It appears that you cannot set a configuration value with a name containing spaces. It almost works, but it doesn't seem to store them correctly: OVMS > config set wifi.ssid "Wifi With Spaces" secretpassword OVMS > config list wifi.ssid wifi.ssid AndroidAP Wifi With Spaces OVMS > wifi mode client "Wifi with spaces" Error: SSID password must be defined in config wifi.ssid So it thinks it has a configuration value for that network but it doesn't work. When you reboot the OVMS you find that the configuration item was stored with only the first word of the SSID: OVMS > config list wifi.ssid wifi.ssid AndroidAP Wifi
Observant readers will notice that I made a spelling mistake in the wifi mode client call to demonstrate the problem, it doesn't work with the same error even if you spell the ssid correctly. On 19/11/17 16:12, Tom Parker wrote:
OVMS > config list wifi.ssid wifi.ssid AndroidAP Wifi _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Nasty. The config system currently uses a space as a the separator between the instance and it’s value. I’ve changed it to a tab character, in what I think is a backwards compatible way. Please try with latest. Regards, Mark.
Mark Webb-Johnson -
Tom Parker
