PR review requests + Mongoose 7 progress update
Dear all, I have a few PRs pending, that are low-risk I believe, but are building block for the ESP-IDF4+ upgrade saga: * ESP-IDFv4+: fix cmake build of ovms_webserver #907 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/907> specific to ESP-IDF4+ builds (for the ovms_webserver component): o It reverts a previous PR on the component.mk / ESP-IDF3 build system of this component - which had a temporary workaround o It fixes the ESP-IDF4+ build system of this component with an approach better aligned to the ESP-IDF3 approach. * mongoose: identify dependencies, and generate a version header #909 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/909> o In order to help upgrade mongoose from 6.11 to 7.10, it introduces a new header with ability to compare mongoose version. It impacts both ESP3 and ESP4+ builds but should be low-impact Also pending: * fix documentation of arguments of tcpserver #900 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/900> straightforward update of the documentation * fix a few issues appearing when disabling/enabling components #910 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/910> o (specific to ESP-IDF4+) : make |ovms_plugins| compilable with or without |duktape| o |vehicle_hyundai_ioniq5| had issue when disabling webserver component o |vehicle_maxus_euniq56| had missing header when disabling webserver component If some of you can review any or all of these it'll help. Thank you ! Finally, progress is being made on the Mongoose v7.10 upgrade. You can have a look at the `upgrade-mongoose-7` branch <https://github.com/llange/Open-Vehicle-Monitoring-System-3/tree/upgrade-mongoose-7>, or this (artificial) PR <https://github.com/llange/Open-Vehicle-Monitoring-System-3/pull/5/files> to show the diff. At the moment, SSH console is crashing. Not happy with that, and will happily read your comments about it. Regards,
Ludovic LANGE
