My OVMS module arrived yesterday, so I'm going to be setting it up for the LEAF this week. Is the current leaf version on Git hub? Can someone send me the flash-ready firmware? Nikki. Sent from my iPhone
Nikki, The code, as committed now, tries to get SOC from message 0x55b on the CAR can bus. The problem is that, even though it is documented as appearing on the CAR CAN bus, I can’t see it in any of the logs I took from the 2011 Leaf here in Hong Kong. I am re-working the code to use polling mode, which will bridge CAR can to EV can and let us get true GIDS. I should have this working, and ready for testing, sometime in the next few days / week at worst. My initial code needs DIAG mode and a serial console (serial-to-usb adaptor), to output the information on what it is doing. You will need a laptop and serial-to-usb adaptor to see what is going on. I can send you a .hex for this, as soon as I get it going. Regards, Mark. On 10 Nov, 2013, at 5:27 pm, Nikki Gordon-Bloomfield <nikki@littlecollie.com> wrote:
Nikki. Sent from my iPhone _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Mark, Can you make the .hex file available to me as well. Regards, Rob ---- On Sun, 10 Nov 2013 14:07:13 +0100 Mark Webb-Johnson<mark@webb-johnson.net> wrote ---- Nikki, The code, as committed now, tries to get SOC from message 0x55b on the CAR can bus. The problem is that, even though it is documented as appearing on the CAR CAN bus, I can’t see it in any of the logs I took from the 2011 Leaf here in Hong Kong. I am re-working the code to use polling mode, which will bridge CAR can to EV can and let us get true GIDS. I should have this working, and ready for testing, sometime in the next few days / week at worst. My initial code needs DIAG mode and a serial console (serial-to-usb adaptor), to output the information on what it is doing. You will need a laptop and serial-to-usb adaptor to see what is going on. I can send you a .hex for this, as soon as I get it going. Regards, Mark. On 10 Nov, 2013, at 5:27 pm, Nikki Gordon-Bloomfield <nikki@littlecollie.com> wrote: > My OVMS module arrived yesterday, so I'm going to be setting it up for the LEAF this week. > > Is the current leaf version on Git hub? Can someone send me the flash-ready firmware? > > Nikki. > Sent from my iPhone > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Mark Webb-Johnson -
Nikki Gordon-Bloomfield -
Robert Sharpe
