Re: [Ovmsdev] Tick math
Ok, so you every 104.8576ms will add 5243MarkSecs (just invented a new time unit) right? And when the counter reaches or pass 50000 you add one second and subtract 50000 to the count. This way you are over 0.0024ms per timer interrupt, roughly 0.022ms per second, that is less than 2s per day (that is, every 43690s we count one second more.) Please check my math.... But you won! Gianluca Magalotti dal mio iPad mini
Il giorno 22/ott/2014, alle ore 06:00, ovmsdev-request@lists.teslaclub.hk ha scritto:
Sorry, in my P.S., I think I miscalculated the improvement.
1] Current methodology:
Signed 16 bit integer Every 104.8576ms timer interrupt, add 105ms to the counter. If counter >1,000 treat it as 1 second and deduct 1,000 from counter.
Accuracy: loses 0.1424ms per timer interrupt.
2] 50ms methodology:
Signed 16 bit integer Every 104.7576ms timer interrupt, add 5243 to the counter. That is equivalent to 5242.88 50ms chunks. Difference is 0.88 / 50 ms Accuracy: loses 0.01760ms per timer interrupt
Or, is my new maths wrong? Is the inaccuracy 0.01760ms or 0.12ms per timer tick?
Confused, I am.
Mark.
+1, I like. Especially because MarkSecs sounds a bit rude... Of course, the final correction is that if we know every time we add 105 to the count, we are off by 0.1424ms, then after 10 times we are off by 1.424ms, so we could just adjust the amount we deduct appropriately. 999 vs 1,000 and instantly 3 times better. That works even better with MarkSecs (which might as well be 60ms vs 50ms, as we are good for up to 65535 for an unsigned int16). At that point, we're more accurate than the clock on the PIC18. Every 104.8576ms interrupt, we add 6291 to the counter, knowing that we are off by 0.0076ms (0.4560 marksecs). Now, when counter exceeds 60,000 (10 interrupts), we have added 62,910 to the counter (6,291 ten times) and each of those times we were too low by 0.4560 marksecs, so we are 4.560 marksecs too low, so we increment car_time by 1 second and decrement the counter by 59,995. We should then be out by 0.007333ms over that 1 second. I think that's about 1/2 second a day. Or, using 1 marksecs as 50ms: for every 104.8576ms interrupt, we add 5243 to the counter, knowing we are off by 0.02ms (0.12 marksecs). Now, when counter exceeds 50,000 (10 interrupts), we have added 52,430 to the counter (5,243 ten times) and each of those times we were too high by 0.12 marksecs, so we are 1.2 marksecs too high, so we increment car_time by 1 second and decrement the counter by 50,001. We should then by out by 0.002ms over that 1 second. I think that is about 0.17 seconds a day. Or, using 1 marksecs as 42ms (I just love the number 42, and in this case it gives us a very small loss of precision): for every 104.8576ms interrupt, we add 4404 to the counter, knowing we are off by 0.000456ms (0.0192 marksecs). Now, when counter exceeds 42,000 (10 interrupts), we have added 44,040 to the counter (4,404 ten times) and each of those times we were too low by 0.0192 marksecs, we we are 0.192 marksecs too low, so we don't need to adjust. We should then be out by 0.00456ms over that 1 second. I think that is about 0.39 seconds a day, but we have solved the answer to life the universe and everything. Or, my maths may be even more wrong. Mark. On 22 Oct, 2014, at 1:38 pm, Gianluca Magalotti <gianluca@magalotti.net> wrote:
Confused, I am.
Mark.
OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
adjusting time to UTC http://www.timeanddate.com/worldclock/timezone/utc once a week when you connect to the server, is that a possibility? 2014-10-22 8:22 GMT+02:00 Mark Webb-Johnson <mark@webb-johnson.net>:
Mark.
Confused, I am.
Mark.
Shouldn’t be necessary, as we use the GSM clock which is synced from the provider’s cell tower. Regards, Mark.
On 22 Oct, 2014, at 8:31 pm, J-C Saint-Pô <jcsaintpo@gmail.com> wrote:
adjusting time to UTC http://www.timeanddate.com/worldclock/timezone/utc <http://www.timeanddate.com/worldclock/timezone/utc> once a week when you connect to the server, is that a possibility?
2014-10-22 8:22 GMT+02:00 Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net>>:
Mark.
On 22 Oct, 2014, at 1:38 pm, Gianluca Magalotti <gianluca@magalotti.net <mailto:gianluca@magalotti.net>> wrote:
Il giorno 22/ott/2014, alle ore 06:00, ovmsdev-request@lists.teslaclub.hk <mailto:ovmsdev-request@lists.teslaclub.hk> ha scritto:
Confused, I am.
Mark.
OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk <mailto:OvmsDev@lists.teslaclub.hk> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
-- http://home.scarlet.be/jcsaintpo <http://home.scarlet.be/jcsaintpo>
This is a pretty cool trick! I was a bit confused when I first read the thread. The marksec time unit is 50ms, it's 1/50,000 of a second, or 20 microseconds. Fine, that's just a notation thing. The trick of improving the rounding error on the increment once per second is a little more complicated. If you do it once per second, sometimes that's 10 interrupts and sometimes it's once every 9 interrupts (about 2 out of 41 times). You can fix that by making the counter correction once every 10 interrupts, which is effectively just adding one decimal place to your increment counter. But, we don't have to do that at all. I wrote a program to try every possible time unit between 1/1000 and 1/60000 of a second and found the time unit with the smallest error. Using a marksec of 1/45681 means there would be 4790.000026 marksecs per interrupt. Rounding that to 4790 for the counter increment value introduces an error of -0.00000000056 seconds per interrupt, which works out to losing -0.00046 seconds per day. So, each interrupt, increment the counter by 4790. When the total is equal to or greater than 45681, increment car_time and subtract 45681 from the counter. There is a better value of 61903 with an increment value of 6491 which cuts that error by a factor of three, but it doesn't work with a 16-bit unsigned integer because of overflow problems (61902 + 6491 > 65535). Tom -----Original Message----- From: Mark Webb-Johnson <mark@webb-johnson.net> Reply-To: OVMS Developers <ovmsdev@lists.teslaclub.hk> Date: Tuesday, October 21, 2014 at 11:22 PM To: OVMS Developers <ovmsdev@lists.teslaclub.hk> Subject: Re: [Ovmsdev] Tick math
Mark.
Confused, I am.
Mark.
Looks good. (45681/4790)*104.8576 = 1000.0000053411 I've committed that, and will carry on testing tonight. Now, of course this depends on the calculation of 104.8576ms per timer1 interrupt. I have no idea where that figure originally came from, or if it is correct. It does looks like the LED count counts 10 of these to get 1 flash a second, so it seems correct. The initialisation for timer1 is: // Timer 1 enabled, Fosc/4, 16 bit mode, prescaler 1:8 T1CON = 0b10110101; // @ 5Mhz => 51.2uS / 256 IPR1bits.TMR1IP = 0; // Low priority interrupt PIE1bits.TMR1IE = 1; // Enable interrupt TMR1L = 0; TMR1H = 0; but the @5Mhz comment is incorrect because that is not what our oscillator runs at. Regards, Mark. On 23 Oct, 2014, at 9:32 am, Tom Saxton <tom@idleloop.com> wrote:
Tom
Mark.
Confused, I am.
Mark.
Hi guys, I just started looking at the OVMS again after a long time away, so forgive me if I get some details wrong. Looking at the Eagle schematic, I see the crystal specified as 20 MHz. In HS mode, that would make the main oscillator run at FOSC = 20 MHz. But if you're using the HSPLL, you could be running at the maximum FOSC = 40 MHz. The latter option would obviously cut the period in half. A quick check of the firmware source shows #pragma config OSC = HS, so you might consider doubling this using HSPLL and the remaining appropriate config changes. Anyway, starting with 20 MHz, FOSC/4 = 5 MHz, which is probably where that 5 MHz comment comes from below. The 1:8 prescaler takes that down to 625 kHz TMR1H:TMR1L of 0x0000 is effectively 0x10000, or 65,536, bringing the frequency down to 9.5367431640625 Hz. The reciprocal is exactly 104.8576 ms. If you double the PIC speed to its rated maximum using the High Speed Phase Locked Loop (and use a multiplier of 2, not the example of 4 in the data sheet which would bring a 10 MHz crystal up to the 40 MHz maximum), then the period would be 52.4288 ms, but I think you could use the exact same technique that Tom mentioned to adjust for seconds without too much error. You'd just need to alter the values by a factor of two. Brian Willoughby Sound Consulting On Oct 22, 2014, at 8:30 PM, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
Looks good.
Brian, Thanks for this. I've updated the source code with your comments, for historical record. With this confirmed, I think we should be good to go. I'll do some further testing over the next few nights (perhaps turning off the GSM sync and seeing how badly/well it drifts). Regarding the clock speed, I think it is fast enough now (as other than the CAN handling, there is little else going on), and presumably we gain a small power advantage from running at FOSC=20MHz (vs 40MHz). Regards, Mark. On 23 Oct, 2014, at 1:00 pm, HONDA S-2000 <s2000@audiobanshee.com> wrote:
Hi guys,
Looks good.
Gianluca Magalotti -
HONDA S-2000 -
J-C Saint-Pô -
Mark Webb-Johnson -
Tom Saxton
