Uart errors accessing SD Card
Since forever I've been getting uart errors (4) - which seems to be an ERROR *E (56071827) uart_events: uart event type: 4* It seems it gets easily overwhelmed. For example while doing (From the web i/f) 'vfs ls /sd' is fine (there are only 15 entries there) .. the command: *vfs ls /sd/log* causes a whole bunch of the above uart errors (l50 or so) interrupted by the output of the command results (50 or so files). I'm not sure whether it lists all of them.. but probably? I was implementing file completion in 'vfs' command.. and it works except for when trying to complete in that directory. I suspect that it's overwhelming the limited spaces in the complete buffer.. but also the messages queue is getting swamped by all the uart_event errors. Thoughts? //.ichael
It's a 25000kHz sd card. config set sdcard maxfreq.khz 15000 did the trick. Setting it to 20000 was still giving grief. //. On Tue, 9 Jul 2024 at 08:37, Michael Geddes <frog@bunyip.wheelycreek.net> wrote:
Thoughts?
//.ichael
Maybe the card is only labeled as 25.000 … like those chinese 9.900 mAh 18650 cells ;-) Regarding the completion buffer, have a look at the completion of "metrics set" -- if there are too many, it ends the list with an ellipsis. Regards, Michael Am 09.07.24 um 16:52 schrieb Michael Geddes via OvmsDev:
Thoughts?
//.ichael
This is what I have according to the welcome message; Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/3; MODEM SIM7600 //.ichael On Wed, 10 July 2024, 08:14 Mark Webb-Johnson, <mark@webb-johnson.net> wrote:
Older versions of OVMS hardware can’t handle high speed sd card access. Could that be the problem?
On 9 Jul 2024, at 10:52 PM, Michael Geddes via OvmsDev < ovmsdev@lists.openvehicles.com> wrote:
Thoughts?
//.ichael
Mark Webb-Johnson -
Michael Balzer -
Michael Geddes
