Michael’s work has brought up an issue that we seem to be missing some javascript integrations. We have: OvmsCommand OvmsLocation OvmsMetrics OvmsVehicle PubSub (to ovms events) Obvious ones missing are: OvmsConfig OvmsWebServer I can do OvmsConfig, but one question: Do we allow scripts access to protected config values? I think not (as that would void the entire protection system with a ’script eval JSON.print(…)', but is a limitation). Comments? It would be interesting to see scripts extend the OvmsWebServer, so urls could be mapped to scripts - but not sure of the practical use of that vs plugins. Regards, Mark.
Also missing: * OvmsEvent (raise) * OvmsNotify (raise) …these would be especially valuable for communication between module and web plugins as well as MQTT listeners. We also need an HTTP/HTTPS client accessable from scripts. Our OvmsHttp implementation needs to be replaced by the IDF HTTPS client. Simple file I/O for scripts would also be valuable (e.g. scripts writing custom data logs to SD). Script access to protected config values could be granted by a general API key mechanism, as planned for the web API (/api/execute). I.e. the script needs to use a valid API token to access protected configs. An API token could include a set of specific grants & denies, so we can extend that as needed to also cover other potentially critical stuff like network & file access. Similar to App permissions on Android / iOS. Regards, Michael Am 08.10.19 um 09:45 schrieb Mark Webb-Johnson:
We have:
* OvmsCommand * OvmsLocation * OvmsMetrics * OvmsVehicle * PubSub (to ovms events)
* OvmsConfig * OvmsWebServer
It seems we have OvmsNotify.Raise() already. I am implementing OvmsEvents and OvmsConfig now. I will just keep config simple (no access to protected variables) for the moment. We can revisit this if/when we have a secure way of setting App permissions. Regards, Mark
On 8 Oct 2019, at 4:25 PM, Michael Balzer <dexter@expeedo.de> wrote:
Also missing: OvmsEvent (raise) OvmsNotify (raise) …these would be especially valuable for communication between module and web plugins as well as MQTT listeners.
Regards, Michael
We have:
_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
-- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Am 08.10.19 um 10:25 schrieb Michael Balzer:
This is now also implemented: https://docs.openvehicles.com/en/latest/userguide/scripting.html#vfs Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
Mark Webb-Johnson -
