Hey you in there! Your door knocker fell off!
When I was plugging a cable into the micro-USB connector on my OVMSv3.0 board the connector came off. This was a bit of a scare! Even though the connector uses through-hole pins for physical attachment, I guess there is some flexing of the solder as the cable is inserted or removed. I have not done that many insertions, though; it's the other end of the cable with a full-size USB connector that gets exercised. Fortunately I was able to reflow the solder for both the through-hole pins and the ity-bity surface-mount electrical connections using a fine-tip soldering iron so operation was restored. So this is just a word of caution to be gentle! -- Steve p.s. The subject is a reference to Firesign Theatre for those of us old enough to have burned up time in college listening to their albums.
Stephen Casner
