wolfssl has been converted to a git submodule
Dear all, The PR https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/887 which converts wolfssl to a git submodule has been merged to master. For those that build / sync their trees manually, please ensure that you do `git submodule update --init --recursive` after the git pull, so that you can properly retrieve the submodule. You can confirm that everything is OK by doing: $ git submodule status 7b953e7ebb440ce9461ee469159c3759450e7c98 components/mongoose/mongoose (6.2-882-g7b953e7) c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 components/wolfssh/wolfssh (v1.4.10-stable) 2d5a0ccae50a2ea32fc933d707b465520cc90011 components/wolfssl/wolfssl (v4.7.0-stable-5-g2d5a0ccae) 7c3878f8302c0e84578a67473e49e60bc6b3ada7 components/zip/libzip (rel-1-5-1-60-g7c3878f) d6bcf4ca4d02479f058fff44cfd171f928148179 components/zip/zlib (v1.2.11-65-gd6bcf4c) It should print (3rd line) a version of v4.7.0-stable-5-g2d5a0ccae. If instead you see: $ git submodule status 7b953e7ebb440ce9461ee469159c3759450e7c98 components/mongoose/mongoose (6.2-882-g7b953e7) c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 components/wolfssh/wolfssh (v1.4.10-stable) -2d5a0ccae50a2ea32fc933d707b465520cc90011 components/wolfssl/wolfssl 7c3878f8302c0e84578a67473e49e60bc6b3ada7 components/zip/libzip (rel-1-5-1-60-g7c3878f) d6bcf4ca4d02479f058fff44cfd171f928148179 components/zip/zlib (v1.2.11-65-gd6bcf4c) then you need to use `git submodule update --init --recursive` Let me know if it's not working according to the plan. Regards,
Hi, when I run git submodule status, I get the following output: /$ git submodule status 7b953e7ebb440ce9461ee469159c3759450e7c98 vehicle/OVMS.V3/components/mongoose/mongoose (6.2-882-g7b953e7) c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 vehicle/OVMS.V3/components/wolfssh/wolfssh (v1.4.10-stable) 9ffa9faecda87a7c0ce7521c83996c65d4e86943 vehicle/OVMS.V3/components/wolfssl/wolfssl (v*5.6.2*-stable) 7c3878f8302c0e84578a67473e49e60bc6b3ada7 vehicle/OVMS.V3/components/zip/libzip (rel-1-5-1-60-g7c3878f) d6bcf4ca4d02479f058fff44cfd171f928148179 vehicle/OVMS.V3/components/zip/zlib (v1.2.11-65-gd6bcf4c)/ I had the problem that after a git pull wolfssl was removed from my local source. git submodule status then showed: $ git submodule status 23e018e58f15a238c8c77ebdf724a2b18ad5f28a vehicle/OVMS.V3/components/mongoose/mongoose (6.2-880-g23e018e) c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 vehicle/OVMS.V3/components/wolfssh/wolfssh (v1.4.10-stable) 6ffb692964ec2dc7fae21790fb5bb13b4ef2ed94 vehicle/OVMS.V3/components/zip/libzip (rel-1-5-1-58-g6ffb692) d6bcf4ca4d02479f058fff44cfd171f928148179 vehicle/OVMS.V3/components/zip/zlib (v1.2.11-65-gd6bcf4c) I then ran 'git submodule update --init --recursive' as described. But although the module was present in .gitmodules, it was not downloaded. I then used $ git submodule add https://github.com/openvehicles/wolfssl.git vehicle/OVMS.V3/components/wolfssl/wolfssl to add it manually. But now my code no longer compiles. I get the following error message during compile make[1]: *** No rule to make target 'wolfssl/wolfcrypt/src/hc128.o', needed by 'libwolfssl.a'. Stop. Is it because I now have version v5.6.2 of wolfssl instead of the expected submodule version v4.7.0? How can I get my submobules to be included in the required version again? I would be grateful for any help! Kind regards, Simon Am 17.05.2023 um 23:24 schrieb Ludovic LANGE:
Dear all,
If instead you see:
Not sure what is going on for you. I just did a submodule update —init and —recursive, and get: $ git submodule status 7b953e7ebb440ce9461ee469159c3759450e7c98 components/mongoose/mongoose (6.2-882-g7b953e7) c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 components/wolfssh/wolfssh (v1.4.10-stable) 2d5a0ccae50a2ea32fc933d707b465520cc90011 components/wolfssl/wolfssl (v4.7.0-stable-5-g2d5a0ccae) 7c3878f8302c0e84578a67473e49e60bc6b3ada7 components/zip/libzip (rel-1-5-1-60-g7c3878f) d6bcf4ca4d02479f058fff44cfd171f928148179 components/zip/zlib (v1.2.11-65-gd6bcf4c) I think v4.7.0 should be correct for wolfssl. Regards, Mark.
On 19 Feb 2024, at 4:29 AM, Simon Ehlen <ovms@highteq.de> wrote:
Hi,
when I run git submodule status, I get the following output: $ git submodule status 7b953e7ebb440ce9461ee469159c3759450e7c98 vehicle/OVMS.V3/components/mongoose/mongoose (6.2-882-g7b953e7) c05f6c7530a8670e3d0ffdf04ee4cecb2d3b0496 vehicle/OVMS.V3/components/wolfssh/wolfssh (v1.4.10-stable) 9ffa9faecda87a7c0ce7521c83996c65d4e86943 vehicle/OVMS.V3/components/wolfssl/wolfssl (v5.6.2-stable) 7c3878f8302c0e84578a67473e49e60bc6b3ada7 vehicle/OVMS.V3/components/zip/libzip (rel-1-5-1-60-g7c3878f) d6bcf4ca4d02479f058fff44cfd171f928148179 vehicle/OVMS.V3/components/zip/zlib (v1.2.11-65-gd6bcf4c)
Kind regards, Simon
Dear all,
If instead you see:
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Hi Mark, when I look at the version.h from the master branch that is referenced as submodule, it also says 5.6.2. https://github.com/openvehicles/wolfssl/blob/master/wolfssl/version.h #define LIBWOLFSSL_VERSION_STRING "5.6.2" [submodule "vehicle/OVMS.V3/components/wolfssl/wolfssl"] path = vehicle/OVMS.V3/components/wolfssl/wolfssl url = https://github.com/openvehicles/wolfssl.git Kind regards, Simon Am 19.02.2024 um 09:26 schrieb Mark Webb-Johnson:
Hi,
Kind regards, Simon
Dear all,
If instead you see:
Ludovic LANGE -
Mark Webb-Johnson -
Simon Ehlen
