I'm preparing a new Twizy release adding an option to control max current level and raise torque & power levels above the safety limits. T80 example: raise current level to 500 A, set 100 Nm torque level and power level to 15.5 kW (mech): CFG POWER 182 127 119 111 Code and manual updates are in the hub, firmware file can be downloaded from: http://dexters-web.de/f/tw-beta/OVMS-Twizy-3.7.0.zip This has been tested during the last weeks, but on T80 only up to now. T45 should work, but maybe the flux map modification needs some specific optimization. To check this I need some more T45 register data. Maybe some T45 driver can fill the "?" fields in the "Twizy-SDO-List" to help on this: https://github.com/openvehicles/Open-Vehicle-Monitoring-System/blob/master/d... Regards, Michael -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
