I'm running 3.2.012. This morning when I went to check the status after charging overnight, which had completed, the iPhone app was behaving in a very strange manner. I cycled a few times (for as long as I watched) through three states at an interval on the order of 10-20 seconds: 1. 86%, ideal range 191, no charge connector icon. Those range and SOC numbers were correct, but the charge cable was connected. 2. 95%, ideal range 177, charge connector icon shown. 3. 48%, don't recall the range, no charge connector icon. When I checked the Car screen, it too was cycling among showing no numbers, showing old gray numbers, and showing some numbers in white. I don't recall their accuracy. Now after I finished my morning walk the display appears stable and correct with 86%, ideal range 190, and charge connector icon shown. The Car screen shows just old numbers in gray except for the aux battery voltage. Sorry I didn't have the presence of mind to grab screenshots. -- Steve
That may have been https://github.com/openvehicles/Open-Vehicle-Server/issues/2 Regards, Michael Am 08.06.20 um 19:02 schrieb Stephen Casner:
-- Steve _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
That sounds plausible. Since the problem ceased, I wonder if that implies that the server was restarted. I'm using Mark's server. -- Steve On Mon, 8 Jun 2020, Michael Balzer wrote:
Regards, Michael
Steve, I wasn’t aware of this issue, but will look into it. I can’t immediately see the cause, but it should be relatively easy to add a clean-up of the channel structures when the connection starts. I haven’t restarted the api.openvehicles.com <http://api.openvehicles.com/> server recently. Regards, Mark.
Regards, Michael
Hi, I’ve also seen this strange behavior yesterday afternoon. I’m connected on the same server (api.openvehicles.com <http://api.openvehicles.com> ). The car was going out of range of the Wifi and using the modem at that time. It seems stable now. Regards, Sebastien Darveau On Jun 9, 2020, at 1:48 AM, Mark Webb-Johnson <mark@webb-johnson.net <mailto:mark@webb-johnson.net> > wrote: Steve, I wasn’t aware of this issue, but will look into it. I can’t immediately see the cause, but it should be relatively easy to add a clean-up of the channel structures when the connection starts. I haven’t restarted the api.openvehicles.com <http://api.openvehicles.com/> server recently. Regards, Mark. On 9 Jun 2020, at 1:39 PM, Stephen Casner <casner@acm.org <mailto:casner@acm.org> > wrote: That sounds plausible. Since the problem ceased, I wonder if that implies that the server was restarted. I'm using Mark's server. -- Steve On Mon, 8 Jun 2020, Michael Balzer wrote: That may have been https://github.com/openvehicles/Open-Vehicle-Server/issues/2 Regards, Michael Am 08.06.20 um 19:02 schrieb Stephen Casner: I'm running 3.2.012. This morning when I went to check the status after charging overnight, which had completed, the iPhone app was behaving in a very strange manner. I cycled a few times (for as long as I watched) through three states at an interval on the order of 10-20 seconds: 1. 86%, ideal range 191, no charge connector icon. Those range and SOC numbers were correct, but the charge cable was connected. 2. 95%, ideal range 177, charge connector icon shown. 3. 48%, don't recall the range, no charge connector icon. When I checked the Car screen, it too was cycling among showing no numbers, showing old gray numbers, and showing some numbers in white. I don't recall their accuracy. Now after I finished my morning walk the display appears stable and correct with 86%, ideal range 190, and charge connector icon shown. The Car screen shows just old numbers in gray except for the aux battery voltage. Sorry I didn't have the presence of mind to grab screenshots. -- Steve _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> -- Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal Fon 02333 / 833 5735 * Handy 0176 / 206 989 26 _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> _______________________________________________ OvmsDev mailing list OvmsDev@lists.openvehicles.com <mailto:OvmsDev@lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
Very bizarre. The issue was hard to track down. Seems to be strange behaviour in SSL connections with faults, where the SSL error comes in, the connection is torn down, but then a welcome message arrives for the login (after the disconnection). If the welcome login succeeds, then the vehicle App connection is associated with the FD# and causes the issue later on. So, the server code sees a login message after the connection was disconnected 😱 2020-06-10 20:36:20.271547 +0800 info OVMS::Server::ApiV2: #253 - - new TLS connection from <redacted> 2020-06-10 20:36:20.273606 +0800 info OVMS::Server::Core: #253 - - ConnStart 2020-06-10 20:36:28.781028 +0800 error OVMS::Server::ApiV2: #253 C <redacted-car> got error: ssl3_read_bytes: ssl handshake failure 2020-06-10 20:36:28.782356 +0800 info OVMS::Server::Core: #253 C <redacted-car> CarDisconnect 2020-06-10 20:36:28.782821 +0800 info OVMS::Server::Core: #253 - - ConnFinish Use of uninitialized value in concatenation (.) or string at plugins/system/OVMS/Server/ApiV2.pm line 631. 2020-06-10 20:36:28.783094 +0800 info OVMS::Server::ApiV2: #253 C <redacted-car> got proto #/C login Use of uninitialized value $clienttype in concatenation (.) or string at plugins/system/OVMS/Server/Core.pm line 237. 2020-06-10 20:36:28.784261 +0800 info OVMS::Server::Core: #253 <redacted-car> CarConnect At that stage, the fd #253 is tagged with an App connection, and never cleared (because the CarDisconnect was before the CarConnect). Later on, that fd# can get data from the original app/car with connection issues. The source of bad data seems to be almost always the DEMO car. Workaround is to add connection checks to the io_line and io_welcome routines, to simply return (discard) if the connection is not marked as up. Will load this live on api.openvehicles.com now, and monitor for a few days. We now have logging for these mismatched connections (and code to avoid sending out the data in that case), so it should be easy to see if this solves the problem. Regards, Mark.
On 9 Jun 2020, at 1:48 PM, Mark Webb-Johnson <mark@webb-johnson.net> wrote:
Steve,
On 9 Jun 2020, at 1:39 PM, Stephen Casner <casner@acm.org <mailto:casner@acm.org>> wrote:
That may have been https://github.com/openvehicles/Open-Vehicle-Server/issues/2 <https://github.com/openvehicles/Open-Vehicle-Server/issues/2>
Regards, Michael
Mark Webb-Johnson -
Michael Balzer -
Stephen Casner -
Sébastien Darveau
