There is a question that came in to support, regarding Smart ED. Can someone with experience of that car have a look, and help answer? https://www.openvehicles.com/node/2335 <https://www.openvehicles.com/node/2335> Battery display in the App I have the smart ED 451. It has a 18 KWh battery and charges very slowly with max 3,7 KW. The display of the battery In the OVMS app is not quite right. - In the green to the left it says 8 KWh. I assume this is the used power from full. So it should be on the other side, as the green area with 70% represents around 13 KWh of power remaining. However, the numbers don’t add up. - to recharge fully I will need over 1 hr. But the app only estimates 16 mins. How can I change that? Thanks, Mark.
The problem was resolved in a private message in the German forum. It was a display error in the iOS app. Now everything works as it should.
Mark Webb-Johnson <mark@webb-johnson.net> hat am 28. Oktober 2019 um 04:09 geschrieben:
Battery display in the App I have the smart ED 451. It has a 18 KWh battery and charges very slowly with max 3,7 KW. The display of the battery In the OVMS app is not quite right.- In the green to the left it says 8 KWh. I assume this is the used power from full. So it should be on the other side, as the green area with 70% represents around 13 KWh of power remaining. However, the numbers don’t add up.- to recharge fully I will need over 1 hr. But the app only estimates 16 mins. How can I change that? Thanks, Mark.
Mark Webb-Johnson -
Thomas Heuer
