As I commented on Issue #99, I created the problem with SIMCOM not powering off because I had excluded CONFIG_OVMS_COMP_MAX7317 from the config and the power to the SIMCOM is controlled through the MAX7317 chip. Would it make sense in Kconfig for config OVMS_COMP_MODEM_SIMCOM to depend upon OVMS_COMP_MAX7317? -- Steve
Steve, Makes sense. I’ve added it to the Kconfig. Regards, Mark.
-- Steve _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Well, it may not be quite so simple. Unconfiguring MAX7317 then results in a compilation error: /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/ovms_webserver/src/web_cfg.cpp: In static member function 'static void OvmsWebServer::HandleCfgFirmware(PageEntry_t&, PageContext_t&)': /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/ovms_webserver/src/web_cfg.cpp:1459:7: error: 'netif_default' was not declared in this scope if (netif_default) { ^ make[1]: *** [src/web_cfg.o] Error 1 make: *** [component-ovms_webserver-build] Error 2 -- Steve On Thu, 3 May 2018, Mark Webb-Johnson wrote:
Steve,
Makes sense. I've added it to the Kconfig.
A simple one. Fix committed now. Regards, Mark
Steve,
Mark Webb-Johnson -
Stephen Casner
