Jack, Looks good: 2012-02-19 13:00:33.288461 +0800 info main: #10 C 1237 rx msg S 73,M,-1,0,prepare,standard,141,99,12,0,100,0,7,13,0 2012-02-19 13:03:03.284167 +0800 info main: #10 C 1237 rx msg S 73,M,-1,127,prepare,standard,141,99,12,65535,100,0,7,13,0 2012-02-19 13:03:07.059278 +0800 info main: #10 C 1237 rx msg S 73,M,-1,127,prepare,standard,141,99,12,65535,100,0,7,13,0 2012-02-19 13:03:42.004698 +0800 info main: #10 C 1237 rx msg S 73,M,-1,127,prepare,standard,141,99,12,65535,100,0,7,13,0 2012-02-19 13:04:42.149139 +0800 info main: #10 C 1237 rx msg S 73,M,-1,127,prepare,standard,141,99,12,65535,100,0,7,13,0 2012-02-19 13:04:58.848701 +0800 info main: #10 C 1237 rx msg S 73,M,-1,0,prepare,standard,141,99,12,0,100,0,7,13,0 2012-02-19 13:05:03.692352 +0800 info main: #10 C 1237 rx msg S 73,M,-1,0,prepare,standard,141,99,12,0,100,0,7,13,0 2012-02-19 13:05:10.936363 +0800 info main: #10 C 1237 rx msg S 73,M,1,0,prepare,standard,141,99,12,0,100,0,7,13,0 2012-02-19 13:05:16.909696 +0800 info main: #10 C 1237 rx msg S 73,M,0,0,heating,standard,141,99,12,0,11,0,11,15,0 2012-02-19 13:05:20.229710 +0800 info main: #10 C 1237 rx msg S 73,M,1,0,heating,standard,141,99,12,0,11,0,11,15,0 2012-02-19 13:07:34.699594 +0800 info main: #10 C 1237 rx msg S 73,M,251,7,heating,standard,141,99,12,0,13,0,11,15,0 2012-02-19 13:07:56.605184 +0800 info main: #10 C 1237 rx msg S 72,M,237,7,heating,standard,139,99,12,0,13,0,11,15,0 2012-02-19 13:08:47.265994 +0800 info main: #10 C 1237 rx msg S 72,M,238,8,heating,standard,139,99,12,0,13,0,11,15,0 2012-02-19 13:08:58.259495 +0800 info main: #10 C 1237 rx msg S 73,M,238,7,heating,standard,139,99,12,0,13,0,11,15,0 2012-02-19 13:09:26.768173 +0800 info main: #10 C 1237 rx msg S 73,M,237,7,heating,standard,139,99,12,0,13,0,11,15,0 2012-02-19 13:09:52.005598 +0800 info main: #10 C 1237 rx msg S 73,M,237,8,heating,standard,139,99,12,0,13,0,11,15,0 2012-02-19 13:11:01.340287 +0800 info main: #10 C 1237 rx msg S 73,M,238,7,heating,standard,139,99,12,0,13,0,11,15,0 2012-02-19 13:14:47.905323 +0800 info main: #10 C 1237 rx msg S 72,M,0,0,stopped,standard,139,99,12,0,100,0,3,21,0 2012-02-19 13:14:51.508543 +0800 info main: #10 C 1237 rx msg S 73,M,1,0,stopped,standard,139,99,12,0,100,0,3,21,0 That shows charge state 0x0f -> 0x15 (heating -> stopped charging), with sub-states 11->3(heating->by-request). So, for heating mode with VDS STOP we get heating->stopped with sub-state by-request. Very similar to the charging mode. This should NOT alert with our current logic, and should be ok. Can you try those few (red) lines of code I sent you a few hours ago? If you slide-to-stop during heating, with those lines in place, you should get an alert. Regards, Mark. On 19 Feb, 2012, at 1:16 PM, Jack West wrote:
I shut off the heating " by request" at 1:11HK time
Hopefully that worked. Seems our cell service is worse that usual at the moment
Jack
