Hi folks, Hope you’re all keeping well and that your holidays have been lovely so far! I’ve been watching the OVMS project for just over a year since Mercedes announced they were going to shut down the Smart EQ servers (UK 453 Brabus). Then, we got my mum a module for Christmas so finally getting to play with it properly 😄 However, I’m having some trouble with the V2 server. I’m using Dexter’s cloud server for now (thank you for hosting it!) with the aim to set Mum up with the Quarz iOS app (https://apps.apple.com/gb/app/quarz/id6740280553). <https://apps.apple.com/gb/app/quarz/id6740280553> If I start V2 on the module, it either crashes instantly or does so within a few minutes. If I enable autostart on it, it boot loops for a minute and then needs a manual reboot. Not so bad in the summer but having to go back outside to the car in 1°C weather isn’t my idea of fun 😂 Problem is: when it crashes, there’s no crash data. Last crash: IllegalInstruction exception on core 0 Registers: PC : 0x00000000 PS : 0x00000000 A0 : 0x00000000 A1 : 0x00000000 A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000000 A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000000 A9 : 0x00000000 A10 : 0x00000000 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x00000000 A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Backtrace: Version: 3.3.005-536-g20a42926/ota_1/edge (build idf v3.3.4-851-gfa4f07fb3b Dec 25 2025 16:43:35) Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600 Despite all this, I’m having no such issues with V3/MQTT. I’m happy to use that - and I intend to integrate it with Home Assistant so probably would aim for that in general, but the data usage is *so* much lower on V2 - and with a Hologram SIM, that’s pretty important - that I’d have preferred to go down that path. Any ideas as to why it could be crashing? Best wishes and kind regards, Aaron *Aaron Carson** (he/him)* ✉️ : aaron@aaroncarson.co.uk 💻 : aaroncarson.co.uk <https://www.aaroncarson.co.uk/> 🔑 : 715E 0332 F7E1 E0F1 <https://keys.openpgp.org/vks/v1/by-fingerprint/45982EB56486CED008DAED0D715E0332F7E1E0F1>
Welcome, Aaron. Sorry, no idea about the crash, the V2 client is normally very stable and tolerates all kinds of misconfigurations. Please catch the USB console log during a crash, which will likely show crash details. We try to carry crash details over the reboot in SRAM, but that doesn't work under all circumstances. Check the log for any warnings or error indicators. Possibly try log level debug or verbose to see more details. Also, do you actually need the car connection to reproduce the crash, and does it only occur with the SQ vehicle, or does it also happen with e.g. the NONE vehicle on your desk? Regards, Michael Am 27.12.25 um 14:33 schrieb Aaron Carson via OvmsDev:
Hi folks,
Aaron
*Aaron Carson*/ (he/him)/
✉️ : aaron@aaroncarson.co.uk <mailto:aaron@aaroncarson.co.uk> 💻 : aaroncarson.co.uk <https://www.aaroncarson.co.uk/> 🔑 : 715E 0332 F7E1 E0F1 <https://keys.openpgp.org/vks/v1/by-fingerprint/45982EB56486CED008DAED0D715E0332F7E1E0F1>
-- Michael Balzer * Am Rahmen 5 * D-58313 Herdecke Fon 02330 9104094 * Handy 0176 20698926
Aaron, I see that you don’t have DNS configured. Best to set that as 8.8.8.8 to avoid issues with switching between wifi and cellular dns providers. Please also check to ensure that you don’t have any custom scripts configured. Regards, Mark.
On 28 Dec 2025, at 12:24 AM, Aaron Carson <aaron@aaroncarson.co.uk> wrote:
Hi both,
Thanks very much for getting back to me so quickly!
I have now tried turning off TLS/SSL - and unfortunately it crashed immediately upon hitting start server.
Module summary is below. If anything obviously wrong sticks out, I’d be very appreciative if you could spare the time to check and let me know.
I’ll catch the USB logs as soon as I can - same with a NONE vehicle, haven’t tried any of that yet. It might well be that any issues make themselves obvious at that point!
Thanks again - really excited for the potential of OVMS!
Aaron
OVMS MODULE SUMMARY
Module Version: 3.3.005-536-g20a42926/ota_1/edge (build idf v3.3.4-851-gfa4f07fb3b Dec 25 2025 16:43:35) Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600 Free RAM: 8bit=57212-58652 32bit=12128 SPIRAM=3225048-3244984 bytes 12V: 11.9V
Storage /store: Size: 976 kB Avail: 896 kB Used: 9%
WIFI Status Power: on Mode: Access-Point + Client mode
STA SSID: **redacted** (-78.2 dBm) [fixed] MAC: 00:4b:12:... IP: 10.75.0.247/255.255.0.0 GW: 10.75.0.1 AP: ba:fb:e4:c4:1b:6f
AP SSID: **redacted** (20 MHz, channel 6) MAC: 00:4b:12:... IP: 192.168.4.1 AP Stations: 0
MODEM Status Model: SIM7600 Revision: Network Registration: Unknown Provider: Signal: 0 dBm Mode: State: PoweredOn Ticker: 0 User Data: 0 UART: FIFO overflows: 0 Buffer overflows: 0 Parity errors: 0 Frame errors: 0 Driver Buffer overflows: 0 State Timeout Goto: PoweringOn (in 40 seconds) Mux: Not running PPP: Not running GPS: Not running
Configuration [auto] dbc: no egpio: no ext12v: no init: yes modem: yes obd2ecu: ota: yes scripting: yes server.v2: no server.v3: no vehicle.type: SQ wifi.mode: apclient wifi.ssid.ap: **redacted** wifi.ssid.client: **redacted** [can] [dbc] [egpio] monitor.ports: [http.plugin] [http.server] [locations] Home: **redacted** [log] [modem] apn: hologram apn.password: apn.user: enable.gps: yes enable.gpstime: yes enable.net: yes enable.sms: yes gps.parkpause: 600 gps.parkreactawake: yes gps.parkreactivate: 50 gps.parkreactlock: 5 net.type: auto pincode: [module] cfgversion: 2022121400 init: done [network] dns: modem.sq.bad: -103 modem.sq.good: -93 type: 4G wifi.ap2client.enable: yes wifi.sq.bad: -95 [notify] [obd2ecu] [obd2ecu.map] [ota] auto.allow.modem: no auto.hour: 2 http.mru: https://ovms.dexters-web.de/firmware/ota/v3.3/edge/ovms3.bin server: https://ovms.dexters-web.de/firmware/ota tag: edge [password] module: **redacted** pin: **redacted** server.v2: **redacted** server.v3: **redacted** [plugin] [plugin.disabled] [plugin.enabled] [plugin.repos] [power] [pushover] [sdcard] maxfreq.khz: 20000 [server.v2] port: server: ovms.dexters-web.de tls: no updatetime.connected: updatetime.idle: workaround.ios_tpms_display: no [server.v3] events.legacy_topic: yes metrics.exclude: metrics.exclude.immediately: metrics.include: metrics.include.immediately: metrics.priority: port: 8883 queue.modified: queue.sendall: server: ovms.dexters-web.de tls: yes topic.prefix: updatetime.awake: updatetime.charging: updatetime.connected: updatetime.idle: updatetime.immediately: no updatetime.keepalive: 1740 updatetime.on: updatetime.priority: no updatetime.sendall: user: **redacted** [ssh.info] fingerprint: wNr7F8DCIPXn12my8kyX3W/E9Zl9CqeiMf/eYRjWdn8 [ssh.keys] [ssh.server] key: **redacted** [system.adc] factor12v: 195.7 [tpms] [usr] [vehicle] 12v.alert: 0.8 12v.ref: 12v.shutdown: 12v.shutdown_delay: 12v.wakeup: 12v.wakeup_interval: flatbed.alarmdistance: flatbed.alarminterval: id: **redacted** name: Momo stream: 10 timezone: GMT0BST,M3.5.0/1,M10.5.0 timezone_region: Europe/London tpms.fl: 0 tpms.fr: 1 tpms.rl: 2 tpms.rr: 3 units.accel: miphps units.accelshort: ftpss units.consumption: mipkwh units.distance: M units.distanceshort: feet units.speed: miph valet.alarmdistance: valet.alarminterval: [wifi.ap] **redacted**: **redacted** [wifi.ssid] **redacted**: **redacted** [xsq] 12v.charge: yes bcvalue: no canwrite: yes cfg.preset.ver: 7 extended.stats: yes full.km: 126 led: no modem.check: no rebootnw: 0 reset.notify: yes resettotal: no resettrip: no tpms.alert.enable: yes tpms.front.pressure: 225 tpms.rear.pressure: 255 tpms.value.alert: 50 tpms.value.warn: 30 unlock.warning: yes
REPORT ENDS
On 27 Dec 2025, at 14:50, Michael Balzer via OvmsDev <ovmsdev@lists.openvehicles.com> wrote:
Welcome, Aaron.
Regards, Michael
Hi folks,
Registers:
Backtrace:
Aaron
Aaron Carson (he/him) ✉️ : aaron@aaroncarson.co.uk <mailto:aaron@aaroncarson.co.uk> 💻 : aaroncarson.co.uk <https://www.aaroncarson.co.uk/> 🔑 : 715E 0332 F7E1 E0F1 <https://keys.openpgp.org/vks/v1/by-fingerprint/45982EB56486CED008DAED0D715E0332F7E1E0F1>
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev <OpenPGP_signature.asc>
Hi all, 8.8.8.8 is Google. Maybe in this case not that important, but if you are interested in more privacy on the net you can search for "8.8.8.8 alternative privacy" and you'll get other options. Regards Chris Am Montag, dem 29.12.2025 um 07:49 +0800 schrieb Mark Webb-Johnson via OvmsDev:
Aaron,
Hi both,
Aaron
OVMS MODULE SUMMARY
Module Version: 3.3.005-536-g20a42926/ota_1/edge (build idf v3.3.4-851- gfa4f07fb3b Dec 25 2025 16:43:35) Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600 Free RAM: 8bit=57212-58652 32bit=12128 SPIRAM=3225048-3244984 bytes 12V: 11.9V
Storage /store: Size: 976 kB Avail: 896 kB Used: 9% WIFI Status Power: on Mode: Access-Point + Client mode STA SSID: **redacted** (-78.2 dBm) [fixed] MAC: 00:4b:12:... IP: 10.75.0.247/255.255.0.0 GW: 10.75.0.1 AP: ba:fb:e4:c4:1b:6f AP SSID: **redacted** (20 MHz, channel 6) MAC: 00:4b:12:... IP: 192.168.4.1 AP Stations: 0 MODEM Status Model: SIM7600 Revision: Network Registration: Unknown Provider: Signal: 0 dBm Mode: State: PoweredOn Ticker: 0 User Data: 0 UART: FIFO overflows: 0 Buffer overflows: 0 Parity errors: 0 Frame errors: 0 Driver Buffer overflows: 0 State Timeout Goto: PoweringOn (in 40 seconds) Mux: Not running PPP: Not running GPS: Not running
Configuration [auto] dbc: no egpio: no ext12v: no init: yes modem: yes obd2ecu: ota: yes scripting: yes server.v2: no server.v3: no vehicle.type: SQ wifi.mode: apclient wifi.ssid.ap: **redacted** wifi.ssid.client: **redacted** [can] [dbc] [egpio] monitor.ports: [http.plugin] [http.server] [locations] Home: **redacted** [log] [modem] apn: hologram apn.password: apn.user: enable.gps: yes enable.gpstime: yes enable.net: yes enable.sms: yes gps.parkpause: 600 gps.parkreactawake: yes gps.parkreactivate: 50 gps.parkreactlock: 5 net.type: auto pincode: [module] cfgversion: 2022121400 init: done [network] dns: modem.sq.bad: -103 modem.sq.good: -93 type: 4G wifi.ap2client.enable: yes wifi.sq.bad: -95 [notify] [obd2ecu] [obd2ecu.map] [ota] auto.allow.modem: no auto.hour: 2 http.mru: https://ovms.dexters- web.de/firmware/ota/v3.3/edge/ovms3.bin server: https://ovms.dexters-web.de/firmware/ota tag: edge [password] module: **redacted** pin: **redacted** server.v2: **redacted** server.v3: **redacted** [plugin] [plugin.disabled] [plugin.enabled] [plugin.repos] [power] [pushover] [sdcard] maxfreq.khz: 20000 [server.v2] port: server: ovms.dexters-web.de tls: no updatetime.connected: updatetime.idle: workaround.ios_tpms_display: no [server.v3] events.legacy_topic: yes metrics.exclude: metrics.exclude.immediately: metrics.include: metrics.include.immediately: metrics.priority: port: 8883 queue.modified: queue.sendall: server: ovms.dexters-web.de tls: yes topic.prefix: updatetime.awake: updatetime.charging: updatetime.connected: updatetime.idle: updatetime.immediately: no updatetime.keepalive: 1740 updatetime.on: updatetime.priority: no updatetime.sendall: user: **redacted** [ssh.info] fingerprint: wNr7F8DCIPXn12my8kyX3W/E9Zl9CqeiMf/eYRjWdn8 [ssh.keys] [ssh.server] key: **redacted** [system.adc] factor12v: 195.7 [tpms] [usr] [vehicle] 12v.alert: 0.8 12v.ref: 12v.shutdown: 12v.shutdown_delay: 12v.wakeup: 12v.wakeup_interval: flatbed.alarmdistance: flatbed.alarminterval: id: **redacted** name: Momo stream: 10 timezone: GMT0BST,M3.5.0/1,M10.5.0 timezone_region: Europe/London tpms.fl: 0 tpms.fr: 1 tpms.rl: 2 tpms.rr: 3 units.accel: miphps units.accelshort: ftpss units.consumption: mipkwh units.distance: M units.distanceshort: feet units.speed: miph valet.alarmdistance: valet.alarminterval: [wifi.ap] **redacted**: **redacted** [wifi.ssid] **redacted**: **redacted** [xsq] 12v.charge: yes bcvalue: no canwrite: yes cfg.preset.ver: 7 extended.stats: yes full.km: 126 led: no modem.check: no rebootnw: 0 reset.notify: yes resettotal: no resettrip: no tpms.alert.enable: yes tpms.front.pressure: 225 tpms.rear.pressure: 255 tpms.value.alert: 50 tpms.value.warn: 30 unlock.warning: yes
REPORT ENDS
Welcome, Aaron.
Regards, Michael
Hi folks,
Registers:
PC : 0x00000000
PS : 0x00000000
A0 : 0x00000000
A1 : 0x00000000
A2 : 0x00000000
A3 : 0x00000000
A4 : 0x00000000
A5 : 0x00000000
A6 : 0x00000000
A7 : 0x00000000
A8 : 0x00000000
A9 : 0x00000000
A10 : 0x00000000
A11 : 0x00000000
A12 : 0x00000000
A13 : 0x00000000
A14 : 0x00000000
A15 : 0x00000000
SAR : 0x00000000
LBEG : 0x00000000
LEND : 0x00000000
LCOUNT : 0x00000000
Backtrace:
Version: 3.3.005-536-g20a42926/ota_1/edge (build idf v3.3.4- 851-gfa4f07fb3b Dec 25 2025 16:43:35)
Aaron
Aaron Carson (he/him) ✉️ : aaron@aaroncarson.co.uk 💻 : aaroncarson.co.uk [1] 🔑 : 715E 0332 F7E1 E0F1 [2]
[1] aaroncarson.co.uk https://www.aaroncarson.co.uk/ [2] 715E 0332 F7E1 E0F1 https://keys.openpgp.org/vks/v1/by-fingerprint/45982EB56486CED008DAED0D715E0...
Aaron Carson -
Chris van der Meijden -
Mark Webb-Johnson -
