Hi all, In Vehicle.cpp the NotifyVehicleIdling() routine is essentially called when StdMetrics.ms_v_env_awake is true and the idle ticker has expired. My understanding from the standard metrics documentation is that the awake metric is to indicate activity on the can bus eg when charging or prior to the vehicle being turned on. Hence I was only expecting an idle notification if the vehicle has been accidentally left in the on state indicated by StandardMetrics.ms_v_env_on. Or have I misunderstood how the two metrics and idle function are intended to work or mean? Cheers Derek
Derek, awake = switched on (manually), on = ignited. Charging is charging (not necessarily awake while charging, but possible). Regards, Michael Am 31.07.20 um 13:11 schrieb Derek Caudwell:
Hi all,
Cheers Derek
Derek Caudwell -
