Hi , I am trying to make nissan leaf work with normal cable - on the CARCAN. I am trying to figure out the polling mechanism and I have trouble understanding what the different parameters in the configurations are. In the ampera file I can see: | rom struct | | | { | | | unsigned int moduleid; | | | unsigned char polltime; | | | unsigned int pid; | | | } vehicle_voltampera_polls[] | | | = | | | { | | | { 0x07E0, 10, 0x000D }, | | | { 0x07E4, 10, 0x4369 }, | | | { 0x07E4, 10, 0x4368 }, | | | { 0x07E4, 10, 0x801f }, | | | { 0x07E4, 10, 0x801e }, | | | { 0x07E4, 10, 0x434f }, | | | { 0x07E4, 10, 0x1c43 }, | | | { 0x07E4, 10, 0x8334 }, | | | { 0x07E1, 100, 0x2487 }, | | | { 0x0000, 0, 0x0000 } | | | }; | While in the nissan leaf file I can see the following: | rom vehicle_pid_t vehicle_nissanleaf_polls[] | | | = | | | { | | | { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIICURRENT, 0x0d, { 10, 10, 0 } }, // Speed | | | { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIIVEHICLE, 0x02, { 10, 10, 0 } }, // VIN | | | { 0, 0, 0x00, 0x00, { 0, 0, 0 } } | | | }; | I can kind of guess some of it. I also found an old e-mail from Mark that describes a structure similar to the one in the nissan leaf file, but the leaf has one extra parameter - I think it is the return message can Id. Any info/advice is appreciated! Nikolay
The Ampera is still using the old polling logic. The poling code is within the vehicle_voltampera module itself. The Leaf is using the new centralised polling logic (in vehicle.h and vehicle.c). This is the new recommend way of doing this, as the vehicle.{h,c} code will do the polling for you - all you need to do is setup the appropriate structure. The new structure is: typedef struct { unsigned int moduleid; unsigned int rmoduleid; unsigned char type; unsigned int pid; unsigned int polltime[VEHICLE_POLL_NSTATES]; } vehicle_pid_t; and the following polling types are currently supported: #define VEHICLE_POLL_TYPE_NONE 0x00 #define VEHICLE_POLL_TYPE_OBDIICURRENT 0x01 #define VEHICLE_POLL_TYPE_OBDIIVEHICLE 0x09 #define VEHICLE_POLL_TYPE_OBDIIGROUP 0x21 #define VEHICLE_POLL_TYPE_OBDIIEXTENDED 0x22 The moduleid is the replying module id, the rmoduleid is the id to use for the request. Regards, Mark.
On 21 Jun, 2015, at 9:44 pm, Nikolay Shishkov <nshishkov@yahoo.com> wrote:
Hi ,
In the ampera file I can see: rom struct { unsigned int moduleid; unsigned char polltime; unsigned int pid; } vehicle_voltampera_polls[] = { { 0x07E0, 10, 0x000D }, { 0x07E4, 10, 0x4369 }, { 0x07E4, 10, 0x4368 }, { 0x07E4, 10, 0x801f }, { 0x07E4, 10, 0x801e }, { 0x07E4, 10, 0x434f }, { 0x07E4, 10, 0x1c43 }, { 0x07E4, 10, 0x8334 }, { 0x07E1, 100, 0x2487 }, { 0x0000, 0, 0x0000 } };
rom vehicle_pid_t vehicle_nissanleaf_polls[] = { { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIICURRENT, 0x0d, { 10, 10, 0 } }, // Speed { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIIVEHICLE, 0x02, { 10, 10, 0 } }, // VIN { 0, 0, 0x00, 0x00, { 0, 0, 0 } } };
Nikolay _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Thanks Mark, I had to implement VEHICLE_POLL_TYPE_OBDIIGROUP section of the code in the vehicle.c... and I had to correct some of the code.I thought the moduleid was the requesting one while the rmoduleid was the response one ... Talk about context ;) Nikolay On Monday, June 22, 2015 3:12 PM, Mark Webb-Johnson <mark@webb-johnson.net> wrote: The Ampera is still using the old polling logic. The poling code is within the vehicle_voltampera module itself. The Leaf is using the new centralised polling logic (in vehicle.h and vehicle.c). This is the new recommend way of doing this, as the vehicle.{h,c} code will do the polling for you - all you need to do is setup the appropriate structure. The new structure is: typedef struct{ unsigned int moduleid; unsigned int rmoduleid; unsigned char type; unsigned int pid; unsigned int polltime[VEHICLE_POLL_NSTATES];} vehicle_pid_t; and the following polling types are currently supported: #define VEHICLE_POLL_TYPE_NONE 0x00#define VEHICLE_POLL_TYPE_OBDIICURRENT 0x01#define VEHICLE_POLL_TYPE_OBDIIVEHICLE 0x09#define VEHICLE_POLL_TYPE_OBDIIGROUP 0x21#define VEHICLE_POLL_TYPE_OBDIIEXTENDED 0x22 The moduleid is the replying module id, the rmoduleid is the id to use for the request. Regards, Mark. On 21 Jun, 2015, at 9:44 pm, Nikolay Shishkov <nshishkov@yahoo.com> wrote: Hi , I am trying to make nissan leaf work with normal cable - on the CARCAN. I am trying to figure out the polling mechanism and I have trouble understanding what the different parameters in the configurations are. In the ampera file I can see: | rom struct | | | { | | | unsigned int moduleid; | | | unsigned char polltime; | | | unsigned int pid; | | | } vehicle_voltampera_polls[] | | | = | | | { | | | { 0x07E0, 10, 0x000D }, | | | { 0x07E4, 10, 0x4369 }, | | | { 0x07E4, 10, 0x4368 }, | | | { 0x07E4, 10, 0x801f }, | | | { 0x07E4, 10, 0x801e }, | | | { 0x07E4, 10, 0x434f }, | | | { 0x07E4, 10, 0x1c43 }, | | | { 0x07E4, 10, 0x8334 }, | | | { 0x07E1, 100, 0x2487 }, | | | { 0x0000, 0, 0x0000 } | | | }; | While in the nissan leaf file I can see the following: | rom vehicle_pid_t vehicle_nissanleaf_polls[] | | | = | | | { | | | { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIICURRENT, 0x0d, { 10, 10, 0 } }, // Speed | | | { 0x797, 0x79a, VEHICLE_POLL_TYPE_OBDIIVEHICLE, 0x02, { 10, 10, 0 } }, // VIN | | | { 0, 0, 0x00, 0x00, { 0, 0, 0 } } | | | }; | I can kind of guess some of it. I also found an old e-mail from Mark that describes a structure similar to the one in the nissan leaf file, but the leaf has one extra parameter - I think it is the return message can Id. Any info/advice is appreciated! Nikolay_______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev _______________________________________________ OvmsDev mailing list OvmsDev@lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
Mark Webb-Johnson -
Nikolay Shishkov
