Any help appreciated to understand why App alerts are being sent with different information to that in the MP-0 message. I assume it is being triggered earlier and then delayed for some reason? 2020-08-05 18:25:08 NZST I (325841) ovms-server-v3: Tx event vehicle.charge.start 2020-08-05 18:25:08 NZST I (325861) ovms-server-v3: Tx event vehicle.charge.state 2020-08-05 18:25:08 NZST I (325891) ovms-server-v3: Tx event vehicle.charge.mode 2020-08-05 18:25:08 NZST I (326031) webserver: HTTP POST /api/execute 2020-08-05 18:25:08 NZST I (326051) webserver: HTTP POST /api/execute 2020-08-05 18:25:08 NZST I (326071) webserver: HTTP POST /api/execute 2020-08-05 18:25:08 NZST I (326091) webcommand: HttpCommandStream[0x3f89a4bc]: 3601112 bytes free, executing: stat*2020-08-05 18:25:08 NZST I (326101) ovms-server-v2: Send MP-0 S62.0,K,371,0,charging,standard,132,101,16,1,0,0,3,1,0,0,0,0,65.44,0,0,0,80,-1,0,0,0,0,0,164,0,-0.51,511.50,82* 2020-08-05 18:25:08 NZST I (326131) ovms-server-v2: Send MP-0 D80,8,4,12.5,0,16,0,447560,0,325,12.5,1,1,1,12.17,0,12.5,0,0,0,16 2020-08-05 18:25:08 NZST I (326091) webcommand: HttpCommandStream[0x3f895bf4]: 3598540 bytes free, executing: stat 2020-08-05 18:25:08 NZST I (326091) webcommand: HttpCommandStream[0x3f89a3f4]: 3600896 bytes free, executing: stat*2020-08-05 18:25:10 NZST I (328121) ovms-server-v2: Send MP-0 PINot charging|SOC: 62.0%|Ideal range: 132km|Est. range: 102km|ODO: 44756.0km|CAC: 65.4Ah|SOH: 82%* 2020-08-05 18:25:10 NZST I (328131) ovms-server-v3: Tx notify ovms/nismo/notify/info/charge.started=Not charging|SOC: 62.0%|Ideal range: 132km|Est. range: 102km|ODO: 44756.0km|CAC: 65.4Ah|SOH: 82% 2020-08-05 18:25:10 NZST I (328191) ovms-server-v3: Tx event notify.info.charge.started 2020-08-05 18:25:11 NZST I (328301) ovms-server-v3: Message publishing acknowledged (msg_id: 216) 2020-08-05 18:25:11 NZST I (329151) ovms-server-v3: Tx event vehicle.charge.pilot.on 2020-08-05 18:25:11 NZST I (329171) ovms-server-v3: Tx event vehicle.charge.prepare
Derek, the "stat" command & notification text (created by OvmsVehicle::CommandStat()), depends on the chargeport door status. If the chargeport is closed, it sends "Not charging". The server v2 code OTOH simply transmits the charge state metric directly and independantly of the charge poort status. So if your CAN processing detects a charge start, it should basically also set the charge port door state to "open" (true). Or, if you need some delay to e.g. validate the charge state or wait for the door state, you can force that by overriding the OvmsVehicle::GetNotifyChargeStateDelay() method in your vehicle. Or, if you'd rather customize the command / notification text, override OvmsVehicle::CommandStat(). Or, if you'd rather take full control of these notifications, set m_autonotifications to false and add your own metrics listeners (see OvmsVehicle::MetricModified() for the standard handling). Regards, Michael Am 05.08.20 um 09:36 schrieb Derek Caudwell:
Any help appreciated to understand why App alerts are being sent with different information to that in the MP-0 message. I assume it is being triggered earlier and then delayed for some reason? 2020-08-05 18:25:08 NZST I (325841) ovms-server-v3: Tx event vehicle.charge.start 2020-08-05 18:25:08 NZST I (325861) ovms-server-v3: Tx event vehicle.charge.state 2020-08-05 18:25:08 NZST I (325891) ovms-server-v3: Tx event vehicle.charge.mode 2020-08-05 18:25:08 NZST I (326031) webserver: HTTP POST /api/execute 2020-08-05 18:25:08 NZST I (326051) webserver: HTTP POST /api/execute 2020-08-05 18:25:08 NZST I (326071) webserver: HTTP POST /api/execute 2020-08-05 18:25:08 NZST I (326091) webcommand: HttpCommandStream[0x3f89a4bc]: 3601112 bytes free, executing: stat /2020-08-05 18:25:08 NZST I (326101) ovms-server-v2: Send MP-0 S62.0,K,371,0,charging,standard,132,101,16,1,0,0,3,1,0,0,0,0,65.44,0,0,0,80,-1,0,0,0,0,0,164,0,-0.51,511.50,82/ 2020-08-05 18:25:08 NZST I (326131) ovms-server-v2: Send MP-0 D80,8,4,12.5,0,16,0,447560,0,325,12.5,1,1,1,12.17,0,12.5,0,0,0,16 2020-08-05 18:25:08 NZST I (326091) webcommand: HttpCommandStream[0x3f895bf4]: 3598540 bytes free, executing: stat 2020-08-05 18:25:08 NZST I (326091) webcommand: HttpCommandStream[0x3f89a3f4]: 3600896 bytes free, executing: stat /2020-08-05 18:25:10 NZST I (328121) ovms-server-v2: Send MP-0 PINot charging|SOC: 62.0%|Ideal range: 132km|Est. range: 102km|ODO: 44756.0km|CAC: 65.4Ah|SOH: 82%/ 2020-08-05 18:25:10 NZST I (328131) ovms-server-v3: Tx notify ovms/nismo/notify/info/charge.started=Not charging|SOC: 62.0%|Ideal range: 132km|Est. range: 102km|ODO: 44756.0km|CAC: 65.4Ah|SOH: 82% 2020-08-05 18:25:10 NZST I (328191) ovms-server-v3: Tx event notify.info.charge.started 2020-08-05 18:25:11 NZST I (328301) ovms-server-v3: Message publishing acknowledged (msg_id: 216) 2020-08-05 18:25:11 NZST I (329151) ovms-server-v3: Tx event vehicle.charge.pilot.on 2020-08-05 18:25:11 NZST I (329171) ovms-server-v3: Tx event vehicle.charge.prepare
Derek Caudwell -
