141341) ovms-server-v2: Incoming Msg: MP-0 Z1 I (2141401) ovms-server-v2: One or more peers have connected I (2141471) ovms-server-v2: Send MP-0 S55.0,M,244,12,charging,range,157,146,12,26,0,100,5,1,3,0,0,0,178.49,853,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (2141531) ovms-server-v2: Send MP-0 D92,0,5,35,40,30,466,559124,0,2141,25,2,1,1,12.78,0,12.6,0,35,0,0 I (2141591) ovms-server-v2: Send MP-0 L37.346249,-122.037209,336,42,1,1,0,0,2.3,0,0 I (2141641) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (2141721) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (2160471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 33 minute(s) remaining) I (2173471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2174471) ovms-server-v2: Send MP-0 S55.0,M,245,12,charging,performance,158,146,12,27,0,100,5,1,4,0,0,0,178.49,857,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (2177381) ovms-server-v2: Incoming Msg: MP-0 Z0 I (2183471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2220471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 32 minute(s) remaining) I (2233471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2243471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2280471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 31 minute(s) remaining) I (2293471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2303471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2340471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 30 minute(s) remaining) I (2353471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2363471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2400471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 29 minute(s) remaining) I (2400531) housekeeping: 2019-07-30 19:37:06 GMT (RAM: 8b=113788-127084 32b=10312) I (2413471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2423471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2460471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 28 minute(s) remaining) I (2520471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 27 minute(s) remaining) I (2580471) v-teslaroadster: Cooldown: 2 cycles 29C/25C 12A (with 26 minute(s) remaining) I (2607471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2617471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2640471) v-teslaroadster: Cooldown: 2 cycles 29C/25C 12A (with 25 minute(s) remaining) I (2667471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2677471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2700471) v-teslaroadster: Cooldown: 2 cycles 29C/25C 12A (with 24 minute(s) remaining) I (2700541) housekeeping: 2019-07-30 19:42:06 GMT (RAM: 8b=113788-127084 32b=10312) I (2727471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2737471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2742471) ovms-server-v2: Send MP-0 S56.0,M,244,12,charging,range,159,147,12,36,0,200,5,1,3,0,0,0,178.49,842,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (2742531) ovms-server-v2: Send MP-0 D92,0,5,35,44,30,466,559124,0,2742,25,2,1,1,12.78,0,12.6,0,35,0,0 I (2742581) ovms-server-v2: Send MP-0 L37.346329,-122.037308,336,55,1,1,0,0,2.3,0,0 I (2742651) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,26,1,TR1N,Revelstoke I (2760471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 23 minute(s) remaining) I (2787471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2797471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2820471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 22 minute(s) remaining) I (2847471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2857471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2880471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 21 minute(s) remaining) I (2907471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2917471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2940471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 20 minute(s) remaining) I (2967471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2977471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3000471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 19 minute(s) remaining) I (3000541) housekeeping: 2019-07-30 19:47:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3027471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3037471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3060471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 18 minute(s) remaining) I (3087471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3097471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3120471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 17 minute(s) remaining) I (3147471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3157471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3180471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 16 minute(s) remaining) I (3207471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3217471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3240471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 15 minute(s) remaining) I (3267471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3277471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3300471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 14 minute(s) remaining) I (3300551) housekeeping: 2019-07-30 19:52:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3327471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3337471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3343471) ovms-server-v2: Send MP-0 S56.0,M,243,12,charging,range,161,149,12,46,0,200,5,1,3,0,0,0,178.49,827,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (3343531) ovms-server-v2: Send MP-0 D92,0,5,36,47,30,466,559124,0,3343,25,2,1,1,12.78,0,12.6,0,36,0,0 I (3343611) ovms-server-v2: Send MP-0 L37.346321,-122.037262,336,59,1,1,0,0,2.3,0,0 I (3343671) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (3360471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 13 minute(s) remaining) I (3387471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3397471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3420471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 12 minute(s) remaining) I (3447471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3457471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3480471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 11 minute(s) remaining) I (3507471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3517471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3540471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 10 minute(s) remaining) I (3567471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3577471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3600471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 9 minute(s) remaining) I (3600551) housekeeping: 2019-07-30 19:57:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3627471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3637471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3649701) simcom: PPP Connection disconnected I (3649751) simcom: PPP Connection disconnected I (3650471) simcom: Lost network connection (+PPP disconnect in NetMode) I (3650521) simcom: State: Enter NetLoss state I (3650571) gsm-ppp: Shutting down (hard)... I (3650631) gsm-ppp: PPP is shutdown I (3650711) netmanager: MODEM down (with WIFI client up): staying with WIFI client priority I (3655491) gsm-ppp: StatusCallBack: User Interrupt I (3655541) gsm-ppp: PPP connection has been closed I (3659471) simcom: State timeout, transition to 5 I (3659521) simcom: State: Enter NetWait state I (3660471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 8 minute(s) remaining) I (3663471) simcom: State: Enter NetStart state I (3664561) simcom: PPP Connection is ready to start I (3665471) simcom: State: Enter NetMode state I (3665521) gsm-ppp: Initialising... I (3668241) gsm-ppp: StatusCallBack: None I (3668291) gsm-ppp: status_cb: Connected I (3668351) gsm-ppp: our_ipaddr = 10.170.41.247 I (3668401) gsm-ppp: his_ipaddr = 10.64.64.64 I (3668451) gsm-ppp: netmask = 255.255.255.255 I (3668501) gsm-ppp: our6_ipaddr = :: I (3668611) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority I (3687471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3697471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3720471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 7 minute(s) remaining) I (3747471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3757471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3780471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 6 minute(s) remaining) I (3807471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3817471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3840471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 5 minute(s) remaining) I (3867471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3877471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3900471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 4 minute(s) remaining) I (3900541) housekeeping: 2019-07-30 20:02:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3927471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3937471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3944471) ovms-server-v2: Send MP-0 S57.0,M,244,12,charging,range,163,151,12,56,0,300,5,1,3,0,0,0,178.49,820,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (3944531) ovms-server-v2: Send MP-0 D92,0,5,36,50,30,466,559124,0,3944,25,2,1,1,12.79,0,12.6,0,36,0,0 I (3944601) ovms-server-v2: Send MP-0 L37.346325,-122.037338,336,55,1,1,0,0,2.3,0,0 I (3944661) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (3960471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 3 minute(s) remaining) I (3987471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3997471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (4020471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 2 minute(s) remaining) I (4047471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (4057471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (4080471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 1 minute(s) remaining) I (4080521) v-teslaroadster: Cooldown: Cycle 2 cooldown completed I (4080701) ovms-server-v2: Send MP-0 PARange - Charge Stopped|SOC: 57.0%|Ideal range: 163M|Est. range: 151M|ODO: 55912.4M|CAC: 178.5Ah|SOH: 80% I (4126971) ovms-server-v2: Incoming Msg: MP-0 Z1 I (4127031) ovms-server-v2: One or more peers have connected I (4127471) ovms-server-v2: Send MP-0 S58.0,M,65535,127,stopped,standard,133,124,32,0,0,300,3,21,0,0,0,0,178.49,812,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,79 I (4127541) ovms-server-v2: Send MP-0 D68,0,5,36,51,30,466,559124,0,4127,25,0,1,1,11.47,0,12.6,0,36,0,0 I (4127621) ovms-server-v2: Send MP-0 L37.346321,-122.037346,336,65,1,1,0,0,0.0,0,0 I (4127681) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (4127751) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (4142331) ovms-server-v2: Incoming Msg: MP-0 Z0 I (4200481) housekeeping: 2019-07-30 20:07:06 GMT (RAM: 8b=113788-127248 32b=10312) I (4420551) ovms-server-v2: Incoming Msg: MP-0 Z1 I (4420601) ovms-server-v2: One or more peers have connected I (4421471) ovms-server-v2: Send MP-0 S58.0,M,1,0,stopped,standard,133,124,32,0,0,300,2,21,0,0,0,0,178.49,812,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,79 I (4421531) ovms-server-v2: Send MP-0 D76,0,5,34,49,30,466,559124,0,4421,25,2,1,1,12.94,0,12.6,0,34,0,0 I (4421591) ovms-server-v2: Send MP-0 L37.346359,-122.037308,336,65,1,1,0,0,0.4,0,0 I (4421661) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (4421721) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (4424641) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS# log close Closed log file I (4491401) command: SetLogfile: file logging stopped I (4500481) housekeeping: 2019-07-30 20:12:06 GMT (RAM: 8b=113788-127496 32b=10312) OVMS# exit
Steve, The output looks correct. The car just only turned on the HVAC twice (2 cycles detected) in the hour. The behaviour of the VMS is pretty much voodoo in this. The cycling of RANGE/PERFORMANCE seems to work once every ten minutes or so for hot packs, but In your case it didn’t seem to want to go below 30C. That is average temperature - perhaps the control is more on min/max brick temperature? The conjecture Is that too much / quick cooling would be a bad thing as it would cause condensation within the pack/ Below 31C should be fine to turn off the little coolant pump. Regards, Mark.
OVMS# config list xtr xtr (readable writeable) cooldown.templimit: 25 OVMS# log file /sd/cooldown Logging to file: /sd/cooldown OVMS# log mon Monitoring log messages enabled I (466541) ovms-server-v2: Incoming Msg: MP-0 Z0 I (493591) ovms-server-v2: Send MP-0 PAStandard - Charge Stopped|SOC: 54.0%|Ideal range: 124M|Est. range: 115M|ODO: 55912.4M OVMS# charge cooldown Cooldown has been started I (540471) v-teslaroadster: Cooldown: 0 cycles 32C/25C 12A (with 60 minute(s) remaining) I (580461) ovms-server-v2: Incoming Msg: MP-0 Z1 I (580521) ovms-server-v2: One or more peers have connected I (581471) ovms-server-v2: Send MP-0 S54.0,M,245,12,charging,range,153,142,12,0,0,0,5,1,3,0,0,0,178.49,858,0,0,0,0,0,0,0,0,0,0,0,-1.16,0.00,79 I (581541) ovms-server-v2: Send MP-0 D92,0,5,31,28,31,466,559124,0,581,23,2,1,1,12.75,0,12.6,128,31,0,0 I (581601) ovms-server-v2: Send MP-0 L37.346279,-122.037292,336,30,1,1,0,0,1.2,0,0 I (581661) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (581711) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (599471) ovms-server-v2: Send MP-0 PIRange - Charging|242.0V/12.0A|Full: 858 mins|SOC: 54.0%|Ideal range: 153M|Est. range: 142M|ODO: 55912.4M|CAC: 178.5Ah|SOH: 80% I (600471) v-teslaroadster: Cooldown: 0 cycles 31C/25C 12A (with 59 minute(s) remaining) I (600551) housekeeping: 2019-07-30 19:07:05 GMT (RAM: 8b=113788-127376 32b=10312) I (638391) ovms-server-v2: Incoming Msg: MP-0 Z0 I (660471) v-teslaroadster: Cooldown: 0 cycles 31C/25C 12A (with 58 minute(s) remaining) I (720471) v-teslaroadster: Cooldown: 0 cycles 30C/25C 12A (with 57 minute(s) remaining) I (780471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 56 minute(s) remaining) I (793471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (803471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (840471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 55 minute(s) remaining) I (853471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (863471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (900471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 54 minute(s) remaining) I (900541) housekeeping: 2019-07-30 19:12:05 GMT (RAM: 8b=113788-127084 32b=10312) I (913471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (923471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (960471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 53 minute(s) remaining) I (973471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (983471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1020471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 52 minute(s) remaining) I (1033471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1043471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1080471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 51 minute(s) remaining) I (1093471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1103471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1140471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 50 minute(s) remaining) I (1153471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1163471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1182471) ovms-server-v2: Send MP-0 S54.0,M,243,12,charging,range,155,143,12,10,0,100,5,1,3,0,0,0,178.49,875,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (1182551) ovms-server-v2: Send MP-0 D92,0,5,35,33,30,466,559124,0,1182,25,2,1,1,12.79,0,12.6,0,35,0,0 I (1182611) ovms-server-v2: Send MP-0 L37.346329,-122.037262,336,57,1,1,0,0,2.3,0,0 I (1182661) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (1200471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 49 minute(s) remaining) I (1200601) housekeeping: 2019-07-30 19:17:05 GMT (RAM: 8b=113788-127376 32b=10312) I (1213471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1223471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1260471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 48 minute(s) remaining) I (1273471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1283471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1320471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 47 minute(s) remaining) I (1333471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1343471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1380471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 46 minute(s) remaining) I (1393471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1403471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1440471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 45 minute(s) remaining) I (1453471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1463471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1500471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 44 minute(s) remaining) I (1500541) housekeeping: 2019-07-30 19:22:05 GMT (RAM: 8b=113788-127084 32b=10312) I (1513471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1523471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1560471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 43 minute(s) remaining) I (1573471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1583471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1603141) ovms-server-v2: Incoming Msg: MP-0 Z1 I (1603191) ovms-server-v2: One or more peers have connected I (1603471) ovms-server-v2: Send MP-0 S54.0,M,245,12,charging,range,156,144,12,17,0,100,5,1,3,0,0,0,178.49,864,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (1603551) ovms-server-v2: Send MP-0 D92,0,5,35,36,30,466,559124,0,1603,25,2,1,1,12.79,0,12.6,0,35,0,0 I (1603621) ovms-server-v2: Send MP-0 L37.346302,-122.037346,336,65,1,1,0,0,2.3,0,0 I (1603681) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (1603741) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (1620471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 42 minute(s) remaining) I (1631391) ovms-server-v2: Incoming Msg: MP-0 Z0 I (1633471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1643471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1680471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 41 minute(s) remaining) I (1693471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1703471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1740471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 40 minute(s) remaining) I (1753471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1763471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1800471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 39 minute(s) remaining) I (1800541) housekeeping: 2019-07-30 19:27:05 GMT (RAM: 8b=113788-127084 32b=10312) I (1813471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1823471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1860471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 38 minute(s) remaining) I (1873471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1883471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1920471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 37 minute(s) remaining) I (1933471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (1943471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (1980471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 36 minute(s) remaining) I (1993471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2003471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2040471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 35 minute(s) remaining) I (2053471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2063471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2100471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 34 minute(s) remaining) I (2100541) housekeeping: 2019-07-30 19:32:05 GMT (RAM: 8b=113788-127084 32b=10312) I (2113471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2123471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2141341) ovms-server-v2: Incoming Msg: MP-0 Z1 I (2141401) ovms-server-v2: One or more peers have connected I (2141471) ovms-server-v2: Send MP-0 S55.0,M,244,12,charging,range,157,146,12,26,0,100,5,1,3,0,0,0,178.49,853,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (2141531) ovms-server-v2: Send MP-0 D92,0,5,35,40,30,466,559124,0,2141,25,2,1,1,12.78,0,12.6,0,35,0,0 I (2141591) ovms-server-v2: Send MP-0 L37.346249,-122.037209,336,42,1,1,0,0,2.3,0,0 I (2141641) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (2141721) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (2160471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 33 minute(s) remaining) I (2173471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2174471) ovms-server-v2: Send MP-0 S55.0,M,245,12,charging,performance,158,146,12,27,0,100,5,1,4,0,0,0,178.49,857,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (2177381) ovms-server-v2: Incoming Msg: MP-0 Z0 I (2183471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2220471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 32 minute(s) remaining) I (2233471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2243471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2280471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 31 minute(s) remaining) I (2293471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2303471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2340471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 30 minute(s) remaining) I (2353471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2363471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2400471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 29 minute(s) remaining) I (2400531) housekeeping: 2019-07-30 19:37:06 GMT (RAM: 8b=113788-127084 32b=10312) I (2413471) v-teslaroadster: Cooldown: Cycle 1 PERFORMANCE mode I (2423471) v-teslaroadster: Cooldown: Cycle 1 RANGE mode I (2460471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 28 minute(s) remaining) I (2520471) v-teslaroadster: Cooldown: 1 cycles 30C/25C 12A (with 27 minute(s) remaining) I (2580471) v-teslaroadster: Cooldown: 2 cycles 29C/25C 12A (with 26 minute(s) remaining) I (2607471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2617471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2640471) v-teslaroadster: Cooldown: 2 cycles 29C/25C 12A (with 25 minute(s) remaining) I (2667471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2677471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2700471) v-teslaroadster: Cooldown: 2 cycles 29C/25C 12A (with 24 minute(s) remaining) I (2700541) housekeeping: 2019-07-30 19:42:06 GMT (RAM: 8b=113788-127084 32b=10312) I (2727471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2737471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2742471) ovms-server-v2: Send MP-0 S56.0,M,244,12,charging,range,159,147,12,36,0,200,5,1,3,0,0,0,178.49,842,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (2742531) ovms-server-v2: Send MP-0 D92,0,5,35,44,30,466,559124,0,2742,25,2,1,1,12.78,0,12.6,0,35,0,0 I (2742581) ovms-server-v2: Send MP-0 L37.346329,-122.037308,336,55,1,1,0,0,2.3,0,0 I (2742651) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,26,1,TR1N,Revelstoke I (2760471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 23 minute(s) remaining) I (2787471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2797471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2820471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 22 minute(s) remaining) I (2847471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2857471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2880471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 21 minute(s) remaining) I (2907471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2917471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (2940471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 20 minute(s) remaining) I (2967471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (2977471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3000471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 19 minute(s) remaining) I (3000541) housekeeping: 2019-07-30 19:47:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3027471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3037471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3060471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 18 minute(s) remaining) I (3087471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3097471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3120471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 17 minute(s) remaining) I (3147471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3157471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3180471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 16 minute(s) remaining) I (3207471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3217471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3240471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 15 minute(s) remaining) I (3267471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3277471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3300471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 14 minute(s) remaining) I (3300551) housekeeping: 2019-07-30 19:52:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3327471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3337471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3343471) ovms-server-v2: Send MP-0 S56.0,M,243,12,charging,range,161,149,12,46,0,200,5,1,3,0,0,0,178.49,827,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (3343531) ovms-server-v2: Send MP-0 D92,0,5,36,47,30,466,559124,0,3343,25,2,1,1,12.78,0,12.6,0,36,0,0 I (3343611) ovms-server-v2: Send MP-0 L37.346321,-122.037262,336,59,1,1,0,0,2.3,0,0 I (3343671) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (3360471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 13 minute(s) remaining) I (3387471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3397471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3420471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 12 minute(s) remaining) I (3447471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3457471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3480471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 11 minute(s) remaining) I (3507471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3517471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3540471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 10 minute(s) remaining) I (3567471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3577471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3600471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 9 minute(s) remaining) I (3600551) housekeeping: 2019-07-30 19:57:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3627471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3637471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3649701) simcom: PPP Connection disconnected I (3649751) simcom: PPP Connection disconnected I (3650471) simcom: Lost network connection (+PPP disconnect in NetMode) I (3650521) simcom: State: Enter NetLoss state I (3650571) gsm-ppp: Shutting down (hard)... I (3650631) gsm-ppp: PPP is shutdown I (3650711) netmanager: MODEM down (with WIFI client up): staying with WIFI client priority I (3655491) gsm-ppp: StatusCallBack: User Interrupt I (3655541) gsm-ppp: PPP connection has been closed I (3659471) simcom: State timeout, transition to 5 I (3659521) simcom: State: Enter NetWait state I (3660471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 8 minute(s) remaining) I (3663471) simcom: State: Enter NetStart state I (3664561) simcom: PPP Connection is ready to start I (3665471) simcom: State: Enter NetMode state I (3665521) gsm-ppp: Initialising... I (3668241) gsm-ppp: StatusCallBack: None I (3668291) gsm-ppp: status_cb: Connected I (3668351) gsm-ppp: our_ipaddr = 10.170.41.247 I (3668401) gsm-ppp: his_ipaddr = 10.64.64.64 I (3668451) gsm-ppp: netmask = 255.255.255.255 I (3668501) gsm-ppp: our6_ipaddr = :: I (3668611) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority I (3687471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3697471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3720471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 7 minute(s) remaining) I (3747471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3757471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3780471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 6 minute(s) remaining) I (3807471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3817471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3840471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 5 minute(s) remaining) I (3867471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3877471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3900471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 4 minute(s) remaining) I (3900541) housekeeping: 2019-07-30 20:02:06 GMT (RAM: 8b=113788-127084 32b=10312) I (3927471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3937471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (3944471) ovms-server-v2: Send MP-0 S57.0,M,244,12,charging,range,163,151,12,56,0,300,5,1,3,0,0,0,178.49,820,0,0,0,0,0,0,0,0,0,0,0,-2.32,0.00,79 I (3944531) ovms-server-v2: Send MP-0 D92,0,5,36,50,30,466,559124,0,3944,25,2,1,1,12.79,0,12.6,0,36,0,0 I (3944601) ovms-server-v2: Send MP-0 L37.346325,-122.037338,336,55,1,1,0,0,2.3,0,0 I (3944661) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (3960471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 3 minute(s) remaining) I (3987471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (3997471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (4020471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 2 minute(s) remaining) I (4047471) v-teslaroadster: Cooldown: Cycle 2 PERFORMANCE mode I (4057471) v-teslaroadster: Cooldown: Cycle 2 RANGE mode I (4080471) v-teslaroadster: Cooldown: 2 cycles 30C/25C 12A (with 1 minute(s) remaining) I (4080521) v-teslaroadster: Cooldown: Cycle 2 cooldown completed I (4080701) ovms-server-v2: Send MP-0 PARange - Charge Stopped|SOC: 57.0%|Ideal range: 163M|Est. range: 151M|ODO: 55912.4M|CAC: 178.5Ah|SOH: 80% I (4126971) ovms-server-v2: Incoming Msg: MP-0 Z1 I (4127031) ovms-server-v2: One or more peers have connected I (4127471) ovms-server-v2: Send MP-0 S58.0,M,65535,127,stopped,standard,133,124,32,0,0,300,3,21,0,0,0,0,178.49,812,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,79 I (4127541) ovms-server-v2: Send MP-0 D68,0,5,36,51,30,466,559124,0,4127,25,0,1,1,11.47,0,12.6,0,36,0,0 I (4127621) ovms-server-v2: Send MP-0 L37.346321,-122.037346,336,65,1,1,0,0,0.0,0,0 I (4127681) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (4127751) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (4142331) ovms-server-v2: Incoming Msg: MP-0 Z0 I (4200481) housekeeping: 2019-07-30 20:07:06 GMT (RAM: 8b=113788-127248 32b=10312) I (4420551) ovms-server-v2: Incoming Msg: MP-0 Z1 I (4420601) ovms-server-v2: One or more peers have connected I (4421471) ovms-server-v2: Send MP-0 S58.0,M,1,0,stopped,standard,133,124,32,0,0,300,2,21,0,0,0,0,178.49,812,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,79 I (4421531) ovms-server-v2: Send MP-0 D76,0,5,34,49,30,466,559124,0,4421,25,2,1,1,12.94,0,12.6,0,34,0,0 I (4421591) ovms-server-v2: Send MP-0 L37.346359,-122.037308,336,65,1,1,0,0,0.4,0,0 I (4421661) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0 I (4421721) ovms-server-v2: Send MP-0 F3.2.001-18-gac0ae29b-dirty/ota_1/main (build idf v3.1-dev-2835-g151269458-dirty May 23 2019 17:16:23),5YJRE11B181000033,25,1,TR1N,Revelstoke I (4424641) ovms-server-v2: Incoming Msg: MP-0 Z0 OVMS# log close Closed log file I (4491401) command: SetLogfile: file logging stopped I (4500481) housekeeping: 2019-07-30 20:12:06 GMT (RAM: 8b=113788-127496 32b=10312) OVMS# exit _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Mark, Thanks. I've changed the templimit to 30. The setting of 25 was probably left over from the testing we were doing last winter. -- Steve On Wed, 31 Jul 2019, Mark Webb-Johnson wrote:
Steve,
The behaviour of the VMS is pretty much voodoo in this. The cycling of RANGE/PERFORMANCE seems to work once every ten minutes or so for hot packs, but In your case it didn't seem to want to go below 30C. That is average temperature - perhaps the control is more on min/max brick temperature? The conjecture Is that too much / quick cooling would be a bad thing as it would cause condensation within the pack/
A week or two ago I ran cooldown on the Roadster with the templimit set to 30. The battery temp was brought down to 31 but not 30, so I decided to restore the templimit to the default 31. Then today the coolant pump was running again, even though the battery was at 52% SOC and cooler ambient temps that the heat spell we were having. So I decided to try cooldown again, but got "Error: Could not start cooldown" because the battery temp was already 31. So maybe that default is not low enough even though cooldown may not be able to push the temp lower. I changed the limit to 30 again and this time cooldown ran successfully for 2 minutes to cool the battery to 30 and stop the pump. I think it would be helpful to have a more specific message than "Error: Could not start cooldown". I see that message is printed in the vehicle base code where information about the cause of the error is not available. Would it be reasonable to additionally log a more specific message within the vehicle_teslaroadster code to distinguish the three possible causes of that error message? If so, I will add that. -- Steve On Wed, 31 Jul 2019, Stephen Casner wrote:
Mark,
Steve,
Steve, I’ve been trying to cool down a roadster, and can’t get it below 30C. I suspect the car behaves differently once that limit is hit, and our cooldown tricks are not as helpful. Glad for you to help improve the error reporting on this. Let me know if you need anything. Regards, Mark.
Mark,
Steve,
Mark Webb-Johnson -
Stephen Casner
