My simcom lost its connection between two stops this morning. I happened to check the app when leaving the second stop and it showed the car a few blocks from the first stop. Now that it's back on my home wifi I can see the gps is happy (locked on 10 sats) and the simcom has signal but is in DeniedRegistration state... Looking at https://status.hologram.io/ I see they had an outage today. Ah, checking my other module I see it also says DeniedRegistration. So more accurately: they are *having* an outage today. Craig
Craig, Thanks for the heads-up on this. I wasn’t aware of it. The DeniedRegistration thing is part of the GSM standards. If the SIM repeatedly can’t connect to the network, the modem itself backs off and won’t try for an exponential delay. There is a low-level AT command that can clear this, but normally best to wait for the network to recover. Regards, Mark. P.S. Also worth double-checking you still have balance on the account.
Craig <modem.png>_______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
I checked a few minutes ago and all three of my modules were still in DeniedRegistration. Stopping/restarting the modem did not correct this but rebooting the modules did. If your module DeniedRegistration is on wifi you can use the app to reboot; settings -> car -> control -> reset ovms module. Craig
Craig Leres -
