A lot has changed in iOS 8, and it seems to have broken push notifications (APNS) for new users. Existing users are fine. So, I find the few lines that need to be changed, and fixed that. Cool. Now, submit to App Store, and Apple requires 64bit. OK, change the building settings for a 32bit + 64bit dual package, and rebuild. (old) Testflight sdk not compatible (32bit only). Remove testflight sdk, and all its tendrils throughout the code base. Rebuild. 190+ warnings about int vs long. Crap de crap de crap. Rebuild. OK. All clean, built and ready to go. Only issue is that all my working devices are IOS 9 beta (for work), and Apple’s not accepting iOS 9 built stuff yet, so I can’t properly test. Each of the above steps needs about 15-to-45 minutes of googling. So, I have a build (v1.6.6). It is 32bit and 64bit. It seems to work. But, I need help testing. Seems Apple have a new test flight integrated to iTunes connect. Never tried it, but you are all about to get an invite ;-) Regards, Mark.
Happy to Beta-Test Mit freundlichen Grüßen / Kind regards Michael Eymann An den Teichen 34 46519 Alpen +491722571111
Am 21.08.2015 um 16:56 schrieb Mark Webb-Johnson <mark@webb-johnson.net>:
Rebuild.
Rebuild.
Thanks. I’ve submitted all the addresses to Apple, but seems that they still need to review the app even for ‘beta test’. Anyway, I guess once the review is complete you will all get an invite in your eMail. You can speed things up somewhat by pre-installing the ‘testflight’ app from Apple on your phones. Regards, Mark. P.S. I managed to get it installed on my own iOS v9 iPhone 6+. Seems to work ok, but I will do more testing over the weekend.
On 21 Aug, 2015, at 11:16 pm, Michael Eymann <michael.eymann@me.com> wrote:
Happy to Beta-Test
Rebuild.
Rebuild.
Hi, got invitation. It runs now on my iPad Air (1) with 9.0 latest beta. Waiting for the next push. PS: the Settings survive. Bye Michael
Am 21.08.2015 um 17:23 schrieb Mark Webb-Johnson <mark@webb-johnson.net>:
Thanks.
Happy to Beta-Test
Rebuild.
Rebuild.
Michael, Thanks for the feedback. I’ve got it running on two 64bit devices, with surprisingly no problems. I am getting push notifications, and the registrations look ok. Yes, the warning about you may lose your settings is just a warning. Everything is retained for me. Regards, Mark. P.S. Apple enforces 30 day betas. The real one is in app store review now, so baring any problems that will be ready for release in about a week.
On 22 Aug, 2015, at 9:11 pm, Michael Jochum <mikeljo@me.com> wrote:
Hi,
Bye Michael
Thanks.
Happy to Beta-Test
Rebuild.
Rebuild.
I have now three roadster under control Keep you in loop Mit freundlichen Grüßen / Kind regards Michael Eymann An den Teichen 34 46519 Alpen +491722571111
Am 22.08.2015 um 15:36 schrieb Mark Webb-Johnson <mark@webb-johnson.net>:
Michael,
Hi,
Bye Michael
Thanks.
Happy to Beta-Test
Rebuild.
Rebuild.
Did we lost parameter 24 - GMT/UTC? Mit freundlichen Grüßen / Kind regards Michael Eymann An den Teichen 34 46519 Alpen +491722571111
Am 22.08.2015 um 15:45 schrieb Michael Eymann <michael.eymann@me.com>:
Michael,
Hi,
Bye Michael
Thanks.
Happy to Beta-Test
Rebuild.
Rebuild.
Surely #23? Parameters should be 0..23. Mark.
Michael,
Hi,
Bye Michael
Thanks.
Happy to Beta-Test
> Am 21.08.2015 um 16:56 schrieb Mark Webb-Johnson <mark@webb-johnson.net>: > > > A lot has changed in iOS 8, and it seems to have broken push notifications (APNS) for new users. Existing users are fine. > > So, I find the few lines that need to be changed, and fixed that. Cool. > > Now, submit to App Store, and Apple requires 64bit. > > OK, change the building settings for a 32bit + 64bit dual package, and rebuild. > > (old) Testflight sdk not compatible (32bit only). > > Remove testflight sdk, and all its tendrils throughout the code base. > > Rebuild. > > 190+ warnings about int vs long. > > Crap de crap de crap. > > Rebuild. > > OK. All clean, built and ready to go. > > Only issue is that all my working devices are IOS 9 beta (for work), and Apple’s not accepting iOS 9 built stuff yet, so I can’t properly test. > > Each of the above steps needs about 15-to-45 minutes of googling. > > So, I have a build (v1.6.6). It is 32bit and 64bit. It seems to work. But, I need help testing. > > Seems Apple have a new test flight integrated to iTunes connect. Never tried it, but you are all about to get an invite ;-) > > Regards, Mark. > > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
- 24 was out of the manual.. Is UTC correction 23? - Charge Time calclulation: i just got following sms Feedback 21:29:53 -> it is already 23:29 Local Time Range - Charging 216V/13A -> so about 16,25km/chargehour Full: 126 min -> seems to be optimistic SOC: 65% Ideal Range: 209 km Est. Range: 132 km ODO: 118,276.2 km CAC: 129.65 - notifications Are Fine!! Just Far tooooo much Cos my 12v Battery Needs service Mit freundlichen Grüßen / Kind regards Michael Eymann An den Teichen 34 46519 Alpen +491722571111
Am 24.08.2015 um 03:25 schrieb Mark Webb-Johnson <mark@webb-johnson.net>:
Mark.
Michael,
Hi,
Bye Michael
Thanks.
> On 21 Aug, 2015, at 11:16 pm, Michael Eymann <michael.eymann@me.com> wrote: > > Happy to Beta-Test > > Mit freundlichen Grüßen / Kind regards > > Michael Eymann > An den Teichen 34 > 46519 Alpen > +491722571111 > > >> Am 21.08.2015 um 16:56 schrieb Mark Webb-Johnson <mark@webb-johnson.net>: >> >> >> A lot has changed in iOS 8, and it seems to have broken push notifications (APNS) for new users. Existing users are fine. >> >> So, I find the few lines that need to be changed, and fixed that. Cool. >> >> Now, submit to App Store, and Apple requires 64bit. >> >> OK, change the building settings for a 32bit + 64bit dual package, and rebuild. >> >> (old) Testflight sdk not compatible (32bit only). >> >> Remove testflight sdk, and all its tendrils throughout the code base. >> >> Rebuild. >> >> 190+ warnings about int vs long. >> >> Crap de crap de crap. >> >> Rebuild. >> >> OK. All clean, built and ready to go. >> >> Only issue is that all my working devices are IOS 9 beta (for work), and Apple’s not accepting iOS 9 built stuff yet, so I can’t properly test. >> >> Each of the above steps needs about 15-to-45 minutes of googling. >> >> So, I have a build (v1.6.6). It is 32bit and 64bit. It seems to work. But, I need help testing. >> >> Seems Apple have a new test flight integrated to iTunes connect. Never tried it, but you are all about to get an invite ;-) >> >> Regards, Mark. >> >> _______________________________________________ >> OvmsDev mailing list >> OvmsDev@lists.teslaclub.hk >> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev > _______________________________________________ > OvmsDev mailing list > OvmsDev@lists.teslaclub.hk > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Hi, it works. i got the push notification on the iPad. In the meantime i got a new iPhone 6. iOS beta 9.x and then full restore from the old iPhone 5. -> no push notifications from OVMS Installed TestFlight and inside this OVMS -> Push now works. Well done! ;-) Bye Michael
Michael,
Hi,
Bye Michael
Thanks.
Happy to Beta-Test
Rebuild.
Rebuild.
Testflight version: bug? I just drove down my SOC and got a different SMS than before the test flight update: New: (received while driving!!!) 09:32:18 Not charging SOC: 4% Ideal Range: 10 km Est. Range: 6 km ODO: 119,157.6 km CAC: 128.93 Old ALERT!!! CRITICAL SOC LEVEL APPROACHED (0% SOC) Mit freundlichen Grüßen / Kind regards Michael Eymann An den Teichen 34 46519 Alpen +491722571111
Am 28.08.2015 um 10:36 schrieb Michael Jochum <mikeljo@me.com>:
Hi,
it works.
Well done! ;-)
Bye Michael
Michael,
Hi,
Bye Michael
Thanks.
Happy to Beta-Test
Rebuild.
Rebuild.
The SMS messages don’t go through the App at all. This would be something on the module firmware side. Regards, Mark.
On 28 Aug, 2015, at 5:49 pm, Michael Eymann <Michael.Eymann@Networkz.de> wrote:
Hi,
it works.
Well done! ;-)
Bye Michael
Michael,
Hi,
Bye Michael
Thanks.
Happy to Beta-Test
Mark Webb-Johnson -
Michael Eymann -
Michael Eymann -
Michael Jochum
