Hello, I'm working on a project to log and analyze data from different electric vehicles, and I'm testing the OVMS on a Renault Twizy. Basically, my goal is to log all important data relative to the battery health, like single cell voltages and temperatures, every time these details are sent through the CAN bus. The last update from Mark about Drive and Charge logging looked interesting to me, so I have recompiled and uploaded the last version from github and now I have a few questions. - By setting bits of feature #13, do you mean sending a command like "S FEATURE 13 3" to set them both? - How much data will be recorded? Will it record cell voltages every second, for example? I'm also having a few problems with the server, I'm running it from my pc, but I keep getting this error: 2013-08-20 03:11:09.570207 -0700 info main: #8 - new ovms connection from 83.224.73.48:36348 2013-08-20 03:11:11.176338 -0700 info main: #8 - - rx MP-C 0 5OnUlqzQRG/M9iLIp+XEVa j11lelnvojoURvQHwe1zlg== Test123 2013-08-20 03:11:11.177198 -0700 error main: #8 TEST123 error - Incorrect client authentication - aborting connection I tried to change passwords and encryption scheme from the DB, but I still get that error. I'd also like to know if you think that the OVMS is a good option for my needs, because it looks like the goal of the OVMS is too different from mine, so I may need to rewrite the PIC firmware to just dump the data from the CAN bus and push it through to my server, then parse it later. Regards Mastro Gippo
Mastro,
Yes, that is correct.
It only stores one record for each of charge and drive. The record is a summary only - no cell voltages. The Renault Twizy vehicle module does have some other logging code that is closer to what you require (it is only implemented in Twizy module at the moment). I believe that this is configurable to send one record every second or so during driving.
It seems that the server password on your vehicle module doesn't match the 'carpass' field in the mysql database. The passwords are stored in plaintext. I also suggest you ensure that deleted=0 for the vehicle record, and that the vehicleid matches.
The OVMS project is really about high-level control of the vehicle (start/stop charge, etc), as well as monitoring. The v1 and v2 modules are not really designed for streaming data - the lack of hardware flow control, limited RAM memory for buffering, and the limitations of 2G GPRS impact how much can be streamed. We did add streaming while driving, but that is limited to 1 message update every 2 or 3 seconds. It is sufficient to plot the position of the car moving against a background map. So, if you need to stream all CAN bus data, I would be doubtful whether the hardware could meet your requirements. In particular, the GPRS limitation. To do it properly, you would need 3G/4G speeds and a large data buffer. Regards, Mark. On 20 Aug, 2013, at 6:24 PM, Mastro Gippo <gipmad@gmail.com> wrote:
Regards Mastro Gippo _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Mark, thank you very much for the prompt reply.
I will not send all CAN data, but just the important bytes; it looks like I need about 60 bytes of data per second, including the IP overhead it should be less than 150bytes per second, shouldn't be a problem for GPRS. The small RAM is a bigger problem when I don't have GPRS connection, so maybe an SPI flash or SD may be added as a buffer. I will experiment and see what the best options are. Thank again Regards Mastro Gippo
Mark Webb-Johnson -
Mastro Gippo
